Question about Goodman CLQ24AR42 Air Conditioner
4 yr old goodman mod CLQ24-1B trips CB
When I reset the CB the fan turns slowly even when the the ac is off. As soon as I call for the AC to go on the CB trips. I replaced the capacitor and there was no change.
  • 6,826 Answers
The fan is most likely the problem,the windings in the fan motor are bad,replacement of the fan motor will solve this problem.
Posted on Jul 06, 2010
  • 1 more comment
  • hcolgan Jul 06, 2010
    In addition when I reset the CB and with the ac thermostat set to off the fan not only turns slowly the compressor repeatedly cycles momentarily. Is it possible there is a problem with the relay? when I set the thermostat for ac the CB trips
    I isolated the fan and compressor. The fan runs normally when the compressor is diconnected. When I disconnect the fan and reconnect the compressor, the compressor tries to start and the circuit breaker disconnects. What now? I have read of start assist capacitors, could this work. The temp here is 100 degrees, could that be contributing to the problem?
  • Ronny Bennett Sr.
    Ronny Bennett Sr. Jul 07, 2010
    If you have isolated it to the compressor,either the start capacitor ,or run capacitor for the compressor could be the problem,but do not be fooled,if the compressor is bad,it will pull too many amps,and throw the breaker,most newer models,have start,and run capacitors built together,all in one,do not know if your is or not,but most likely is,check the amp draw on the compressor,to see how many it is drawing,I strongly believe it is the problem.
5 ton goodman package unit
I guess this is a heat pump unit, check the change over valve in the gas circuit, sounds like the solenoid on the valve is burnt out
Mar 24, 2014 | Heating & Cooling
My goodman furnance will not bow out air only the fan works . what should i do
Check all the easy things first. Check that all the settings on the thermostat are correct for AC. Does the AC unit run? If not check the electrical panel breakers to see if the AC unit breaker is tripped. If it is tripped, reset it. If it continues to trip, call are reputable service company. There are little or no items for "do-it-yourself" unless you have the training and equipment to service AC. Good luck.
May 16, 2011 | Goodman CKL30AR30 Air Conditioner
Air conditioner just conked out;only 3 yrs old
Is the indoor unit operating? If no turn the fan from auto to on at thermostat. If the fan comes on, that is a sign that you have 24volts
present on thermostat side.
Turn AC unit off outside,turn the thermostat as low as it will go. Open the electrical panel to the outdoor unit. There is a contactor located in the unit, push the plastic bar in the middle of contactor. If it pushes
in, you have low voltage wiring problem from the outdoor unit to the
indoor unit.
If you are skilled or know somebody that is with electrical, turn the power back on to the outdoor unit take a non conductive object and
push the contactor in, the unit may start. If it doesnt start,check the
breaker for the ac unit to make sure it is not tripped.
If the breaker is not tripped and the condensor fan comes on and the
compressor does not come on and the breaker does not trip, then it
is very possible that you will need a new capacitor and while you are
at it put in a hard start kit.
This unit according to you, still should have 2 years left on the compressor warranty.
Jun 18, 2010 | Goodman CLQ36AR49 Air Conditioner
The fan or blower motor is not turning when I switch air conditioner on.
MY AC UNITE IS ARCHING OUT SIDE THE CURCUITE BREAKER IS TRIPPING OFF
May 20, 2010 | Goodman CKL36AR36 Air Conditioner
Last night the frigidare AC with breaker in line
if the breaker reset and the display lights are lit its not the cord sorry to say could be compressor or fan motors.
May 06, 2010 | Maytag M7Y12F2A Air Conditioner
2003 civic temps go up with ac on
Seems like the a/c radiator fan is not working. Either the fan itself is broken, or the power wires that drive it are not connected. The fan is tripped by a/c compressor activity, and goes through a relay unit, which actually trips the voltage that feed this particular fan. You can check fan activity with car parked, and turning on the a/c . if you cant recognize the louder noise of this fan, stick a straw into the fan to check if it is turning. Careful with fingers.
Apr 23, 2010 | 2005 Honda Civic
I have a goodman furnace and ac unit heat and fan work but soon as i flip the ac on it blows the 5amp fuse at the furnace
their is a control short some place check the control wiring . dog or rodents chewing threw it or shorted controls or thermostat id get service. Tom
Jun 24, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman CLQ24AR42 Air Conditioner Logo
102 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
