Question about Craftsman Garden
Sears Craftsman mower-Tecumseh engine 3.75 HP- wouldn't start-replaced air filter & spark plug; dismantled carburetor and cleaned it; now it will start but only runs for a couple of seconds and dies. Suggestions?
Check the linkage for the governor, maybe on the wrong side,when off it should be pushing the throttle wide open, the governor brings it down after start up!
Posted on Jul 24, 2011
Tecumseh 143-434332 on craftsman mower, Will not start
If you have oil on the plug then you either have a valve problem or ring problem.
Jul 31, 2016 | Craftsman Garden
Toro GTS 6.5 HP doesn't run well in grass. Any ideas?
Has the fuel filter been replaced lately? Also you can look to see if the new spark plugs are getting fouled out still. Sometimes just replacing the spark plugs wont fix the problem.
Feb 17, 2012 | Garden
My name is jim. My Sears Craftsman lawn Tractor
Clean the carburetor. The needle and float are stuck closed, passage blocked or a jet plugged with debris. Give it a good cleaning.
Jul 30, 2011 | Craftsman Garden
I have a 4 hp tecumseh that runs good when it is first running.After a little while it seems to loose power,runs slower and slower.Ive cleaned and set float in carb,put a new carb kit in also.plug and wire...
This could be 3 of possible solutions to this problem..
From a Sears Tech of 22 years,,,,,,,,,,,,,,
1) Replace the Fuel Cap! Remember that air must fill the void of the fuel going out to the carburetor, If the fuel cap is clogged It will cause poor performance.
2) Clogged fuel filter or bad fuel line, Ethanol in today's fuels can cause many problems for fuel related components in any engine that is made today!
3) Carburetor and Ignition, including flywheel timing key! Possible sheered flywheel key, Lack of fuel to engine over 5 minutes. Vapor Lock? Change to different fuel filter!!!
Best regards,, Scooter Tech....
Jun 11, 2011 | Craftsman Garden
I have a craftsman rider w/ a 12 hp tecumseh. it
Most surging problems today are caused by a 'lean fuel' condition caused by 'varnish' or debris in the 'main jet' of the carburetor. Many times the jet can be cleaned with a thin piece of wire commonly called 'tag' wire. It is smaller than the main jet hole and does not damage the hole. The main jet is commonly the nut on the bottom of the carburetor that holds the bowl onto the body of the carburetor.
If the body or bowl of the carburetor is plastic, then the best solution is to replace the bowl with a kit that is offered by the manufacture.
In some cases, the carburetor has an electric fuel solenoid, which when malfunctioning, will not allow enough fuel into the main jet to operate the engine.
Nov 07, 2009 | Craftsman Garden
I recentley bought a Craftsman 4.0 HP mower at a yard sale, tested it before taking home and it fired right up. It did run a little rough so I replaced the air filter & spark-plug. Once again it fired...
You need to disassemble the carburetor and spray the with carb. cleaner. Make sure all small debris is out. Ckeck any gaskets for signs of ware. If they look bad, replace them; your carb. could be sucking air if so. Also check the fuel filter to see if gas is flowing through it.
Jim
Jun 09, 2009 | Craftsman Woodstock Percussion Crcbm ...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor
This sounds too easy of a solution but I had a like ptroblem with my Craftsman. I loosed the gas cap a bit and the rough running and stalling stopped. he vent on the gas cap that contains a turn over interrupt valve was plugged causing the gas not to flow. I took the cap apart and cleaned out the vent hole though cleaning the holewith a paper clip would have worked as well. Anyway..it fixed my problem. I think my dirty hands of deris deposited the matera in the vent hole when filling with gas.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
507 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
