Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
How do I attach a jump ring to the sandisk so I can attach a strap? Where can I get a jump ring small enough and where do I get a strap?
  • 4,102 Answers
Hi, if you go into any phone shop and buy one of their straps they come with a cord that you loop through the hole and back on itself and this cant then come undone by mistake, its like a nylon thread that you feed through the hole and then put the end through the whole and pull tight you then just clip the strap onto the clip on the loop part, this is very secure and strong as its made to hold the weight of a mobile phone worn around the neck, how ever if you dont want the long strap you can just use the small loop part to attatch it to a key ring or similar.
I know you may be a bit confused but if you go into a phone shop and take the usb drive with you you will see exactly what i mean, these straps also cost near nothing so you cant really lose.
go into any small phone shop or market stall that sells phone accessories and you will see the neck straps im going on about you have the long neck strap part and this attatches to a small nylon loop that you can feed through the tiny hole on the flash drive
hope fully you understand what im saying.
let me know if you have any problems
Posted on Jul 06, 2010
Testimonial: "Thank you for your quick and easy-to-understand response. I've seen these straps but couldn't remember where what they were for. I'm all set now."
  • 540 Answers
There must be a hole in any of the corner of the drive you have to enter the strap in that hole directly.
How to untwist the lower connector strap?
The only thing I can suggest is to rub some Vaseline on it and use two needle nose pliers to pull it free.
Oct 04, 2014 | Britax Baby Gear
How do you move the straps for a bigger child
Hi
Undo the popper on the shoulder harness pad. Slide the pad down the length of the shoulder harness strap.
Unhook the metal D ring.
Feed the short length, low down anchor point back in behind the seat fabric. Bring the longer length, higher up anchor point out at the desired height.
Re-attach the D ring. Adjust the harness straps accordingly.
Slide harness pad back up shoulder harness and re-attach popper.
Sep 11, 2011 | Quinny Buzz Three Wheel Stroller
I want to exhaust a portable A/C out of a 2'w X 6'h, crank open window. Obviously, with no sliding window, the slider system won't apply. So, what are common solutions for venting out crank...
I use a 1" metal strap that is heavy enough to support the unit to the window frame, then I cut plexiglass to fill in the opening. I typically drill small holes to attach the metal strap. Remember that it is very important that the unit slope downwards towards outside for the condensation to run OUT.
Jul 22, 2011 | Frigidaire Heating & Cooling
How do I replace the Fuel Pump?
The fuel pump is located in your fuel tank...you have to drop your fuel tank to replace it...before you do so you will have to sifion [sp] most of the gas out as gas is heavy...when you get out all you can leave the gas cap off and remove the bolts holding the filler neck in place...Then jack up vehicle and place on jack stands....Remove battery ground cable,go under and remove sheild covering fuel tank,while there remove the ground strap attached to the filler neck...Once the cover is off this will expose the 2 tank holding straps.....at this point you will need a jack or holding and lowering devise to support the gas tank..... make sure it is supported well before you loosen the strap bolts!!!! disconnect the EVap hose from canister it runs to tank then remove the strap bolts ...move them aside and lower the tank enough to expose the top where the fuel lines are disconnect them and the electrical connector,ground ...then lower gas tank slowly checking nothing is still hooked to it ...After the tank is down remove it from under vehicle and use a BRASS punch or piece of wood not a regular metal punch to remove the pump retaining ring ...once ring is removed CAREFULLY remove the pump from the tank.....replace pump and new strainer... Then Carefully put the pump back in the tank...if needed replace the ring seal before you place the pump back in...tighten up the retaining ring ....take back to car and put on supporting devise and lift just high enough to reattach all your connectors...then jack up the rest off the way attach holdings straps ,cover,ground ******** filler neck,filler neck bolts,battery cable install gas cap and start hopfully
Nov 09, 2010 | 2001 Chevrolet Impala
How do I attach a cord or ring to my Sandisk Cruzer 8 gb? I am afraid I will lose it because it is so small.
If this is the one you are using,
there must be a ring attached at the bottom or if not there's a you can still attach it with a keychain or something like mobile string, etc..
Hope this helps.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Aug 18, 2010 | SanDisk Computers & Internet
I cant seem to get the bbq hot enough to use it unless I use a propane tank and hose attached to the regulator. If I use the small screw in units, it does not get hot enough. using a propane tank and hose...
Most likely not.
The new style OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
Mar 29, 2010 | Magma Catalina A10-1218 Grill
Need to know how to replace fuel pump on 2002 Pontiac Grand Prix 3.8 v6
You don't need to drop the tank to replace the fuel pump.
Under the carpet in the trunk there is a access cover that you can take off to access the pump. You need a good snap ring pliers to get the snap ring off to release the pump from the tank.
I wish people would have first hand knowledge of the process before they start clicking post and cost a person a lot of money and time for something that isn't needed to be done to complete the job.
Oct 10, 2009 | Pontiac Grand Prix Cars & Trucks
Attaching Neck Strap to SanDisk Cruzer Mini 1.0 GB
There should be two holes to thread the neck strap through. I believe you have to loop them in a certain way so it stays there.
Jan 28, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Brass cotter pins an plastic catch tubes???? Kenmore washer 110.92597210
This is an easy one to solve. Those are moving pins , when in transport. When it is delivered, the delivery people simply just pull on some straps and the pins fall in the cup. You need to keep these when moving washer to put back in, so not to damage anything.
Sep 25, 2008 | Kenmore 23822 Top Load Washer
Quinny Speedi
OK, we saw your problem and after a lot of mucking around I have found a solution. The small metal links on the straps attaching the pushchair have a gap in them. If you twist the loops on the strap to one side, you can work the straps through the small gap.
I hope this helps.
Nov 16, 2007 | Baby Gear
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
424 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
