Question about Dometic Rooftop RV Air Conditioner
Model 630516 the compressor shuts down and fan keepsrunning, almost seems like the heat pump comes on. Unit is set in auto run mode when this happens.
  • 11,800 Answers
On this device the heat pump uses the same compressor as the AC so it can't just jump from one mode of operating to the other.
In Auto mode the compressor shuts down when the set temperature has been reached and the fan is kept running for a while to keep absorbing the residual heat - the same way the fan on a car's radiator is kept running for a while after the engine has been stopped.
Posted on Jul 06, 2010
Compressor relay switch
What temperature is this heat pump being run at? If it is low ambient temp outside this may be running in what is called defrost mode to where the compressor will run without a call for heat. This seems normal to me as long as the setpoint temperature is being reached.
Dec 25, 2013 | Honeywell Heating & Cooling
Heat pump compressor wont come on in heat mode, works fine in cool mode, we get heat occaisionally for about 2 min, then the compressor shuts off. it is a fridgedaire window unit.
Try setting the thermostat at a normal heat setting. By raising the temperature too high the unit thinks that the heat pump won't be effective and go into strip heat mode.
Nov 17, 2013 | Frigidaire Energy Star Room Air...
Heatpump r-22 rudd system,unit runs starts out heating then compressor stops in middle of heating ,this unit has a out side air temp. sensor just wondering if possible bad board or not
If compressor stops in middle, check the following.
1.Thermostat setting must be minimum +3 degree than your room temp
2. Check it's in heat "mode"
3. Check indoor and outdoor coils are clean.
4. Check fan motor is working alright.
5. Outside sensor and room air sensor is placed correctly.
6. Gas pressure is o.k
7.Check compressor is overheated, even all the above is o.k.
Jan 12, 2011 | Ruud UAPA024 Air Conditioner
Duro-therm rv roof a/c..model 57915.331...compressor coming on..fan not running..after a couple min. breaker trips....fan will not run on manual or auto...help,blackie williamson
Either your fan is stuck due to age or grime or is shot
if the fan does not provide cooling then the unit goes into thermal protection mode and shuts down
Jun 09, 2009 | Dometic Rooftop RV Air Conditioner
Compressor runs, overheats and shuts down..fan does not run...
I have had the same problem. Following the advice of someone on these pages I opened the machine up and checked the fan with a meter. On my model (the 404) it has two settings so two leads; one seemed okay, the other was dead. I checked the circuit where the fan connector plugs in and I got that both speed settings were supplying plenty of juice. Apparently the fan motor is dead. A replacement runs $79 at http://www.appliancefactoryparts.com/. I ordered one; we'll see what happens.
Apr 11, 2009 | Goldstar DH504EL Dehumidifier
Will not heat below 40
2nd stage heat should kick in on auto defrost ,sounds like bad sequencer or relay
Jan 27, 2009 | Intertherm P3RA-036K Air Conditioner
LG PTAC acting strange in heat mode
I believe the problem in lies in the dual stage heat mode setup on the thermostat, but the unit going into defrost does make the unit act kinda strange. Even more so than other types of equipment. I would suggest hiring a licensed HVAC service technician if the problem cannot be resolved by yourself.
Dec 15, 2008 | LG LP120HED Wall/Window Air Conditioner
Compressor fan not running
Does it look like the coils are frosting over? Is it steaming? Keep watching, after about 30 min does the fan come back on?
If yes to any/all the above then the unit is probably in defrost mode and yes the fan will stop blowing during that time, but restart when the unit goes back into regular heat mode.
During this time you will likely notice warmer heat from the vents than normal and the "AUX or EM HEAT" light will be on.
That is your backup heat system. It should automatically come on during a defrost cycle.
Dec 06, 2008 | Goodman CLQ36AR49 Air Conditioner
Ruud heat pump outside unit trips circuit breaker
Check your wiring between the contactor and compressor for a short to ground, or check the compressor windings for short to ground.
With the Tstat off, the contactor should be open so the only way for the compressor to be trying to do anything is if the 110 volts from the unbroken side are traveling through the compressor to ground. Since 110v is not enough to run it, the overload is kicking it out, cooling off, and repeating the cycle. When you kick on the Tstat, the contactor is supplying voltage directly to ground without going through the resistence of the compressor windings and kicking the breaker.
Post back and let me know what you find.
Nov 20, 2007 | Ruud Central System Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
70 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
