Question about Whirlpool GHW9100L Front Load Washer
Duet front load washer about 10 years old alarms hf in every cycle. If wait a few minutes can restart the load this may happen just once a load but generally occurs 3-4 times through out load always within minutes of starting.
    Problem Solver:
  • 17 Answers
Try to replace water pressure valve switch and flow meter. If not OK then replace main circuit board.
Good luck.
Posted on Aug 06, 2010
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Duet GHW9150P Front Load Washer: I put my machine on pause and now I can't restart....
Press "end of cycle" for 3 seconds, wait for 2 minutes, try door. Shut door and restart your cycle. If door still does not open - repeat 'end of cycle' press for another 3 seconds.
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL GHW9150PW4 DUET WASHER DOESN'T SPIN AFTER START
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Mar 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
How long should a normal wash cycle take on the whirlpool duet?
One hour and 10 minutes is normal for your washer. All front load washers take a long time. They wash a lot better than top loaders. So to answer your question.. yes its normal.
Nov 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
HF alarm
1st ck all hoses and screens for blockage be sure you have good water flow to washer next remove top ck flow meter left side 2 small hoses 1 in one out may be able to tap it on the side and temporaily correct problem best bet is to replace it
Oct 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite
Peace Friend,
ngafm At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Sep 03, 2008 | Kenmore Elite 45986 Front Load Washer
Washer stopped during cycle
cleanlaundry If your washer is less then a year old do nothing and call the manufacturer ASAP. It is under warranty for one year. Gendos...post back
Mar 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9100L Front Load Washer Logo
55 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
