The unit gets ice on the evaporator then the blower motor blows it in the room. The unit keeps the room cool. How do I fix it? I am a licensed a/c mechanic, but I do installations.
Make sure the coils are not dirty,if they are not dirty,add freon to the system,not much,feel the evaporator,when the evaporator is cool all over,and the condenser is warm all over,there is enough freon,add very little at a time,this system does not hold much freon,if this was helpful,at all,please rate,thank you.
Testimonial: "Thank You. It worked. It turns out that leafs from the tree that the unit is under fell inside the top vents of the casing. Ths must have happened in the fall. It was blocking the air flow through the condenser as the fan turned. I did a total clean out of the unit. I cleaned both coils too. The a/c worked wonderful last night. There is no more ice on the evaporator coil. Thank you very much, Paul"
