Question about Kroy K 4350 Printer
My new K4350 does not print. Err light comes on each time I try to print using excel even with old programing .
3 Suggested Answers
Donz Responz
  • 15 Answers
SOURCE: Kroy K4350 Gap Sensor Problems
Your problem is too complex to solve in one pass on this or any other forum. Give me a call at 800-304-9043 and I'll walk you thru it. I'm Don from Hanover Technical Sales. www.EmpowerCompany.com hanover@visi.net
Posted on Apr 24, 2009
n25an
  • 622 Answers
SOURCE: when I print from excel the page comes out blank
ok... here are some general tips... in your print driver make sure that it is set to spool documents... it gathers everything and then prints... make sure the print driver isn't shared from a server... servers are famous for distorting excel printer communication.... it isn't the konica... its a print driver excel conflict...
Posted on Mar 14, 2010
Printer almost always refuses to print Landscape from Excel. It prints Landscape or Portrait from other software, but balks with Excel in Landscape. It prints a portion (the information at the left) in...
Try printing to a different printer if possible. This may shed some light on whether the problem is with the printer or with Excel. You could also open the file on a completely different PC and printer to see if something is corrupt in the file. Also try creating a completely new document to see if it will print in landscape. Can you print in landscape orientation from MS Word or another program?
Jul 18, 2011 | Office Equipment & Supplies
Each time I print from Exel the printer gives me 2 pages for every one page even when Excel says 1 of 1 I will get 2 copies.
Hi
Set up again new printer and set it as default printer. Delete the old printer icon and try to print again.
It will solve your problem by this. Regards
Feb 21, 2011 | HP LaserJet 1320 Printer
Apr 15, 2009 | Kroy K 4350 Printer
Every time I try to print the dreaded yellow error box comes up.
Are you using the "same" printer with your 2 PC? or 2 different printers?
If you're using the same printer, check your cables, power supply, drivers, inks, and lifetime of the printer.
If your using 2 different printer you might have a virus in you pc.
Apr 06, 2009 | Computers & Internet
Samsung CLP-500 output problems
i have found that removing the toners, and shaking them side to side, while keeping them horizontal, which seems to spread the toner for even distribution. This can sometimes fix the problems with fading prints. hope it helps.
Margins i think might be a problem with the wysiwyg of the program, some don't do it well, but also excel in particular has a shrink to fit page option, you may find the percentage not at 100%. you can also copy an excel table to word and print from that if it is driving you nuts.
Jan 23, 2009 | Samsung CLP-500 Laser Printer
1994 lexus ls 400, cd player
Hello I just purchased a 1991 Lexus LS400
I have one of those 6 cd changers and got "err" when I started up the CD.
Here is what I tried and the result
1. I took out the CD,s replaced with new ones and it played but only for a bit, then even the new CD's got the err message
2. I then though maybe dust and/ or dirt so I took out the 6 pack of CD's and blasted compressed air into the unit from a can of computer cleaner compressed air. Lost the err message but then came back
3. Read a few other ideas on the problem and then tried the old hair dryer trick. (I am a long term live a board boater and have brought back may mis-behaving electronic devices that have moisture issues with the hair drier) However the hair drier did not do away with the err message.
4. two more boating tricks I thought of... I wiped down each leaf of the CD pack with rubbing alcohol
and actually got a good deal of dirt off the plastic, finally and probably the solution I sprayed some "wire dryer" a light spray then a mist.( Wire dryer made by Gunk is a spray can of a liguid we used all the time to get cars started in the cold weather, even got a better connection by spraying on battery wires to get the sailboat diesel started with an almost dead battery.)
I Waited a few minutes put back the cd holder and it worked.
It has been about 6 hours and it is still running like a champ.
could have been the combination or just the wire dryer...not very scientific maybe it will help
Jan 12, 2009 | 1993 Lexus Ls 400
Distortation of engineering drawing in Ms Excel
I am assuming that the reason you are using Excel is because of the gridlines. An "engineering drawing" done in Excel would break when rotated especially the angular lines. The reason is Excel does not have the necessary engine to display (render) such drawings. By Excel alone, there is no way out of this problem.
However, there is a workaround. After making the drawing, before rotating it, do a Print Preview. Open an image manipulation program, even a simple one such as PaintShop Pro. Capture the image on the Print Preview. Open another Excel sheet, copy and paste the image from the image manipulation program to the Excel sheet.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 16, 2008 | Dell Dimension 3000 PC Desktop
Problems with printer settings
Interesting. I tried printing a simple 3-page Excel spreadsheet sent my by a colleague to my 8500DN from Microsoft's Excel Viewer and got a timeout error formatted as follows:
ERROR: timeout
OFFENDING COMMAND: timeout
STACK:
42
-mark-
(84,160)
No idea what this means, but resetting the network parameters (even though I use USB connection) from the printer's front panel cleared the problem. The printer would print nothing else from any program until I performed this reset. Wonder if Excel futzes with settings and printing somehow?
Oct 14, 2008 | Xerox Phaser 8500/DN Printer
Can't print to old applications
The issue your having is with the Operating system compatability. The HP 3055 is compatible with 98, ME, XP, Window 2000 and forward. It won't do windows 3.1 or 95 well even if your computer will, the disconnect comes when the software is sending old print commands to a new style print driver.
Your best hope is to download and install the HP Printdriver for Windows 98 and try it as it's the most tolerant of old gear. Download the PCL 5 as the PCL6 is too new and probably not going to work.
As an alternate try to download each of the printdrivers for the differnt era windows and try them. It's a hard problem that may not have a solution other than upgrading the accounting software.
If it's simply a connection problem, they do make a USB to Parallel addaptor which may help you with the physical connection issue.
Here's a link:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1140780&taskId=135&prodTypeId=18972&prodSeriesId=1161389&submit.y=4&submit.x=3&lang=en&cc=us
Hope that helps you.
Aug 24, 2008 | HP LaserJet 3055 All-In-One Printer
Need help with Kroy K4350 Printer.
This sounds like a hot pixel failure on the print head. The hot pixels are not repairable. The entire head will have to be replaced, most likely, at a cost of about $300. Hanover Technical Sales, Inc. (that's us) does Technical Support for Kroy printers, so we know what we're talking about.
Could it be something else? Sure, but without a pic of the issue, we'd not be able to guess what else it might be.
Make sure that heat shrink tube is clean and free of static electricity. When possible, use Kroy brand tube in the K4350. And we have a new hybrid ribbon that minimizes static at the head ... and consequently minimizes hot pixel issues.
Dec 12, 2007 | Kroy K 4350 Printer
54 people viewed this question
Top Kroy Office Equipment & Supplies Experts
Donz Responz
Donz Responz
Level 1 Expert
Norman  J Weimar Jr
Norman J Weimar Jr
Tom Chichester
Are you a Kroy Office Equipment and Supply Expert? Answer questions, earn points and help others
