Add CD-RW Drive
Sir i have a computer which has a cd-reader attached to it now i want to add a cd-rewritable drive to it, what are the configuration to be changed, or what is the procedure to do that? kindly suggest me a solution to the problem
    Problem Solver:
  • 28 Answers
Your jumper should be set the same as your previous drive if it's a replacement.
Posted on Apr 18, 2008
In my desktop computer the LG CD/DVD writer/reader is showing empty though the CD is filled with data..hat could be the reason, i tried by re-installing the drivers but no success...
Not knowing the operating system, In windows 7 and 8 sometimes it forgets the cd format. Then you need to go to the device manager and remove the drive and let windows re-detect it.
Feb 11, 2015 | LG Super Speed USB 20X DVD / 48X CD...
I conect external super multi DVD rewriter GSA-E60n, but i can not install in my pc.my pc is ASUS Eee pc 900, I want install one recovery cd in my pc,problem is this not working with my pc,I have to...
click start control panel administrive tools scroll to cd/dvd drives connect this dvd rw then see if your drive there if not check the leads that attach from the dvd drive to the computer make sure they have secure connections and are seated properly or you might have to activate add new device wizard click start control panel you will see add a new device this may vary depending on your operating system
hope this helps
Mar 28, 2011 | LG SecurDisc 20x External Double-Layer DVD...
I bought 2nd hand NEC ND-3540A DVD-RW CD-RW DUAL LAYER REWRITER IDE for the replacement of Philips DVD R/RW Drive (DVD8631/96). However this ND-3540A will cause the ploblem of not only unworkable, but...
since you have been inside your computer and moving leads about some of these may be old and deteriotaed then any movement might
(crack break the circuit even if its slight)
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 10, 2011 | NEC ND-3540A DVD RW Dual Layer Burner
Sir iam unable to write on dvd, does this laptob contain with dvd drive
as per configuration i think urs is combo drive cd rw +dvd reader. we cannot write dvds
Mar 27, 2010 | Fujitsu Siemens AMILO D-7830 Notebook
How do i format a Cd on windows xp
1 Open your disk drive2_bing.gif. Ensure that your disk drive is empty before proceeding, some CDs, especially CD-RWs, will be erased if you skip this step.
  • Step 2 Place CD-RW into CR-R drive. The disk drive may automatically detect this is an empty or "clean" disk. If so, skip to step 4.
  • Step 3 Find the disk. Click on "Start," then "My Computer," then on "Devices with Removable Storage," and then right-click on the CD-RW icon.
  • Step 4 Format the disk. Select "Format Disk" from either the drop down menu on Step 3 or from the Dialog Box in Step 2. This process should take only a few minutes to complete. If your CD-RW has information on it already, you may select "Erase CD-RW" instead of "Format Disk."
  • Mar 16, 2010 | Microsoft Windows XP Home Edition
    Which dvd disks do I buy to burn a dvd on my optiarc dvd rw ad 7563a ATA Can I add later batches of pictures? can I reuse the DVD disks?
    DVD media has several types:
    * DVD-R ("write-once-read-many")
    * DVD+R ("write-once-read-many")
    * DVD-RW ("write/erase/rewritable")
    * DVD+RW ("write/erase/rewritable")
    * DVD dual-layer ("write-once-read-many")
    Some CD/DVD-writing software allows multiple "sessions" (write a bunch of files, do not "close" the disk, much later write a bunch of files), so that you can "add" files to an "open" ("non-closed") CD/DVD disk.
    Jan 24, 2010 | Gateway (5500652) (  5500652)...
    Acer Aspire 3000 CD-RW/DVD not working
    in add new hardware
    you should be able to add your cd drive
    does the drive show in my computer if so you can check the settings there
    May 01, 2009 | Computers & Internet
    Looking for.....
    You will need a low profile dvd. Do you want a part and vendor?
    Worldvet
    Jun 21, 2008 | HP Compaq Business d530 Ultra-Slim PC...
    ATAPI DVD+RW Burning Problem
    DVD / CD-RW is usually a a combo drive
    DVD PLAYER with CD BURNER
    DVD-RW is a dvd rewritable drive
    Dec 30, 2007 | KHypermedia (KHCRW522452) (20326452) CD-RW...
    Dvd rewriter
    may be some dust in ur dvd drive man ...just try to clean u r lens  by a lens cleaner disk..which is ablable in market with a liquid...
    best regards & best of luck..
    even u can mail me at my mailing add- sigma_shiva1@yahoo.co.in
    Oct 12, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
    Computers & Internet Logo
    David Payne
    David Payne
