Question about Adobe PageMaker 7.0 Classroom in a Book (201756250)
How to put visarga in pagemaker - Adobe PageMaker 7.0 Classroom in a Book (201756250)
Hi, i need ADOBE ACROBAT DISTILLER for Pagemaker 7
There is a version of Adobe Acrobat Distiller included with your PageMaker installation disks. Put your installation disk in your CD drive and follow the prompts to install the distiller program.
Oct 11, 2009 | Adobe Acrobat Distiller 6.0 Full Version ...
Aldus pagemaker 5.0
Fixya does not give free licenses. You will have to purchase for a genuine license for your own use. Acquiring a free Adobe Pagemaker license would mean software piracy and is punishable by law.
Sep 23, 2009 | Adobe PageMaker V7.0.2 for PC
Pagemaker spell checking problem
Pagemaker 7 will not readily allow Spell checking under Windows 7. To do this you will need to run the Pagemaker application as the Administrator. This can either be by clicking on the right hand mouse botton (right handed persons) while the cursor is on the Pagemaker launch icon either on the desktop, Windows Start up menu or Application Program launch menu and then choosing to run the Application as Administrator. Pagemake launched like this will normally allow spell checking, without  the Pagemaker application will return distionary missing or does not support spelling.
Disabling account control in Windows 7 before running the Pagemaker, which I do not recommend also achieves this in Windows 7. All the above applies for Windows Vista too!
May 06, 2009 | Adobe PageMaker 7.0 for PC
Want to get back adobe pagemaker 7.0 which got uninstalled
If you had original version, you can check it out with Adobe. But this is illegal. you can find the link to download full version of pagemaker @ www.allyoulike.com and search pagemaker.
Jan 21, 2009 | Adobe PageMaker 7.0 for PC
How to convert Adobe pagemaker 7 to indesign cs3?
Pagemaker to InDesign is not an exact process. You are going to have to put some work into the converted file. The important thing to maintain in PageMaker to make a clean transition, is to make sure the PM file is PRISTINE. All the links in the Links Palette are current, al fonts for the file are loaded. Delete any unused colors, just clean the file up. The more clean the file, the cleaner the transition.
No matter how clean the file is, there are going to be things you are going to HAVE to fix. You are going from an app that has not been supported for over a decade into the latest and greatest, InDesign. Be patient and be glad at least you can get the PM file into something usable instead of having to rebuild it entirely.
Hope this helps.
Dec 27, 2008 | Adobe PageMaker 7.0.2 for PC
Translate a pagemaker file into indesign
This is from Adobe InDesign (CS3) Help module:
Convert PageMaker documents InDesign can convert document and template files from Adobe PageMaker 6.0 and later. When you open a PageMaker file, InDesign converts the original file information to native InDesign information. InDesign files are saved with an .indd filename extension.
For more information, see the PageMaker Conversion Guide (PDF) at www.adobe.com/go/learn_pmconv. Before opening the document in InDesign, you may want to do the following:
  • If the PageMaker file or its linked graphics are located on a network server, floppy disk, or removable drive, it may not open as expected if an interruption in data transfer occurs. To prevent data transfer problems, copy documents and their links to the hard disk, preferably in the same folder where the PageMaker publication is stored, before opening them in InDesign.
  • You may want to use Save As in PageMaker to clear unnecessary hidden data.
  • To ensure that all links are maintained, copy all linked files to the same folder where the PageMaker publication is stored.
  • Make sure that all necessary fonts are available in InDesign.
  • Repair broken graphics links in the PageMaker publication.
  • If you have a problem converting a large PageMaker document, convert portions of the PageMaker file separately to isolate the problem.
If you cannot open a corrupt PageMaker document in PageMaker, try opening it in InDesign. InDesign can recover most documents that PageMaker cannot open.
Oct 29, 2008 | Adobe InDesign CS2 for PC
File conversion problem
pagemaker file to create pdf formate
Nov 17, 2007 | Adobe PageMaker 7.0 Classroom in a Book...
Paper margin problem in pagemaker application
Do you mean the left margin is too large so all the content is shifted to the right and off the page? If this is the case, it is probably a setting in Pagemaker. In the file menu, choose "page setup" or "print setup". Check the paper size. Check the margins.
Jun 24, 2006 | HP Color LaserJet 2600n Printer
Adobe PageMaker 7.0 Classroom in a Book (201756250) Logo
35 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
