Question about Vacuums
No vacuum suction - Vacuums
  • 2 more comments
  • froggy81385 Nov 30, 2008
    And if its not clogged?
  • rug_rookie Dec 19, 2008
    My Sharp EC-TU5907 lost it's suction.  It doesn't pick anything up, the powerhead just moves it around.  Air is going through, it doesn't seem to be clogged.  What's going on and how do you fix that?  Thank you.
  • Anonymous Dec 21, 2008
    I have a Royal 7050; no suction through hoses, but inside motor is creating suction.
  • Anonymous Jan 03, 2009
    I've come to the conclusion that your product is a poor product. Two hundred plus dollars down the drain...never again Bissell!
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Generic problem for all Vacuums
No vacuum suction
No vacuum suction
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I am not sure what type of vacuum you have but it sounds to me that if you have a vacuum with a hose (called a powerteam, or canister with a powerhead) the vacuum hose could be clogged , the filter could be dirty, or the bag is too full – run a marble or steel ball thru the hose to see if there is any blockage, by doing that you can tell where the clog is, if there is use the wire coat hanger – straighten it out and bend the end of the hanger upwards to create a little hook and by doing that you can remove the clog if the ball does not go thru the hose all the way, please be careful if you have a vinyl hose, you could poke a hole in the hose and then you would need a hose sleeve over that spot to stop it from leaking, if it is an upright the same rules would apply to the hose, bag and filter or dirt cup filter .
Posted on Apr 18, 2008
Suction when vacuuming
Some vacuums have a valve or collar near the handle that you can twist to adjust the amount of suction on the vacuum. If you open it a little it will stop sucking up your throw rugs. IF the problem is not enough vacuum then the HEPA filter may be clogged. It's usually a rectangular filter in a plastic frame. That has to be changed occasionally or the suction of the vacuum will continue to drop off.
Apr 04, 2015 | Vacuums
Why does the suction stop after 10 minutes of use on my Dyson DC43?
Your vacuum may be overheating and shutting off the suction motor. Clean the cyclone assembly and the filters to see if they could be restricting the airflow.
Jun 18, 2014 | Dyson DC43 Purple Animal Bagless Upright...
Suction stops when vacuuming with the DC40 model
There may be a clog where the air flows from the brush roll into the vacuum
Jan 29, 2014 | Dyson DC40 Multi-floor Vacuum DC40
What do to if keeps spitting things out even if new bag is in?
It sounds like the roller brush is going, but the vacuum isn't working, i.e., no suction.
If you have a canister vacuum, disconnect wands from hose and place hand at end of hose. If there is suction, it's fine. If not, disconnect hose from vacuum, turn on vacuum, and hold hand to intake. If there's suction here, then the hose must be clogged; or holey hose can result in greatly reduced suction.
If it's an upright, the hose could be clogged. Or the fan broken, which would also result in no suction. It would help to know what model you have.
Oct 21, 2010 | Oreck Vacuums
No suction for Kenmore upright vacuum
You have not stated which model vacuum you have. Bipass vacuum have a bipass compartment which is under drive unit. Make sure there are no cracks around housing as this is where you vacuume is created. In order to have vacuum you must have airflow, in assences suction. No air flow, no suction. If the airflow is deverted somehow suction will stop. Your filter, your bag are all sources of air flow. Clog either and you lose suction. Start with loss of air, being cracks in housing,bag or filter
Feb 23, 2010 | Kenmore Vacuums
Bad suction on bissell powerforce bagless vacuum
I took the bottom apart and it needed a new belt and that was the problem so it's fixed.
Jan 16, 2009 | Bissell 6594 PowerForce Bagless Upright...
Vacuums Logo
606 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
