Question about Goodman GPH1324H21A WallWindow Air Conditioner
TWC SERIES 10 SEER goodman model TWC24-1/-1B not cooling no leaks detected, caps replaced, circuit breaker trips when it's really hot outside
watugot
  • 290 Answers
SOURCE: Ruud heat pump outside unit trips circuit breaker
Check your wiring between the contactor and compressor for a short to ground, or check the compressor windings for short to ground.
With the Tstat off, the contactor should be open so the only way for the compressor to be trying to do anything is if the 110 volts from the unbroken side are traveling through the compressor to ground. Since 110v is not enough to run it, the overload is kicking it out, cooling off, and repeating the cycle. When you kick on the Tstat, the contactor is supplying voltage directly to ground without going through the resistence of the compressor windings and kicking the breaker.
Post back and let me know what you find.
Posted on Nov 20, 2007
TJBENGR
  • 121 Answers
SOURCE: my ac circuit breaker keep tripping
If your outside condenser has a locked rotor or short circuit, than the unit WILL trip the breaker - as it should. On the other hand if a breaker is tripped a few times it will have less of a capacity that the rating, (this is designed in it). You will need to determine if the unit is locked (and broken) or the breaker has become too sensitive.
Posted on Apr 22, 2008
koolbreezes
  • 540 Answers
SOURCE: AC breaker trips after 10 minutes
Whats the amp breaker? Is this for the inside unit or the outside condenser? If the inside and gas heat you have a bad fan motor, If its an electric furnace , the same, but if its the outside unit, the fan could be going bad, locking up and the compressor still runs and pulls high ampsand tripps breaker or the compressor is just pulling too many amps due to plugged coils with dirt , grass or weeds blocking airflow.(koolbreezes74401@yahoo.com)
Posted on Jun 09, 2008
Bat1956
  • 585 Answers
SOURCE: The circuit breaker trips every time I turn the
You need to start with a basic inspection in the outside unit. For the breaker to trip immediately like that indicates a dead short. With the breaker OFF look at the internal wiring between the contactor relay and the compressor. You are looking for signs that the insulation may have been chewed by a rodent, or a wire is off of a terminal and in contact where it shouldn't be. If the wiring looks good, terminals pass tug test etc. you may have a shorted capacitor. Make sure to check the wiring for the fan too. You can disconnect the com lead for the compressor and fan one at a time to isolate the defective component if needed. Work safe! turn the breaker on for the test, and off again before you put your hand or tools back in.
Posted on Jul 17, 2009
co7196
  • 3433 Answers
SOURCE: Goodman Air (outside unit)
was there any refrigerant loss? "bumping" that results in movng usualy causes a leak.If the system is totally empty, It shouldn't start.. If it did major oh nos! will appear. Does it not start all? and was it running when it got thumped? May have to call a tech out on it. Sorry.
Posted on Jul 29, 2009
Lights blinking
The best information you could get is from Carrier. Here's their website:
http://www.carrier.com/homecomfort/en/us/for-owners/
There is a toll free number to call 1-800-Carrier (1-800-227-7437)
Apr 27, 2014 | Carrier Performance 2 Stage 17 Series 2.0...
Ruud achiever 10 seer breaker keeps tripping
Sounds like a short to ground problem with either the motor windings shorting to ground or a high voltage wire shorting.
Nov 25, 2012 | Ruud Matching Split Air Conditioner
Hello, i have a 3 ton 10 seer goodman condensor. It is blowing the circuit breakers, sparks came from breaker box, unit is 11 years old. Can you help?
If you had sparks in your breaker box then you need to call an electrician to look into that. If the a/c is blowing the breaker you may have a shorted compressor and will have to replace it or the whole condensing unit, depends on the price of the compressor vs a new condenser.
Jun 18, 2011 | Goodman CLQ36AR49 Air Conditioner
Goodman a/c unit outside not coming on. buzzing
Sounds like compressor is bad...taken out by a bad contactor.
Aug 17, 2009 | Heating & Cooling
What is the SEER rating on Goodman Air Handler model a32-05c?
Slightly more than 10 seer . Depending on the outside unit. A30 are 10 seer. Rusty
Jun 07, 2009 | Heating & Cooling
579 series, 13.5K BTU Rooftop trips AC circuit breaker in hot weather...
Is your condensing unit located in a well ventilated area and have an ample space, atleast a foot, from the rooftop flooring? Just make a check that free flowing outside air properly ventilates the condensing unit specially on high ambient temperatures. Hope this would solve your problem
Sep 16, 2008 | Dometic Rooftop RV Air Conditioner
Jun 08, 2008 | Goodman CLQ36AR49 Air Conditioner
Open Questions:
See all Goodman GPH1324H21A WallWindow Air Conditioner Questions
Goodman GPH1324H21A WallWindow Air Conditioner Logo
364 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
