Question about HP Pavilion dv6000t 15.4" Notebook Laptop PC PC Notebook
Hp pavilion dv6000 multiple images horizontally and verticle lines throughout the screen.
  • aaronreed1 Jul 06, 2010
    It works find when i use a secondary monitor. I don't know much about the specifics of electronics but all the connectors and boards look fine. There is a wear spot on the elec cable for the monitor in the hinge area but the wires are so small and I am reluctant to pull the wrapping off in fear of breaking the wires. But I will probably check it tomorrow with the proper tools. I will also check to see if I cam barrow a friends lap top as a donor and see if his monitor works on mine. I will post the results.
    Scholar:
  • 36 Answers
Does the video problem occur when connected to an external monitor?
If it does then unfortunately the most likely cause is either:
1. Bad memory modules, try pulling memory chips and rotating between slots to see if any change. If necessary replace faulty memory modules.
2. there is a very large number of these HP/Compaq models that have serious problems with the Video BGA chip coming unseated from the mainboard over time.
This can be repaired by reflowing the BGA chip, but is an involved process, and not for a standard user.
Otherwise the mainboard will need to be replaced.
Posted on Jul 06, 2010
  • Michael Painter
    Michael Painter Jul 06, 2010
    I think you hit the nail on the head.
    The data cable for the screen is very fragile and gets mangled opening and closing.
    You can get a replacement screen data cable on eBay for about $7
    http://cgi.ebay.com/HP-dv6000-LCD-flex-v...
Dell 2300 MP Verticle lines distorted image
light engine or bulb is gettingbad ok how many hours on bulb fans clean ect thx nick
Feb 11, 2008 | Dell 2300MP Multimedia Projector
Jumping lines throughout the screen affecting quality of picture
You didn't say weather the lines are verticle or horizontal, but if the lines are verticle check the circuit for a weak capacitor or if the lines are check the horizontal circuit for a weak capacitor. During your check check for cold solder joints, idf you come across ant re-solder then. Good luck.
Jan 27, 2011 | Pioneer PRO-520HD 53" Rear Projection...
A thin horizontal black line has appeared just below the centre of the screen on my hp pavilion dv6000 (running vista), there is no change when i gently press the screen, so i think the problem isnt with...
As the symptom you indicated above it is the problem with your LCD Panel. It is to be replaced to sort out this issue. To check and confirm the functionality of your Laptop motherboard plz check the Laptop with external display.
Nov 25, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook: a thin verticl line across the screen...
it might be due to static on the notebook
turn off the notebook and then remove the battery from the notebook press and hold the power button on the notebook for 4-5 sec and then put the battery back and then turn on and check
if the line is still there check it in the safe mode or in BIOS if its still there then replace the screen
May 17, 2010 | HP Pavilion dv6000z Notebook
I have a HP Pavilion dv6000. I have to connect to
well what i normall do is go into the control pannel and go to nivida( or what ever your video card driver is ) and then i go to multiple screen set up and it will take you through the proccess and you use clone screen so it will show what ever your laptop has on it and not making it two screens
Mar 02, 2010 | HP Pavilion dv6000z Notebook
I have two verticle lines- one white and other one
The screen will likly need to be replaced. Try an external monitor on it, does it still have lines? if not then its the screen on laptop.
Feb 25, 2010 | HP Pavilion zd8000 Notebook
HP Pavilion ZD8000 vertical lines issue
In answer to your question. It may be a screen problem. as the screen has a Matrix of vertical and horizontal line configuration.
I,d suggest trying the laptop/computer on an external monitor or screen. if it works fine on an external. then it could be assumed that the TFT Panel or invertor has a fault.
if the picture/display still has vertical lines on an external monitor, then the fault may lie, with the Mainboard.
Process of elimination, before spending any Money :)
Mike @ compurepair.
Jun 09, 2008 | HP Pavilion zd8000 Notebook
Image issue
Sounds like the Inverter Board (a small circuit board which decodes the image to be displayed prior to displaying it) is faulty. This is NOT a user serviceable issue, it would need to be sent back to HP. If it's still under warranty they will send UPS to your door and pay all the shipping, if not get them to quote in advance. Either way, it's a problem you can't solve yourself.
May 28, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000t 15.4" Notebook Laptop PC PC Notebook Logo
280 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
