Question about Frigidaire FTF2140E King-Size ENERGY STAR
My 13 year old step-daughter tried to add something to my Frigidaire FTF2140E Washing Machine while it was in the middle of running a load. It will now not start back up. I took the wet load out and remove as much water as possible. It still does not start back up. The green lights will come on but when I hit start it just blinks/beeps two or three times but does nothing else. I have also unplugged the machine for several hours and retried it later with same response. Any ideas?
    Problem Solver:
  • 16 Answers
It sounds like the door latch is not working correctly. As a safety feature the unit will not run without sensing the latch is locked. Check the male end on the door first. If that is not broken then you will need a new door latch assembly.
Posted on Jul 06, 2010
How to remove lock on washing machine door
hi marianne.
go to this link and scroll down the page it might help you out.
How to remove lock on washing machine door Google Search
Nov 06, 2017 | Washing Machines
Washing machine getting hung on a cycle
If the machine is 14 years old, it probably is time to replace it.
Jun 06, 2017 | KitchenAid KAWS850L Top Load Washer
After power failure our FTF2140ES clicks and starts continually all lights are flahsing.... Only way to stop it is unplug it. How can we reset it?
Sorry, this isn't a solution. We are having the same problem, did you ever find a solution?? Our machine actually won't run a wash cycle anymore, just keeps beeping at us like it is possessed!
May 11, 2010 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
2yr old daughter hit some buttons now it won't - pau 33 pau 33
did you get this fixed? how? my 2 year old son did same thing.
Dec 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Ftf2140es3 won't completely drain or do final spin.
I have one that does the same thing at times. remove the bottom front panel. You will see a black boot that comes down from the tub. Loosen the clamp on top of the boot. You should be able to pinch the boot and feel something hard inside the boot. Pull the boot down from the tub and put your fingers down inside the boot and pull up the coin collector. It may be full of junk, coins ect. Clean it and replace the boot and clamp. This should help you.
Jul 16, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
LG stinks too
It is not a poor design its the way we have gone re washing clothes
Old machines washed hotter and with more additives in the powders.
Try using a good strong mix of soda crystals in hot water , pour that into the wash before you switch it on and do a hot wash without any soap powder
Use old fasioned powders for a couple of weeks and do a hot wash once a month with the soda
The constant cool washes leave body fats from the clothing inside the machine as there is no real heat to melt them and no soda in the washing powder anymore to unstick them from the surfaces .
Jun 26, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Clothes rough & scratchy as if dried outside in freezing temps
Having a water softening unit and keeping it working properly are two different things....when was the last time the system was regenerated? Has the hardness of the water been tested lately? Even though you have a softener, it dose sound like a hard water problem....First step would be to get the water tested not only for harness but also for mineral content. Test the water before and after regenerating the unit. Some home improvement centers have a home water test kit available that would be quicker and cheaper but not as reliable as having a lab do it. The home test kits may point you in the right direction before spending for a lab to test. Hope this helps. Let me know what you find.
clarkco
Apr 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Bad odor
glisten and affreash is the cleaning agents
besides this only way to get smell out is a complete inner and outter tub job but also try leaving both soap dispenser and door open for the air to dry up and vent the washing machine
Feb 24, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Frigidaire FTF2140E King-Size ENERGY STAR Logo
119 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
