Question about Alienware PC Systems Alienware Aurora High Performance Gaming Desktop Computer
Alienware Aurora Desktop does not boot, has no HD activity
My Alienware Aurora Desktop will not boot, and does not show a boot screen at startup. When turned on, the fans spin, and the accent lighting turns on, but the activity light on the front of the case remains dark.
My monitor appears to be receiving no signal from the computer.
When unplugged and replugged, the computer turns on automatically, but does not respond to a forced shutdown by holding the power button.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 53 Answers
If the activity light on the front of the tower is not glowing than it can be an issue with the power supply of the PC. Try to open the tower and try to reseat the Power supply cables and check.
You can also try to Reseat the RAM (memory) sticks. If you have 2 Memory stick you can just try to boot the pc with the help of one stick and vice versa. If still the issue persist you can try to do a test on the Motherboard. Simply take out the Memory cards and power on the pc . if you hear a beeping noise than the Motherboard is fine and if you dont hear a beeping noise that it is a faulty Motherboard.
Posted on Jul 06, 2010
  • James wilson Dec 08, 2010
    @Sushendra i think your solution is right. It may be problem with power supply. Alienware Aurora is a totally new design that uses a compact platform and Intel Core i7 platform to provide a compact, high performance desktop.http://www.pcartisan.com/alienware-auror...
My Alienware M9700 starts up but turns off before Windows can start
sounds like a thermal shut down maybe heat sink is full of dust under cpu fan or you need fresh thermal paste on processer
Jan 03, 2014 | Alienware PC Systems Alienware Aurora High...
Loud beeping noise on alienware computer
by fb_margostanley.jpgmargostanley Aug 10, 2012
  • Thankk you. I fixed the problem. It was a key that was stluck. but others may want to know that the type of cement I used for the hinge was JB weld. Worked beautifully! thanks for all lyour help
  • Aug 08, 2012 | Alienware PC Systems Alienware Aurora High...
    Hi, Upon boot up I recieve a Thermal Error on my Aurora R3 Alienware. I have BIOS A05. Therefore I cannot access the Alienware Control Centre. Do you know how I could fix this? Many Thanks in...
    Download the latest BIOS update from the Dell support website. After downloading the update then install it.
    After the update just restart the computer.
    Jun 24, 2011 | Dell Alienware Aurora-R3 Gaming Desktop...
    On my Aurora m9700, the power button stays orange and does not turn off system. Soft-off causes a reboot which goes through post normally until it reaches the boot point, then gives a toe-up beep and the...
    Sounds like a Memory issue. It defiantly a conflict somewhere. I would start with the memory. If you have two sticks installed, then remove one. If it does the samething, re install and then remove the other one.
    Feb 11, 2011 | Alienware PC Systems Alienware Aurora High...
    My alienware aurora desktop is taking a lot now to boot and i can only see the mouse pointer and a black screen... is it normal? it has been 10-15 minutes now waht should i do?
    I checked your system specification and your system should boot fast. And 10-15 mins boot time? That's not normal. Here's what I would like you to try.
    1. Restart the pc. Press F8 immediately and keep tapping it while starting up. (you should get advanced option screen). 2. select safe mode.
    NOTE: if the system start up fine in safe mode. it means your having issues with your normal windows environment. If it's still doing the same thing. The hard drive is about give up. (try running hard drive diagnostic).
    Good Luck!
    Ryan
    Jan 19, 2011 | Alienware PC Systems Alienware Aurora High...
    Alien Aurora will not come out of sleep mode.
    try unpluging it and leave it for a few minutes then plug it back in and try yo boot it up.
    Jun 21, 2010 | Alienware PC Systems Alienware Aurora High...
    Mystery blue screen won't let me log on my computer!
    IF U CAN GO INTO BIOS GO IN BIOS AND CHANGE FIRST BOOT ORDER TO CD ROM THEN PLACE XP CD IN CD ROM AND RESTART PC. AND REINSTALL WINDOWS..........
    Jun 09, 2009 | Alienware PC Systems Alienware Aurora High...
    The montor doesn't come on and shows no connection on the monitor screen
    check the pins on the monitor cable my be some are broken
    and also check your VGA card it may not be good and need to be changed
    May 11, 2009 | Alienware PC Systems Alienware Aurora High...
    Alienware Aurora desktop crashes on bootup
    try to change the cooling fan mayhbe its the problem that your proccessor is over heated.
    Dec 25, 2008 | Alienware PC Systems Alienware Aurora High...
    Alienware PC Systems Alienware Aurora High Performance Gaming Desktop Computer  Logo
    2,209 people viewed this question
    Top Alienware PC Systems Computers & Internet Experts
    Martin Murray
    Frank Zabroski
    Frank Zabroski
    Larry Chandler
    Are you an Alienware PC Systems Computer and Internet Expert? Answer questions, earn points and help others
