Question about LG 32LG30 32 in. LCD HDTV
How do I get my Toshiba Laptop to project on the Sharp TV I connected the VGA cord?
  • 11,361 Answers
If the TV has VGA input the just use VGA cable, just set the TV to 'PC' or 'VGA' on the on screen source inputs selection. On your laptop, you need to set the video resolution to the native resolution of the TV, if it is set too high, you will get 'FOTMAT NOT SUPPORTED', or 'OUT OF RANGE' on the screen.
You will be using Fn key plus either F4, 5, 6, or 7 depends on your make and model of your laptop, the combination keys will let you select Internal, external, or both displays. You will also need to set the display properties on your laptop to alllow the external display to be extended desktop, or cloned of the your laptop display.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Jul 07, 2010
  • LG Master
  • 8,457 Answers
Tries connect it with HDMI cable to tv HDMI hub to the Laptop USB hub this the best result,not many problems with capatabilities this way.
Posted on Jul 06, 2010
Vga hook up
may need to tell the laptop in the screen resolution settings to display the image on the tv instead of the laptop. Right click on the empty desktop of the laptop and go to either propertie or screen resolution and then make sure that the computer can see that the tv is hooked up and that the image is showing on the tv instead of the laptop. You may also need to change the mode on the tv to vga.
Nov 21, 2013 | Pioneer SD-532HD5 53" Rear Projection...
How do I connect my Toshiba Laptop to my Sharp Aquos to watch Netflix?
you need to see if you have a pc in (vga )on your tv and then you need to see if your laptop has a VGA out then you need a VGA Video Monitor Cable HD 15 Male to Male cable bettween the lap top and the TV.
then you need to go to control settings on your laptop (depending on what operating system you are running) then display settings-settings and set it to go to your tv .
Jan 07, 2012 | Toshiba Computers & Internet
I am trying to connect my laptop via VGA cord to my 65" Mitsubishi Medallion, but when I click on the VGA device selection in the device menu, it goes to a blue screen and says "Warning: Turn on...
Press the Windows key + P on your laptop.
Or, if that doesn't work, look on your F keys for something that looks similar to a monitor.
Press the FN key and that key.
This should bring up your laptop's display on the tv.
Mar 09, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Can I hook up my Toshiba laptop to my Sharp Aqous TV, if so what connections do I need, ?S-video? I have an SGA connection on my laptop but not on the TV?
If this is the exact model Sharp Aquos television you have then you would have to have a laptop that has hdmi or dvi. You can try S Video on a laptop but the laptop's resolution would have to be so low that most laptops cannot accommodate this. You're right; this television does not have a VGA (RGB cable) input.
Nov 02, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Connectiing toshiba satellite 2210 to a tv set
The cord you need will either be VGA to S-Video or VGA to RCA depending on which port is on the tv.Once you have the cord hooked up to both,You will need to switch into presentation mode on the laptop using the FN + F7 keys.
Please take time to rate this fixya
May 14, 2009 | Toshiba Satellite A205-S4617 Notebook
No sound when connected to my pc tv type 42 inch dynex flat panel plasma without desktop speakers connected and all audio is turned on also if your tv has speakers and ur using it as a pc monitor shouldt...
No the sound does not travel through the vga cord only HDMI has bidirectional with sound.. You gonna have to use the speakers on your laptop for sound or buy some amplified ones.. good luck
Apr 22, 2009 | Toshiba Satellite A135-S2276 Notebook
Cant connect VGA form laptop to TV.
Sounds like you may be trying to use a resolution or scan rate the TV does not support. Many of these televisions do not support 720p, but DO support 1080i.
Good luck.
Mar 02, 2009 | Mitsubishi WS-65611 65" Rear Projection...
My toshiba tlp 261 won't project the image
hi try using the function key to toggle the display output form the laptop.every laptop when connected to an external display like projector works in the multiple diplay mode.in this mode the laptop vga output can be seen in 3 modes------ only laptop screen, only external deipaly(projector) & both laptop & projector.check this & this should work fine
any further help contact shyam +919867355202
Feb 07, 2009 | Toshiba TLP 261 Multimedia Projector
LG 32LG30 32 in. LCD HDTV Logo
183 people viewed this question
Computer Repairing
Computer Repairing
