Question about HP Pavilion Slimline s3620f Desktop
My hp pavilion slimline went to the blue screen today that said an error occurred and I should shut down and restart and run the harddrive diagnotics. But when I shut it down, it will turn on, but not startup or run Window. It just sits there doing nothing. The USB port works to run another device. What can I do to get it started to run the diagnotics?
  • padei138 Jul 06, 2010
    I tried unhooking everything and holding the power button. I then hooked up the monitor, mouse and keyboard adn turned it back on. I hit the F10 numerous times, but the keyboard lights never lit up and nothing happened on the screen. The monitor light flashes like its in power save mode. Any other suggestions? Thanks for the help.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 53 Answers
You can try to do a Power drain of the system ie disconnect all the cables from the pc and press and hold the power button of the tower for 30 to 40 sec. than reconnect only the keyboard the mouse and the monitor and turn it on. try to enter the BIOS page ( keep on tabbing the F10 key to enter BIOS is Windows Vista during the start up and F1 in Windows XP) and from their you can run a Smart test on the Hard drive. You can also try to boot the Pc to the safe mode and check whether the windows loads or not. From the Advanced boot option try to do a Start up repair.
Posted on Jul 06, 2010
" i have hp pavilion g4 laptop, i have a complaint that my system hangs up with a jerking noise hearing continuously while playing vedios fron internet, and from hard drive also, i cannoe shut it down
it ussualy occurs due to blue screen errors try removing any latest software or it is because of power shortage for a few seconds try cleaning your ram with an eraser .
Sep 25, 2012 | HP Pavilion G4-1213nr 14" Inch...
My hp pavilion desktop is blue screening.
Is your computer infected with the XP blue screen error? This is the error that shows up as blue screen with white text, and there is usually no way to recover the computer, except to restart it. For some people, the blue screen may go away after that, but that was certainly not the case for me a few months ago. It kept reappearing regularly afterwards, and I was convinced that something was wrong with the system.
1. Why Does The Error Occur?
Once the blue screen error persist on your computer, it will not go away unless you fix it. The most common reason for the problem is errors in the computer registry. It contains all the instructions that instruct your program applications to run correctly.
2. How To Repair The Registry?
The blue screen problem can be easily fixed by using a registry cleaner, if your errors are caused by errors in the registry. This was exactly what I did to cure my computer. It does not only get rid of the blue screen, but you should also find that your computer performance will improve if you have never maintained your registry before.
To clean your registry, you will need to download a cleaner software and run a free scan to find all the errors.Here are some of the Best Registry Cleaners :Tuneup Utilities,Registry Mechanic,CCleaner.
If unfortunately, your computer problems are coming from the RAM, you will have to replace the faulty RAM stick. You can also test your current RAM stick by changing it with another working one, and see if the blue screen error returns. If the error still persists, it would mean that there is no problem with the RAM stick, and vice versa.
Oct 15, 2010 | HP Pavilion Slimline s3620f Desktop
Ok..So I've had my tx2500 for a little over a year now (go figure, the warranty's out). After I booted up today, I went online and after a few minutes, the screen went pixel'y' and then went blank. The...
there is something wrong with the video driver or the monitor...If the screen shows something like the devices when it boots up...and only goes blak when it logs to windows...I mean if you see all on the screen until you get to the windows logo..this is a operating system error ..a driver seting or crash...so ...just reinstall it ..or repair the operation system ..cause if it is a setting on video driver or a error ..you can not fix it if you do not see anything ..
if the system boots but you never see a thing on the monitor...not even the writen devices when it first starts..or the bios..this means that the screen or the ribbon of the monitor has a damage on..try to change its position...or so ..but in this case you will need a ribbon for sure ...
Jan 31, 2010 | HP Pavilion tx2500z Notebook
8 screens + blue screen + hangs
i think u need to reinstall the graphics driver, hope it would help. if it doesnt then visit the below mentioned link for a free diagnosis.
http://tinyurl.com/m7ghqz
Jun 16, 2009 | HP Pavilion dv2500t Notebook
HP Pavillion dv9000 fatal error
On the windows boot screen you should be getting choices for safe mode, safe mode with networking, etc ...
Select "Disable automatic restart on system failure'
And let me know what error message(s) you have ... write it all down
Jan 14, 2009 | HP Pavilion dv9000z Notebook
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Description
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
Solution
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&product=18703&docname=c00608578#
_____________________________________________________
Thanks and Regard
dilipbagdi
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
HP pavilion will not shut down
pull the power cord out and the battery (or just let it run out). Then, try turning it back on again. If it does the same thing again then yes it may be old blue death and your harddrive may be worse than dead. I don't believe that the power button doesn't work. Hold it in for 10-15 seconds or so, any computer is DOS programmed to respond to the power commands above all, even above the dreaded blue screens. Let me know if I'm an ******* and I don't know what I'm talking about or if you need more help.
Mar 07, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
HP Pavilion Slimline s3620f Desktop Logo
265 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
