Question about Hamilton Beach BrewStation 47214 Coffee Maker
When you go to get coffee it will leak, and you will also get grounds in your coffee. The rubber gasket is replaced and still happens. Is it possible the little needle valve that the gasket goes around is damaged.
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 17, 2010
Keurig leaking from bottom
Check the Upper Rubber Gasket (fits around the top puncture pin). If it missing you will have leakage because here's no seal to protect leakage. You can buy it online or call Keurig Customer Service (if you still have warranty)
OR:
Upper Rubber Gasket not making a seal with the K-Cup or Reusable Filter and the water and/or coffee grounds leak out. To fix it simply move Upper Rubber Gasket 1/4" down. This should close the gap between K-Cup and upper needle.
Oct 07, 2013 | Coffee Makers & Espresso Machines
My Krups XP4000 coffee machine gasket split. I have descaled the machine and replaced the gasket but water still sprays out of the side of the head and occasionally blows past the gasket. I replaced the...
I had the same problem .... My gasket split and I replaced it and water was still leaking past the gasket... Try this - Don't tighten the screen screw all the way...I have mine set at about 6 turns counterclockwise from fully tightened. Loosen the screen screw more if needed until the leaking stops... As a result, the gasket will sit lower and make a better seal with the portafilter lip.
Feb 17, 2011 | Krups XP 4000 Espresso Machine
My Moka Easy Bialetti electric espresso maker switches off before all the water has been percolated through into the upper pot. I have recently replaced the rubber seal etc. at the base of the pot.
I emailed support at Bialetti and here is what I got:
Check the coffee funnel for any dents around the edge of the funnel. Normally if this brewing problem happens after changing a gasket the problem is a dent or the funnel is out of round and the new gasket isn't formed to it like the old gasket was. Don't bang the funnel to get grounds out or it may dent or get out of round. Try pulling the funnel over to one side in the water chamber and if you see a space on one side pull it tight with the other finger to bend back into shape if possible or replace the part.
Take the gasket and filter plate out from under the upper unit and hold the filter plate up to the light to check for any clogs right in the center where the coffee brews up. You should be able to see through all the holes in the filter, brush clean if needed
Jan 13, 2011 | Bialetti Moka Easy 6-Cup Espresso Machine
More times than not the bialetti leaks all over the stove. That happens no matter how carefully I check to make sure the coffee grounds aren't on the rim, or how tightly I screw on the top, or how...
I think of a diagnosis for the rubber gasket:
With a water ink marker pen mark all the circle that should be in contact with the rubber gasket. Then screw it to the normal operating position and unscrew it and see if the marker ink is evenly transfered to the rubber gasket, if not, you might need to buy a gasket and replace it.
Also you might test the correct "plainess" of the screw edge by doing the same procedure but instead of screwing the lower to the upper sections, just lay the marked surface against any well even and plain surface as a window glass or mirror.
The water based ink is not permanent nor toxic, and can be washed with any soap or detergent.
Dec 23, 2010 | Bialetti Mukka Express
My Waring Pro Coffee maker leaks water out of the bottom. In the morning when I get in I have to clean up the leak. Is this repairable?
When you pour water into the screen area it travels toward the back of the unit and drops through a rubber gasket/cup to be heated/processed. I have the same problem and while I bought another WC1000 I took my old one apart. By turning it over and removing 4 recessed screws you can carefully lift the top off (carefully because wiring is attached). However, you can now access the rubber gasket/cup. Doing this I found that mine was torn which I must assume is the cause of the leaking problem. Now if anyone knows where I can get a replacement rubber gasket/cup or a part number I would appreciate it.
Aug 22, 2010 | Waring Pro WC1000 Coffee Maker
Gasket - coffee grounds in coffee
hi! It goes on the top and surrounds the pin that pops the hole in the kcup....the problem I'm having is how do you stick it on? Should we use crazy glue?
Apr 03, 2010 | Keurig B70 Coffee Maker
Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
Oct 09, 2009 | Bunn GRX-B Original 10-Cup Home Coffee...
Gaggia classic, still drips coffee
Where is the drip for the coffee happening,is it around the portafilter, or the tube hanging in the drain tray on the left, or from the shower in the grouphead.
1- Around portafilter..since the machine is only 2 wks old the it is possible that coffee grounds are on the gasket in the head, get a hard toothbrush or buy a groupbrush and clean group gasket also check for damage.
2- Tube in drain tray...If it is a continuous drip whenever the machine is on then the nucleus in the solenoid is either dirty or damaged, try backwashing the machine. If it happens only when you make a coffee then that is the discharge on the solenoid working. Run a backwash on the group and that will cleann out the discharge.
3- If it is coming from the shower in the group then the solenoid needs to be replaced.
As for the steam wand leak it sounds as though the valve is not closing. That will have to be replaced because it cannot be rebuilt.5547512.jpg
May 20, 2009 | Gaggia Classic Espresso Machine
Saeco Magic leaks water between water tank and machine.
You have to replace the gasket in the machine where the water tank goes in to the machine.
Jun 26, 2008 | Saeco Vienna De Luxe Espresso Machine
Astra Mega II <----Need help!
The left grouphead sounds like a different problem than the right group head. For the left grouphead, I would start by replacing the group electro-valve. With hard water, this can cause the valve to remain in the closed position even though the water pump is running.
For the right group head, I would want to see this happen. Usually, if the gaskets haven't been replaced in a while (if you are busy, your 'while' may be quicker than others), I would evaluate the condition of the rubber gasket. I would also look at whether you are tamping too much espresso grounds into the portafilter. This can cause a similar symptom as a bad gasket.
Apr 28, 2008 | Astra Mega II Espresso Machine
Hamilton Beach BrewStation 47214 Coffee Maker Logo
64 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
