Question about LG LC1000 Air Conditioner
My portable air conditioner will not cool the room lower than 80 degrees, even though it is set for 76. It is staying at 80. How do we get the temperature to go down?
5 Suggested Answers
  • 50 Answers
SOURCE: Danby Portable Air Conditioner DPAC120068 - room temperature
Maybe, the compressor isn't starting? I'd take it back to where you purchased it.
Posted on May 18, 2008
jumptrout51
  • 3361 Answers
SOURCE: Carrier Comfort 13 Puron model 24ACA3 / FV4NB006
Verify 24 volts at the low voltage transformer inside the air handler. If it is OK, jump out the red/green and yellow thermostat wires. If everything comes on, replace the thermostat.
Posted on Jun 08, 2009
6ylucy
  • 742 Answers
SOURCE: Error code E2 on Boston innovative products Air conditioner.
find the user manual here:
http://manualfox.com/link/bostoninnovative.htm
Posted on Jun 26, 2010
heatman101
  • 43501 Answers
SOURCE: portable air conditioner not collecting water
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 22, 2010
Lowering arcticpro temp.
Find in a manual in advanced setup where you can adjust the maximum and minimum cooling and max min heating. Should be a set point that someone set to where it won't go lower than 76
Jun 05, 2016 | Arcticpro Ypc-07c Faac7 Portable Air...
Wont let me change temp. below 76 degrees on arcticpro
76 f is 24 celsius which is optimum temperature for comfort
What tempiture does my pac a110 delonghi have to be on to get cool air
The temperature has to be lower than the room temperature it's in. Most thermostats are set to 76 degrees or lower.
Jun 27, 2014 | Heating & Cooling
How do i get my portable haier air conditioner cool off my house below 73
Air conditioners can only drop the temperature of the room temperature a maximum of 15 to 20 degrees F. A 95 degree F room temperature can drop to a maximum temperature of 75 to 80 degrees F. If the room temperature drops from 95 to 85 degrees F, Then the problem is having too small of a btu rating on the air conditioner or refrigerant has leaked out the sealed system which can affect the amount of cooling performance. You will have to buy a higher rated btu rated air conditioner if the temperature of the room drops by only 10 degrees F. Air conditioners are rated by how much heat that can be removed each hour. The more humid it is, the more work an air conditioner has to do. They cannot do more work than the btu rating that is listed on each air conditioner.
May 26, 2014 | Haier Heating & Cooling
I set remote on "cool"
Hi there, this is a 21/2 ton split system. You can lower it to 68 degrees, but I wouldn't go any lower then that.Auto is for the fan only, it cycles on and off in the auto position, and in the on setting it runs all the time even when the cooling stops just to circulate the air. You can try and leave it in the on not auto as this may help the room stay cooler. Please keep me posted.
Shastalaker7
A/C, Contractor.
PS, if the remote does not say on, and just says auto and cool, set it to auto.
Jun 09, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
The thermostate now reads 112 degrees and will not go below 97 this causes the cooling unit to stay on at all times even though the true room temp is 71 degrees. What is wrong with this thing? It appears...
Hello,Locate and move the thremostat sensor(bulb) to a different location as it is near something on the unit that is 112*f.It needs to sample return/intake air temp.
Sep 18, 2010 | Amcor Portable Air Conditioner...
Room temp stays at 76 and will not get any colder even though unit seems to operate and compressor sounds like it turns on and fan blows and water drains . it is set to 60. room is about 300 sq ft
From what you are describing the unit is working perfectly...You just have alot of heat infiltration and the best that unit can do is 76....
If you want or need it cooler you will need to buy a larger size unit...
heatman101
May 06, 2010 | Maytag M6P09S2ACOM Air Conditioner
Royal Sovereign not keeping the room cool.
electronics give off alot of heat you need larger unit
May 19, 2009 | Royal Sovereign ARP-4009 Portable Air...
My appartment does not have cenral AC/heat, it has a GE cooling/heater unit in each room. You can set up low heat or high heat but it continues runing on until you manually stop it when is to hot. Is there...
the unit runs all the time because of the fan (ventilation motor)-but it is not working on cooling or heating all the time - The ventilation motor pushes the air from the room through the machine and when the termostat is reading that you set it up for cooler air or warm air it will turn on the air conditioning part or the heating part of the machine-it is very good system actually
Oct 04, 2008 | Heating & Cooling
Edgestar 12000 heating problem
bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
Dec 24, 2007 | EdgeStar Portable Air Conditioner Heater
LG LC1000 Air Conditioner Logo
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
