Question about HP Laserjet Cp2025n Printer
Small black dots down center of paper - HP Laserjet Cp2025n Printer
  • 1 more comment
  • steven Jul 08, 2010
    How many on the page.
    Thank You Steven 805-520-3003
  • Al Toledo Jul 13, 2010
    Hi, There could be several factors that would cause this issue, The first being the toner cartridge. Are you using HP original cartridges? It could also be the fuser (the assembly that fuses the toner to the paper). Are you printing on 20lb laserjet paper or some other stock? it could also be a voltage problem with the black toner cartridge. Is the printer connected directly to the wall or a surge protector? Connected through USB or Networked? Al
  • revans257 Jul 14, 2010
    do you have a fax number , if so i will fax a copy of the problem, thank you
  • 223 Answers
Hey revans,
This is a common issue with laser jet printer,
Try running cleaning modes under the service menu on the printer, run 5 back to back. if the issue is still showing, try using a different cartridge and run the cleaning mode again. If you have an old cartridge even if its close to being empty you can do an override on the printer to test the cartridge:
1.press ok
2.use the arrows and navigate to the system set up menu
3. press ok
4. print quality
5. press ok
6. override out
7.press ok and again ok to set
This could also be a build up of toner in the fuser assembly, and you may have to adjust the fuser temperatures in the embedded web server. You can print a blank word document (20 pages) and see if you still see black dots, if you do it is likely to be the fuser, set the driver and printer settings to card stock or heavy in order to heat the fuser more than the usual temp and print 30 blank pages this should resolve the issue. if this does not there could be damage to the ETB or the fuser assembly and servicing of the printer would be required.
take care,
Al
eliteprintersolutions@gmail.com
Posted on Jul 13, 2010
4 Suggested Answers
Muggs01
  • 72 Answers
SOURCE: Small black circle smudges down center of printed page
try replacing the toner cartridge if that does not help it may need a fuser replaced
Posted on Jan 16, 2009
iron_luiggi
  • 91 Answers
SOURCE: When I print or copy, there are small black dots
Hi, check this link there is all the issues, identify yours and they tell what should you do, but appears the cartridge, Q2612A, you must replace de GREEN DRUM, or replace the cartridge.
http://www.printertechs.com/tech/print-defects/print-defects-index.php
Posted on Apr 07, 2010
2pagescouk
  • 325 Answers
SOURCE: How to clean Brother drum
http://www.instructables.com/id/How-to-clean-the-printer-drum-cartridge/
Posted on May 06, 2011
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
When I print or copy, there are small black dots printing on the edge of the paper and also some lighter black dots in the middle of the paper.
Apr 07, 2010 | HP LaserJet 3050 All-In-One Printer
Its stop printing and the LED power light green and orange at the center blink, like there is a paper jam.
Feb 11, 2010 | HP DeskJet 1280 InkJet Printer
Vertical dots down center of paper HP 1320 printer
If the pattern repeats down the feed path of the paper, then a roller is causing it. The toner cartridge replaces the transfer drum, the fuser roller remains in the printer. Since your old cartridge does not show this problem the fuser roller sounds to be fine. Return the recently purchased toner for a replacment, you should be fine. If not then a proper cleaning by a certified technician would be in order.
Aug 26, 2009 | HP LaserJet 1320 Printer
Printer is creating a crease and smudge down center of page.
There sounds like there is somthing in the path of the printhead. Using a flash light, remove back cover of machine and look for a small piece of paper,etc. Be careful not to jam anything in to th machine. It may take running a thick piece of paper through manually with your hands to remove the object.
Feb 12, 2009 | HP LaserJet 1012 Printer
Copier
Take a look at the paper path. You should see a glass strip somewhere. This is that "sees" the paper. This glass is probably dirty. Take a soft cloth moistened with rubbing alcohol or maybe Windex and clean it. Even a small dot on this glass will show as a long line on your paper. If the line is still there, it may be on your drum which will need replacement.
Hope that helps.
May 07, 2008 | Brother IntelliFAX 2600 Fax
Black bullets down left side of paper
inspect the pc drum, if there is no dots, then its ok, also inspect fusing unit rollers and transfer belt for dots and clean laser glass.
Apr 24, 2008 | Konica Minolta magicolor 2300DL Laser...
HP Laserjet 1320 - Gray bars printing on sides of paper with dark dots
It sounds like a defective toner cartridge. Try replacing it. If that does not cure the problem, then the fuser assembly needs to be replaced, in which case it is probably cheaper to buy a new one.
Good luck
John
Dec 31, 2007 | HP LaserJet 1320 Printer
Dell 1600n: Toner marks down the center of the page.
There are 2 seperate glass areas on the top, the large one is for when you lift the cover to scan or copy, the little narrow one is when you use the ADF. If there is a dot or a spec on the narrow part, it will leave the streak on the page, Clean the narrow part really well. I use a foaming window cleaner, and a razor blade.
You may also want to check to see if there are any small scratches on that glass. That will cause the same thing to happen.
Nov 14, 2007 | Dell 1600n All-In-One Laser Printer
HP Laserjet Cp2025n Printer Logo
279 people viewed this question
Seeker5211
Seeker5211
