Question about Bosch Nexxt 300 Series WFMC2201UC
Washing E-13 comes up - Bosch Nexxt 300 Series WFMC2201UC
  • Bosch Expert
  • 414 Answers
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc.
Good Luck.
Posted on Jul 08, 2010
We have Ipso front loader washing machines. One of them works perfectly EMPTY but as soon as you put washing in it, it comes up with error Ed23. The drum spins a few times at 30 minutes, then water comes...
The link shown by searching using https://www.google.com
gives a possible solution.
http://www.coinlaundry.org/openforumlink/community-home/viewthread?GroupId=43&MID=18083&tab=digestviewer&CommunityKey=e3a9040e-d397-423e-8e4f-20e8bb27defa
Quoting:
"Posted 02-10-2016 13:34 Edited by Chris M 02-10-2016 13:40
Reply to DiscussionOptions Dropdown
You need the deflector. It should be under warranty through your distributor. All I get now is the occasional baby sock.
Kit 806308 or 806313 depending on your model."
Other discussion blamed user errors.
Jul 05, 2018 | Washing Machines
Tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/13 error code on...
The error F/13 is shown on the display due to Dispenser Circuit Error detected in the washing machine.
In this problem check the dispenser motor .Either is blocked or its not running in proper direction.
This will Help.Good Luck.
on Mar 11, 2010 | Washing Machines
V4380X0GB/13
Try Googling (Neff)(V4380X0GB/13)(manual) without parens or contact Neff directly to request the manual.
Jun 07, 2017 | Neff Washing Machines
Hitachi sf-6500px error
Possible error on the program due to a memory issue. After resetting, if the machine has the same fault with all the selected programs, then it is possible that the motherboard is faulty. Please check the INLET flow to be good and the drain pump to be clear.
Jun 25, 2013 | Washing Machines
Samsung washer gets clothes dirty
Put a whole house water filter on the cold side of the inlet water. I bet you have well water with lime in it??? Wash your clothes only in cold water. Rub a couple of empty loads with clorox, lime away, oxy clean to remove any build up in your washer
Oct 21, 2012 | Samsung WA5471AB 27" Top-Load Washer, 4.7...
My HOTPOINT Aquarius + super silent will not tumble dry. it starts off OK but then comes up with Error code F-13 can you tell me what this means
Hello
F 13 is a fault code for water supply,inlet valve or hose connections.
You may try unplugging the machine and plugging back in to reset.
Mar 31, 2011 | Hotpoint Aquarius WD640 Front Load...
Where can i get a manual for electrolux ewf1083 front loader washing machine
You can download one from here:http://userguides.50webs.com/
They carry every electrolux manual ever produced.
May 14, 2010 | Washing Machines
Washing machine is not completing it's wash cycle
either you have a blocked hose to the pump or the pump itself is either jammed or the impellor has come off the shaft. either way i think you will need to replace the pump. i presume you managed to get the water out? if so i would say the pump is favourite.
Mar 16, 2009 | Ariston Technologies AWD120 13 lb. Washer...
Error code F 13
f-13 is heating element or thermostat.
remove plastic panel at bottom back, look for black marks in line with the heating element at bottom middle of drum.
part number: 1604486 may fix your problem
Mar 24, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Bosch Nexxt 300 Series WFMC2201UC Logo
650 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
