Question about Cell Phones
My handset is not working. The base is fine because I have two phones and the other one is working. The battery is also OK because I replaced the batery from the other phone and it does not work even with this battery from my second phone. The display is blank and it does not have a dial tone. It appears completely dead.
  • samkar1 Jul 06, 2010
    Your first expert did not even read my problem because he was suggesting something that I have already done and described in my problem. Anyway, I also noticed that for some reason it seems to be in cell phones category while my problem is not a cell phone problem. I also stated my telephone model but did not see it in the Problem Statement. My phone is a cordless Beocom 6000 made by Bang & Olufsen>
  • 1,606 Answers
If you have swapped batteries and they worked on the other set then the problem is going to be internal to the dead handset. With no life showing at all ie no display the problem could be anything from a blown surface mount fuse to the processor and so on. Quite hard to tell until you had it on the work bench to test.
Unfortunetly there is very little you can do other than swear at it or take it to the warrenty repair shop. If its under warrenty they may (if you are lucky) be able to repair or swap just the dead phone. If they are typical they will want the enitre unit with both phones back.
The phones won't actually be repaired they will be replaced so if you do have to take them in don't forget to save or write down your numbers etc.
Posted on Jul 06, 2010
  • 677 Answers
When a phone does not come on, it is either the battery of the phone is dead,
might need to be charge or replaced with another battery.
you can use another battery to test if it is the battery the fault.
The other thing to check is if the phone memory is weak and may need to be restored
back the phone memory.
will need to be flashed.
when a phone won't turn on and blinks red light, it 's either the battery cell
if too weak to power up the phone all application you downloaded on the phone has
VIRUS and has affected the phone memory.
First Charge the battery forlonger hours before using another battery to confirm
if the battery cell is the problem.
If not battery, in think you will have to flash the phone memory for it to come back to life.
You can use the link below to know about how to flash the phone.
(unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
  • ikechukwu joshua
    ikechukwu joshua Jul 06, 2010
    Hi, when you check a phone with another battery and still doesn't come on, that means it's not a battery,but a software problem,since it didn't fall inside water or on the flow.
    flash the phone.
    Or you can contact your service provider for assistance.
    Take
    care.
My neighbors AT&T cordless phone with two handsets has a power failure. I plugged another phone into the Comcast phone jack and it is working OK. I figure that the Comcast service is good. It must be...
If the other phone works fine, then it's probably the base of your neighbor's phone that is the problem, that's why neither handset will work when placed on the base. If you can take the base apart, you can blow some compressed air into it to remove any dust buildup, and check to make sure all of the connections are secure.
If the phone still won't work, do the lights come on to let you know the handsets are charging when you place them on the base
Mar 25, 2010 | AT&T 650530003417 Cordless Phone
My phone says no link to base but I am right beside it.
Sounds like the antenna on the base station is not receiving, or the cordless handset is not transmitting -OR- the sets have never been registered to the base station (please look up registering to base station, if the set has never been registered)
Did the cordless set work before?
The base station or the handset may just have a hick up, I would un-plug the base station and leave it un-plugged... now get all the cordless set(s), and take out the batteries from the cordless set(s). Wait for about 15 seconds for all the power to drain out of the sets, then re-install the batteries.
Once all the cordless sets are back up and working, plug in the base station and wait for about 1 minute.
This forces the base station to re-establish and link between the base station and the cordless sets.
Good luck
May 11, 2009 | Panasonic KX-TGA101S Cordless Handset
One phone just stopped working
some DECT handsets have an internal fuse and please swap the batteries to check if both batteries are Ok
Nov 27, 2008 | Vtech Cordless 6041 Phone
Problems with C110 & A110 Vtech Mirage Dect Home phones
Have strangely got the same problem - about the same time you posted this, but intermitently. I have isolated that the problem is in fact the handset itself, not the base unit. I eliminated a problem with the base unit by a) registering a different DECT phone to it. - The base still works fine. b) Leaving the handset switched off for an hour or so (press and hold the "OK" botton to switch off / on); then whislt it was working, registering the handset to a different base (Base 2). And guess what, after 30 mins the "BASE 2" message started flashing on the faulty handset.
So, if you already have an A110 extension handset, make sure it's also registered to base 1 and maybe try to get just the handset repaired via VTECH. (or just buy a new handset if they are available).
Jun 21, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Tru9466 base and tru9465-2 handset
Same manual as lethean provided on a similar post but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Mar 10, 2008 | Uniden TCX905 Cordless Accessory Handset...
Connection between two phones
There might be two problem....1st of programming and 2nd one of internal hardware problem of your handset which is not working.
For the 1st option- Read manual carefully, there is security setting. Follow the steps with second one handset which is not responding.( I can assum that it is power on but not responding to signals..May i right?) After completing security process it will give long beep and will bond with other one and that is necessary for frequiency adjustment. This generally occures after removal of batteries.
For the 2nd option- There is crystal inside your handset which is resposible for generat stable and similar frequency as other handset. When that crystal lost its capacity it results in mismatching of frequency and occures in non connection results in no response from handset. This can be repaired by technician after getting part no of that crytal from your device and replace it with another one. But for this you have to visit technician with all of handsets and attachment as it is necessary to check it working properly after repair, even technician may also need it for setting frequency level.
Is it clears all doubt about this problem then say FIXYA......
Jan 09, 2008 | Siemens Gigaset 8800 Cordless Expansion...
Cell Phones Logo
14 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
