Question about Ondine Brass Showerhead
Installation instructions on Ondine shower model#25020-3,Were to find,was lost by the previous plumber.
4 Suggested Answers
  • 8 Answers
SOURCE: bathroom stall shower
Most handheld showers use a hose to connect from the existing shower arm down to the hand held option.  Some units come with attachment points on the shower arm, but I believe that you are looking for a unit that has a hook that you can mount where ever is comfortable for you.
Posted on Oct 16, 2008
heavyt15
  • 91 Answers
SOURCE: I need a square white plastic cartridge for the
Easy way go to your local plumber or call...maybe take a pic.
Posted on Aug 22, 2009
motor1258
  • 6674 Answers
SOURCE: We have an Ondine Hand Shower. Ondine Interbath
Either remove it and soak it in CLR (calcium,lime, rust remover) or fill a container and tie it to shower outlet in such a way that head is emersed in the CLR. You can buy it at pretty well any hardware store, or home depot. If you don't want to try that, use vinegar, and soak it as well, I usually try to do it at end of day when shower won't be used, then let it sit in solution overnight.
Posted on Jan 03, 2010
Our shower valve will not shut off on new install
It's not clear whether you installed this yourself or whether a plumber did the install. I suspect it's a DIY effort, so you may have to de-install the unit and return for an exchange. A reputable plumber would have checked the unit out before leaving your home.
Sep 02, 2017 | Home
How do you replace the cartridge in a Ondine volume control valve for a shower
Turn off the water supply before you work on the control valve.
You need to remove the lever/handle first and covers so that you can see the stem of the control valve. Then, use a spanner to unscrew the stem/cartridge.
Feb 22, 2014 | Ondine Brass Showerhead
Installation instructions plumbing
He put the wrong faucet in the cold-water side.. There may be a way to change the direction without changing the faucet... but, if there is, I don't know about it... I think you need to make the plumber come back and fix it right.. I had that problem in my shower after a plumber worked on it.. I almost burned myself to death trying to adjust the temperature.
Nov 19, 2013 | Cifial Hi-Arch Widespread Lavatory Faucet...
Our Ondine ESS Model # 25021-2 is reading an error message E 3. Our builder did not give us a user/service manual and we have no idea how to troublehoot the problem. It may have to do with temperature...
I have a manual with the error codes listed.
E3 is the error code for:
A. valve is "frozen" or
B. motor is unable to turn the thermostatic valve.
I have no idea how long this question has been out here so if youve already found that out I hope you have resolved your problem
Jun 04, 2011 | Ondine Home
My contractor installed a 4 port diverter. The hot and cold are ok, but when I turn the shower on, the flow starts in the hand held shower head and not the main shower head. According to Grohe, whichever...
I haven't had a lot of experience with Grohe brand but have had twenty eight years as plumber, 22 years as master plumber and the bottom port of every tub or tub/shower valve that I installed used the bottom as main supply port. As far as the instructions from manufacture like I said I have not used that particular brand much,so I really couldn't say. Hope this helps some. Thanks
Nov 10, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
We have an Ondine Hand Shower. Ondine Interbath 112.18.1M 25GPM/9.5 LPM MAX and the head is clogged and we do not get a full spray - How do I clean it? S. Seipp
Jan 03, 2010 | Ondine Brass Showerhead
Kohler K-9511-BN MasterShower Shower Arm & Diverter Doesn't Work
As a helpful hint , on these models, When installed some plumbers or home owners use plumbers putty to seal the threads and in some cases tape.
Most of the time the putty or tape gets pushed through the system if too much was used.
Check by removing the shower head and testing the pressure and blowing anything else through, then checking the head itself for foreign objects.
Kohler has a cleaning and care page on thier web site if it needs cleaned.
Jan 10, 2009 | Kohler K-9511-BN MasterShower Shower Arm &...
Assembly and fitting of shower screen
Hi trimdon tony,
I'm Harvey the Master Plumber.
Your problem is: You have a ceramica PWAU0071 shower screen a box of fittings and no instructions on assembly.
In this case the only advise I can give you is to ask the manufacturer for a copy. That"s what I would do. It can be e-mailed, faxed or snail mailed. Be nice. Just tell them you like the product but you lost the instructions. Works every time.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 26, 2008 | Home
How do you install body jets for a shower
Hi mickgosney
Your question is how to tighten up in the wall without putting a stud wall in for kyra body jets.
Kyra sells about fifteen models and they are all designed to be installed in a wall of some type.
The wall lends some very nessessary support to the valve body so that the whole thing dosen't move when the handle is adjusted. Wood stud, metal stud and concrete are typical structures. If you are trying to install on a free standing shower I recomend at least some kind of creative frame to support the valve.
Feel free to contact me again.
Please give me a rating here at fixya.com before you sign off.
Thank you,
Sep 06, 2008 | Home
Ondine Brass Showerhead Logo
224 people viewed this question
Top Ondine Home Experts
john h
Tom Chichester
Are you an Ondine Home Expert? Answer questions, earn points and help others
