Question about EliteGroup Intel Pentium 4 Processor 506&ECS P4M800-M7 Motherboard (506P4M800M7)
NO Power up at all, Nothing!
Im not getting any Power signs at At, its not even attempting to boot, I took the memory out and still the same problem, Its completely DEAD! i have the right jmper setting, but when i turn on the switch on, the green light is still off. i check the manual and i found out that may setting is correct. there is still no output on the monitor and the light led on my keyboard didn't blink also... help me please! F1....
  • phalitao Apr 22, 2008
    thanks mike for the assistance... i will immediately try your solution. thanks FixYa!
  • 2,351 Answers
Phalitao, you need to check you're power supply it may be bad.
No PC or notebook will boot without memory. However in your case I would recheck all power connections from the power supply to the board. Remove & reseat all power connections.
Please use you're manual help guide you. Also on the back of you're power supply (on most PSU's), there is a Red slide switch. Please make sure it is set to 115v & not 220v. After all this checking & you do not see life from the board, suggest you replace the power supply with a min wattage of 400w. Or borrow a PSU of 350w or better.
Please post back with you're findings.
In order to stay within this post do this.
How to repost more questions for same problem.
Enter site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Answer quwstions from you're tech & add more information.
Good Luck!
Posted on Apr 18, 2008
When you replaced the battery did you reinstall the BIOS? In my experience the BIOS is kept onboard the motherboard with that battery and when that goes so does the BIOS or at least it's stability.
Reinstalling the BIOS would be my first attempt after you've replaced the battery (which you've already done)
Dec 23, 2015 | Computers & Internet
Acer 5315 will not switch on with power button, attempt then goes dead after 2 seconds battery light flashing amber when power lead connected but this is when power switched on or off. Sometimes it...
Try removing the battery and power on with the adapter. If you get boot, then you have a bad battery. If not then you adapter is more than likely not producing enough power to power the unit. You may also try allowing the battery to charge over night without trying to boot, If this doesn't do the trick, remove the hard drive and CD/DVD rom and one stick of memory. Try booting with just he adapter. Do the same with the other memory card and then swap memory slots and try again. If this doesn't produce a boot, you may have a broken connections in the laptop power connector. This will require a trip to a reliable repair shop.
Apr 09, 2011 | Acer Computers & Internet
Doesn't boot. IR remote working. No boot lights. Remove memory stick, tries to boot. If program on memory stick, can a new one be purchased?
Power down completely and then remove the memory stick. Wait a full 30 to 60 seconds with power off. Power up to start boot process. Pay attention to the screen while booting to note any messages during this time. If the computer fails to boot still - check the drives (floppy, CD and DVD) to be sure none have disks inside - remove any if found. Attempt a warm reboot if possible - otherwise perform a cold / hardware reboot.
If still not booting, access the computer's BIOS and make sure the information on those pages are correct. If in doubt, set any unknown values to "default" or auto detect. Be sure that the bootable hard disk appears in the boot order somewhere - if not the set as the first bootable device.
Once booting successfully into the OS, insert the memory stick and attempt to read the contents. Many applications that ship on memory cards are not bootable - but yours may. Read the info supplied wit the memory card fully to be sure.
If unable to boot the computer, provide the manufacturer's name, model and your OS. Also include the name of the application on the memory card.
Hopefully, you'll have gotten the computer started before needing to write back with more info. I hope his was helpful - and good luck!
Mar 19, 2010 | Computers & Internet
Compaq Presario V2000 will not boot.
Remove the battery and just leave it off the computer, then plug in the power cord and try it. If it works with no battery...the battery is completely dead and you need to replace.
Mar 08, 2010 | HP Compaq Presario V2000 Notebook
I just came up to download yahoo messenger version 10.0 beta but it wont work out . Ofcourse I do have uninstalled my old yahoo messenger version 8, After several of trials signing in on the yahoo...
well..this problem occurs sometimes with yahoo messenger 10. so you need to know how can you sign in,
when you try to sign in on yahoo messenger 10, please go to messenger settings and then in the connection settings tab, please select your network type, i mean if your network connection is broadband, select broadband..if you are using dial up modem, select it or if you are using it...then try to login again..
i think your problem has been solved.
thaks for using fixya
Feb 28, 2010 | Yahoo Messenger
Regarding Direct Memory Access
Your disk is probably operating in slow PIO - you can reset it to DMA by reading this article
Take the Quick solution
Nov 30, 2009 | Microsoft Windows XP Home Edition
Intel dg31pr motherboad not booting.
Unhook everything except power and your monitor. Put one stick of memory in and attempt to boot. Post here with results, what power supply you're using, what memory, and what processor.
Jun 07, 2009 | Intel DG31PR Motherboard
Drive not accessible due to I/O error
Without a windows cd or recovery it is very hard. You should take some cd from somebody. At other hand, you can connect your hd to another pc and try program - hdd regenerator- on it.
Apr 10, 2009 | Sony VAIO VGN-NR110E/W 15.4-inch Laptop...
Computers & Internet Logo
91 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
