Question about Motorola Mobility Bluetooth Hands Free Headset Wireless Headset
Keeps ringing like there is an outgoing or incoming call and will not disconnect. Have turned off, hit disconnect button and even charged over night. I turn it on and it is still ringing even when there is no phone call incoming or outgoing on my phone. Motorola N 136
  • compton_d Jul 06, 2010
    I only was asked a question and then nothing. I really need and answer. Thank you.
    My motorola N136 keeps ringing like there is an outgoing or incoming call and will not disconnect. Have turned off, hit disconnect button and even charged over night. I turn it on and it is still ringing even when there is no phone call incoming or outgoing on my phone.
  • 1,284 Answers
Hi, you need to take the phone to a phone tech around you to FLASH the phone which will restore it back to factory settings.
You are experiencing a software problem.
Take care
Posted on Jul 06, 2010
  • 4,472 Answers
First off how long have you owned the headset also has it ever worked properly? Once I have more information I can assist you further.
Thank you,
Lee
  • 2 more comments
    Yes it has worked. It has been working for about 4 moths. No problems
    the rining only started this morning.
  • Lee A.
    Lee A. Jul 06, 2010
    It sounds like the unit is defective. You can get replacement bluetooth very cheap on ebay. otherwise if you bought it new you can follow this link and inquire about warranty repair.
    https://globalrepairtools.motorola.com/s...
    Thank you,
    Lee
  • Lee A.
    Lee A. Jul 06, 2010
    You need to give the experts at least a little time to answer your problem. Nothing is instant and feedback from you was required. I hope you will reconsider and accept/rate my solution accordingly.
    Thank you,
    Lee
My Norstar Phone Won't Let Me Pick Up Incoming Calls
Make sure they are Line Buttons, do FEATURE * 0 then press buttons to see what they are/do
Or maybe the key pad inside has failed.
Mar 04, 2013 | NorStar Lands Phones
Already have unplugged everything twice and still will not accept incoming calls. The phone rings once and cuts off. Sometimes the single ring is heard only on the outgoing phone not on the incoming call...
Try reset the phone, Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, see if this fix the problem.
Jun 22, 2011 | Cell Phones
Code LC, I cleaned the filter, won't stop beeping
you need to flush out the rinnai. to do this you will need 4 gallons of white viniger & a circulating pump. #1 disconnect the power. #2 close both incoming & outgoing water valves under the unit. #3 conect a drain hose to the out going flush valve ( flush valves are under the unit & have brass caps) #4 connect pump outlet hose to ingoing flush valve. #5 put pump incoming hose & drain hose from outgoing flush valve in a 5 gallon bucket. #6 pour 4 gallons of vinager into the bucket. #7 open both flush valves. #8 turn on the circulating pump & let viniger pump in the incoming flush valve through the rinnai & out the outgoing flush valve back into the bucket for 45 min. #9 disconct pump from incoming side & close incoming flush valve.( don,t close outgoing vaves at this time) #10 put out going hose in empty bucket. #11 open incoming water to flush viniger out of unit. # 12 disconct outgoing hose , close outgoing flush valve & open outgoing water valve. #13 clean filter & turn on power.
Jul 08, 2009 | Rinnai Water Heaters
Cant get ITCM light to stop flashing - no ring tone for incoming
If you're really lucky, you only put the system in night mode. From extension 10 press ITCM and #. Days :-)
Carl
Jun 03, 2009 | Comdial Impression 2022S-PT Corded Phone
Phone keeps dropping calls
Same issue here. Have you checked the battery? I found out that on mine the battery was leaking and corroding the contacts. Need to call Panasonic to find out if they can do something (about 5 month old phone)
Apr 02, 2009 | Panasonic KX-TG9333T Trio Cordless Phone
Phone won't ring or vibrate and keys click and beep when pressed
I brought my phone in to my service provider and they removed the battery and sim card (because I was unable to turn of my phone with the power button) and rebooted the phone. It's all good now.
Mar 19, 2009 | Nokia 2600
Panasonic KX-TG5632 one handset high pitched constant ringing
you are getting feed back because of too high of a level. Turn your volume down on that handset and the squealing should go away
Dec 27, 2008 | Panasonic KX-TG5632 Phone
Uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Jan 20, 2008 | Uniden Cordless Phone
Motorola Mobility Bluetooth Hands Free Headset Wireless Headset Logo
523 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
