Asl light blilnks and i get error message saying low or no connectivity
  • 146 Answers
This error occurs when your ISP 's(Internet Service Provider) server is partly down or either way. Or it might occur when the DSL wire got any loose connection or cut. Try checking the DSL cable and if still the problem exists, complaint your ISP to check on their side. Thank You.
Posted on Jul 06, 2010
The ASL light is on in my 2005 Volkswagen Passat. What could be the problem?
Does yours have an automatic gearbox? ASL refers to the Auto Select Lever. You need to take the car to a gearbox specialist. There is a switch on auto boxes that prevents an it from going into gear if the brake pedal is NOT pressed. This switch could be faulty. Get it checked anyway as it could jump into or out of gear accidentally.
Apr 24, 2018 | Volkswagen Passat Cars & Trucks
Hp d135 all in one printer error message says "turn off and on" and all lights blinking fast
it's almost the (data cable) connected the carriage- it maybe damaged or not connected well.
Nov 29, 2012 | HP OfficeJet D135 All-In-One InkJet...
I have just had an orange light come on saying ASL.What does this mean
This is the automatic speed limiter in newer Jaguars. It is a feature used by the driver to prevent exceeding a set speed. Once the feature is turned on using the ASL button, the actual speed at which the feature will limit you and prevent any further acceleration is set using the cruise control rockers.
Jul 26, 2011 | Jaguar XF Cars & Trucks
I get a fault light that says "cruise not available" If I hit the ASL (automatic Speed Limiter), I get the message "Limiter not Available. The problem is intermittent and occurrs about 25% of the time....
This vehicle uses modules which have a radio controled signal passed to them from the ECU,by a wire ,5 wires in all ,12v perm 12v ign earth and two bus lines ,sorry its a dealer only job
Oct 17, 2009 | 2006 Jaguar XJ8
Check Engine Light- ASL and Crusie Control (Limiter) Not Availabl
A wild guess - your crank speed sensor. But, with this level of malfunction, pull the codes. Buy a code reader (EOBD/OBD) from Ebay or go to a Jaguar dealer or any decent engine diagnostic center and they will tell you what is malfunctioning. The codes don't tell all the story, they just tell you what is out of tolerance - there could be a lot of things out just because one component is malfunctioning, so you need someone who has expertise with this engine.
Jul 23, 2009 | 2004 Jaguar XK8
"Cruise Not Available" & "Check Rear Lights" flash from message c
Hi Don
I recomend you try this first of all.
Try disconnecting the positive battery + & negative - terminals.
Turn the ignition key several times to erase the computers memory.
Reconect the battery + terminal and then - and start the car.
Your fault code, will hopefully not return.
Good Luck !
John.
Jan 19, 2009 | 2005 Jaguar XKR
Printer refuses to print anything
Rerun the CD that came with the printer.
Jan 11, 2008 | Epson CX4200 All-In-One PSC Printer
Computers & Internet Logo
David Payne
David Payne
