Question about Abit IG-80 Motherboard
Can I put a hard disk serial ATA II to the motherboard ABIT IG 80?
    Novelist:
    Champion:
  • 226 Answers
Yes, full spec can be found here: http://reviews.cnet.com/motherboards/abit-ig-80-motherboard/4507-3049_7-31139653.html?tag=psum;seeFSpec
Hope this helps,
www.PuterCare.com
Posted on Jul 06, 2010
My cd burner does not recognize a blank disk to burn. It keeps asking me to insert a blank disk even though I had just put a new blank disc in.
Are you putting the type of CD's it accepts?
Many burners will only accept specific disk types, such as most won't accept RW. That could be the possible issue in this case, what kind of burner are you using? If you post the model I could tell you what kind of disks it accepts.
Feb 24, 2013 | Hitachi Deskstar 7K80 HDS728080PLA380 80GB...
Will gtx 550 ti work with ig-80
Dear,
did you disabled the on board vga card then it will work and plug the vga cable on the card. It might be possible you, by mistake, put the connector in the onboard VGA connector.
best of luck!
Apr 17, 2012 | Abit IG-80 Motherboard
Max size hard disk for d915gav
The motherboard supports the following
HDD Four Serial ATA; One IDE (ATA 100/66/33)
So any Serial IDE/ATA hd would be ok so long has the max speed is 100
Apr 03, 2012 | Intel Motherboard
I went to the setup menu and set the bus frequence from 133 to 200 and tried to run windows. windows didnt boot up. then i removed the battery from the abit ig-80 motherboard and set the bios to default....
Abit Support > Main page for the Abit IG-80 motherboard. Click on Manual in the list to the right, the on the next page click on the country nearest yours,
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?fMTYPE=LGA775&pMODEL_NAME=IG-80
In the small window that comes up, (Opening ig-80_series.zip), click on the circle to the left of Save file, if there is No green dot in the circle.
Then click on OK.
In the small window that comes up on the left, observe what is stated in the top of the window.
This is where the ZIP file will download to.
It may be Desktop, My Documents, (Documents for Vista), or Downloads.
Desktop is your desktop screen.
My Documents - Start > My Documents
Downloads - Start > My Documents > Double-click on Downloads
When you see the file name, (Yellow folder with a zipper on it, and ig-80_series, next to the folder),
double-click on the file name.
Go to the upper left of the screen, and click on Extract all files.
Now click on Next, Next, and Finish
Double-click on the file name > IG-80_Series_Eng_V101
In the motherboard manual, reduce the view size to 125 or 100 percent. Use the Zoom Out icon at the top of the PDF file. (Circle with a Minus sign in it { - }
Page Number box for the PDF file is at the top of the PDF file to the right of the blue Down Arrow.
Go to Page 15.
CMOS Memory Clearing Header
Observe the warning, computer off, AND unplugged from power.
Go to Page 27.
BIOS Setup
Set the FSB frequency back to 133, don't forget to save changes.
Regards,
joecoolvette
Dec 19, 2010 | Abit IG-80 Motherboard
I have a abit 1c7g motherboard intel 3.2ghz processor twin western digital raptors sata raid 0 config ... 1 sony dru 710a on ide 1 (slave) trying to install plextor 880sa dvd burner having conflict with...
Suggest you connect the plextor to the SATA port 3 and set it's jumper to Master. All SATA drives are seen as Master drives. (Check the serial number on your WD SATA drive "Primary".
Enter the bios menu. Within page 3-7 section 3-3 Advanced bios features. Check, 1st, 2nd and third boot devices.
Floppy disk drive as, 1st boot device. 2nd boot device, "Primary WD SATA port 1". 3rd boot device, CD-ROM drive SATA port 2, Plextor 880sa drive". Save and exit the bios. If you no longer have you're manual you can download it from the link provided below;
http://ftp.abit.com.tw/pub/download/fae/ic7-g_eng_v101.pdf
Check page 3-13. See OnChip serial ATA Mode. As noted, the RAID option is available when the item "OnChip serial ATA" is set as [Enhanced Mode].
Cheers'
Mike
Jun 27, 2010 | Abit IC7-G Motherboard
500gb hard disk supported by intel D101GGC
Hey ROY_GV,
This D101GGC Motherboard supports both IDE and SATA.
Regards,
InfDev
Mar 05, 2010 | Intel D101GGC Motherboard
I have installed windows 7. But the driver for onboard Family Lan do not exists. And there I can not find any to the motherboard Abit IG-80. What to do??
try to download this file.. this is the list of your motherboard drives
here's the link
http://driverscollection.com/?file_cid=404945219255edcda3dd4101ea9
http://www.driversbay.com/drivers/bios-motherboards/abit/ig-80/microsoft-windows-vista/
Jan 17, 2010 | Abit IG-80 Motherboard
Hard Disk Problem
it seems as serious disk drive error to try fixing any errors that may be present on drive please run from command prompt [as admin] cd /D <faulty drive letter> then chkdsk /r if asks to unmount <or scan after reboot if it is sys disk> say Yes <lonely Y also does the job> this should fix the trouble, if not please send message
Oct 09, 2009 | Computers & Internet
Mobo doesn't recognize hdd
Your board shows serial ATA compatibility, I'm pretty sure the Seagate 1.5TB HDD is a serial ATA II device. These are not backwards compatible. Sorry. Hope this helps.
Dec 23, 2008 | Abit VT7 (MBABITVT7) Motherboard
Difference between ata and sata hard disks
ATA, or (PATA) hard drives use the older "seatbelt" 40 or 80 pin ribbon interface cable, whereas SATA is fairly new using the small, thin interface cable found in most computers manafactured in the last 12-18 months, hope it helps
Feb 18, 2008 | Highpoint Technologies 1 Bay e.SATA...
Abit IG-80 Motherboard Logo
41 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
