Question about Fisher and Paykel GWL11 Top Load Washer
Fault code 104 - Fisher and Paykel GWL11 Top Load Washer
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Unfortunately in my manual it says that error 104 is Comms. Error Time-out.This means that there is an error in the communications between the Display module and the Motor controller. Now to rectify this fault the manual says to 1st change the Display module, and if this doesn't rectify the fault change the Motor controller. And lastly if you have changed both these parts and it still faults the manual then says change the Rotor Position Sensor.There is no way to check which part is actually causing the fault and the recommended way to rectify this fault is to change parts until it works correctly.I am sorry for the bad news but on this fault you might have to obtain the service of a technician.Unless there is a place you could send the motor controller and display board and get them checked out for faults.I am in Australia and there are a few places here that do this service but maybe you could ring your local Fisher and Paykel agent and see if they know of anybody that could help you in your area.Please reply for further help and to tell us how you got on.
Posted on Jul 07, 2010
Fisher Paykel GWL10 fault code 104
your display or pump could at fault here.
measure resistance at pump,
if resistance in less than 33 ohms, replace your pump.
Check display plug for bent pins.
Feb 03, 2013 | Fisher and Paykel Washing Machines
How do u reset the fault codes on a 2007 r1
Hi, 23chris16 for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
OEM parts for Yamaha
http://www.lethaladrenalinrydaz.com/index.php/service-manuals/finish/3-service-manuals/6-2007-2008-yamaha-r1-service-manual/0
R1 diagnostic modes and codes
http://www.r1-forum.com/forums/104-04-06-r1-mechanical-help/324272-clearing-error-codes.html
Jul 05, 2012 | Yamaha YZF-R1 Motorcycles
What is code 89?
81. - 95. (0101xxxx) Phase 2 to 3 - Display/ Motor Controller.
See fault code 106
104. (01101000) Phase 2 to 6 See fault code 106
106. (01101010) Phase 2 to 3 - Display to Motor Controller module
Communications Errors (Phase 6 IW also)
These faults are reported when the Display module detects an error in the
communications between the Display module and the Motor Controller module.
Primary Source: Display module.
Action:
Replace Display module.
Secondary Source: Motor Controller module.
Action:
Replace Motor Controller module. If the new Motor Controller module corrects the fault, refit the original Display module.
Feb 18, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fix code 104
104. (01101000) See Fault Code 106
106. (01101010) Display Module to Motor Control Module Communications Error
These faults are reported when the Display Module detects an error in the communications
between the Display Module and the Motor Control Module.
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
Jan 24, 2012 | Fisher and Paykel GWL11 Top Load Washer
90 104 on bmw x5 4.4i sport
90 is an 'Intermittent System Down' code, meaning the system isn't always staying online.
104 should be a right-rear (passenger) wheel speed sensor failure. If a sensor fails the system shuts itself down, so this is likely what's causing the first code.
How did you test your ABS sensors? They normally should be checked for resistance to be within specifications and they also need to have the waveform checked on a graphing meter or have one person check the sensor signals with an appropriate scan tool while another person is driving.
Also check the tone ring (notched ring the sensor reads) for broken/missing teeth and check the wheel bearing for play, as both of these can disrupt the readings, even if the sensor itself is good.
Hope this was helpful to you.
Jeff
Oct 19, 2011 | Cars & Trucks
My bluetooth is asking for a code for the nokia bh-104 what is the code
Hi, to connect nokia bh-104, you will have to use the default code which four zero's "0000" and your done ...
Have a nice day...
Feb 23, 2011 | Nokia BH-104 Bluetooth Headset
Trouble code of #104
From past experience it is a motor controller fault(Main PCB)
If pump running all the time PCB is sending power to pump continously
Part 426204p About $200.00 AU $216NZ
Please rate our help to keep the FREE saervice online++++Thanks for using FIXYA
Sep 17, 2009 | Fisher and Paykel (IWL12)
Recovery code 104 appears on my archos 605 wifi 4gb
recovery code 102 and 104 appear in archos screen. it doesn't work.
Jun 07, 2009 | Archos 605 Wifi Portable Multimedia Player
Code 104
Recovert code 104
would you like to recover your system?
NO
Repair disk
Format disk
P.S. pressed the OK button on the device and its telling me to
connectto your divise to my PC and install an update file DONE
then the devise reapear back to recovery code 104
Jan 14, 2009 | Archos 405 Digital Media Player
Fisher and Paykel GWL11 Top Load Washer Logo
200 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
