Question about Canon Cameras
Lens error message on the cannon s90. how to
Lens error message on the Cannon s90 Power Shot. How to restart camera?
  • 4102 Answers
SOURCE: cannon zoom sd870
hi have you tried removing the battery for couple of hours so it can reset any settings that need to be set back to default it only resets camera memory not settings you have changed but this can sometimes solve the problem your having.
Also when you switch camera on and then press zoom when the camera switches off does the lense go back inside the camera as normal or does it reamin out.
when you switch in on do all the other buttons work like can you take picture and can you access all the menu if you can then take it off auto if its on auto then see if this let you use zoom if not then the chances are their is a fault on the zoom button either jammed could be that the lense motor has come out of line with zoom button, is the display clear when you go to take picture without adjusting the zoom is it still possible to take pictures
Posted on Apr 09, 2008
SOURCE: my lens on my cannon
need a screen for avorcent dc-520
Posted on Apr 12, 2008
SOURCE: Cannon Power shot SD630 Lens Problem
We had the same problem after my wife accidently dropped ours. I disassembled and reasembled our camera, after assuming that the lens was not recognizing that it was closed, hence the error. I can try to fix your camera for $50 and you pay all shipping charges.
Posted on Apr 23, 2008
SOURCE: Cannon Power Shot SD750 Lens error, restart camera
i hve a canon power shot S1 IS camera.. my view finder has no picture and the memory card is empty
Posted on Jun 22, 2008
I had the same problem, tried different things but this is what worked.
I put the camera flat on its "back" (screen down, lens up). Looking down at the lens I could see that it was slightly off center. I pushed the lens towards the center and down, forcing it to close. Once it was centered I was able to turn it on and off no problem.
Posted on Dec 02, 2008
Canon power shot 880. Error message- Lens error. What does this mean and what to do about it?
We should mention the units first so,cannon power shot 880 watt
May 23, 2017 | Canon Cameras
How do you reset a Cannon Power Shot A560 camera
Lens errors are usually caused when there is something interfering with the extension mechanism , or your camera been dropped with the lens extended, or your batteries ran down . try the ff. procedures hope this helps
  • replace a fully charged batteries / battery pack
  • check out this link
Do It Yourself Digital Camera Repair
Aug 27, 2014 | Cannon Cameras
My Cannon power shot s5is was saying lens error, restart camera. Does not restart. Lens remains out and switches off.
It seems that either the plastic drive mechanism is worn/damaged, or the motor (possibly it's drive electronics) have failed. If an extended lens is bumped (or dropped) the plastic worm gear assembly suffers damage (easily too), and the mechanism cannot retract.
Jun 11, 2011 | Cameras
'"The lens of my cannon
This is basically the infamous Canon "E18" error, which has been around for quite a while.
I would type out my own suggestions but since it's such a common error I'll just direct you to a nice long list of solutions already compiled elsewhere: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Mar 01, 2011 | Canon PowerShot SD1000 Digital Camera
My camera power shot s315 lwns wont come out and it keeps saying lens error restart camera where or how can i get it fixed
Common problem with cannon cameras. Cannon will not admit. You can send to Canon, but they will request "standard charge" of $100 plus fix costs. Best bet is to see if they will give you credit toward a new camera or buy a new one, lots of great cameras out there for under $150.
Mar 18, 2010 | Canon Cameras
Canon Power Shot A590 IS lens error message won't
Sending it to an authorized cannon repair facility. the lens must be replaced.
Sep 30, 2009 | Canon PowerShot A590 IS Digital Camera
Camera was dropped now it is saying that there is a lense error HELP!
My camera was dropped and now the lens will only detract half way. It says lens error and restart camera. It is a Cannon Power Shot SD1100 IS. Thanks.
Jul 13, 2009 | HP Photosmart M425 Digital Camera
Lens error= restart camera - this is the message I am receiveing from my cannon SX110 IS
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
May 24, 2009 | Canon PowerShot SX110 IS Digital Camera
Help please
I'm assuming you have a lens error which is giving you the restart message.
It is kind of misleading, but to restart the camera means to power cycle the camera or remove and reinsert the battery.
If you do have a lens error, if restarting the camera doesn't work, you'll need to get the lens fixed if to remove the error.
Dec 17, 2007 | Canon PowerShot SD600 Digital Camera
Cameras Logo
268 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
