Question about Frigidaire FRS23R4A Side by Side Refrigerator
Have a model (sears) FRS23KF5CQ side-by side that is not cooling the water at the dispenser and is hot to the touch at the sheet metal where the 2 doors close...any thoughts appreciated?
    Problem Solver:
  • 16 Answers
Your problem could be a dirty Condensor coil under the unit. Take the grill off of the bottom and use a vacuum with a thin attachment to get in there. That should do it.
Posted on Jul 06, 2010
Hello...My Kenmore Side By Side Refrigerator Model # 57075791 water dispenser gets stuck; removing bottle the dispenser still sends water, pouring all over floor. Help
Since today's refrigerators are about all plastic( cheaply made) and since water has minerals ( that leave deposits), it is only a matter of time until each "fridge" does this.
To see the diagram and order parts, or even to speak with a helper on the phone, type "Searspartsdirect" into your computer search engine , and when you enter your model number, Sears will be happy to assist you.
God bless your efforts.
Feb 26, 2018 | Kenmore Refrigerators
I need a replacement handle for water dispenser on FFUS2613LS
Sorry but this site has no parts resources of any kind. I suggest you contact Sears Direct, they service just about anything.
Jan 19, 2012 | Frigidaire FRS23R4A Side by Side...
Where is the water filter on a 1998 kenmore fridge
Here is where the confusion begins. When Kenmore says their model number, it is different than OEM numbers or original equipment manufacture's number's. Here is the deal with Sears when it comes to their model numbers. Sears buys all their products from someone else like Whirlpool, Maytag, GE and the list goes on and on. Then Sears calls their model number Kenmore Model Number=> Kenmore Model Number Locator's and the first three numbers are the models maker or who originally made the appliance Click Here for examples=> Kenmore Appliance Model Number Prefix's or Click=> Here once you have the correct Kenmore Model Number once you have that then you can find the parts for your dispenser. Your number will look like this for example only 363.235698 then go to Parts Direct or Repair Clinic and enter the correct Kenmore appliance model number and then search dispenser parts for that model numbers parts number. Hope I made this simple enough so if you need assistance I will be here to help you find that one small part you are searching for, Thanks, for understanding, Sea Breeze Once you find that 363.235698 example you will be well on your way!
May 05, 2011 | Kenmore 52642 / 52644 / 52649 Side by Side...
Water dripping out of water dispenser tube
SOUND LIKE YOU HAVE A BAD INTAKE VALVE. IF THE WATER DRIPS ALL THE TIME.
Jan 12, 2010 | Kenmore Refrigerators
My water dispenser does not work. I unscrewed the hose at the bottom of the door and there is water pressure there. Where should I be looking for the problem?
If pressure there it could mean anything may be possible. I need the Sears Model Number. If the water valve on rear of refrigerator does not open then water will not exit the dispenser. Sometimes water is frozen in the dispenser water container located inside the fresh food. Sears Numbers Look Like this (231.564897) for example
compartment. And sometimes it is the dispenser controls. I will need your Kenmore Model Number to tell you the part you need and to help you better. Thank You, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartseast.blogspot.com/
Jul 08, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Water dispenser leaking
Sears has a complete model number system that is confusing I know. Sears made it that way. Not sure why but look around the cold food door while open and look near bottom on the frame just above the kick plate. The number looks like this, (model No. 253.64802400 for example) Find that number and we can go from there, Thanks, Sea Breeze
Jun 10, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Condensation on the outside of the ice/water dispenser on freezer side.
Turn the water supply off to the back of refrigerator and take the line feeding the supply to the water control valves off and then put the line into a pan to purge any trash that may have collected before entering control valve. It is very possible that a piece of rust or a piece of plastic is holding the control valve open slightly. The continuous dripping of the chilled water is what I suspect is causing the condensate. On bottom of the refrigerator Sears uses a number like this example. You may find the number behind the cold food section door near floor. I will need that to help you better. Example 215.22897
Sears always gives their models a different number than the same models that GE, Whirlpool, Westinghouse and on and on. When you are able to see if the valve is stuck and need to clean or replace it we will need your model like in the example to find the correct part, Let me know, Thanks, Sea Breeze
May 15, 2009 | Kenmore Refrigerators
Whirlpool refridgerator ice maker
Check your water valve. Most likely it is leaking by the seal on the icemaker side of the valve so that it is getting a slight trickle of water all the time to the fill tube. This will freeze in the tube much like an icecicle is formed. This is the most common cause. Low water pressure and mineral deposits inside the tube can cause it also, but it usually will take longer than a few days for the problem to reappear.
The dispenser housing and parts on your fridge are replacable and show to still be available.
You can go to sears.com, click on parts, enter your model number, and see parts diagrams and lists for your fridge.
This link should go directly to the parts site.
http://www3.sears.com/
Post back and let me know about the water valve.
Thanks/Mike
Jan 06, 2008 | Refrigerators
Frigidaire FRS23R4A Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
