Question about Logitech Cordless Mouse
My wireless mouse connections keep going out. I
My wireless mouse connections keep going out. I press the white connect button on the bottom of the mouse and it works for a while and then if the mouse isn't being used it goes out again.
    Problem Solver:
  • 22 Answers
I've had this problem be4. There are either one of two problems: one you mouse needs new batteries or two the usb connecter is not connected to the pc or the usb port is messed up. Try this: move the usb connecter to another usb port and see if it works then. OR just replace the batteries.
Posted on Jul 06, 2010
How do i re-connect my wireles mouse? I can not find directions and I am away from home!!
Hello there.
To reconnect your wireless mouse here is what you should do:
1. Be sure your computer is turned on.
2. Connect the receiver with the USB connector.
3. Be sure you have batteries in your mouse. The synchronization will start automatically.
4. If synchronization doesn't start automatically, press the connect button on the receiver then press the connect button on the bottom side of the mouse for ten seconds.
Thanks for using Fixya!
Jun 25, 2011 | Belkin F8E874-APL Wireless Optical Mini...
Dynex wireless mouse with new batteries (kodak AAA) inserted properly fails to move the cursor. Mouse barely used, purchased last year at Best Buy, Hadley MA
Make sure the mouse is turned on (power switch on the bottom) and then reconnect it with the USB receiver. Press the Connect button on the receiver, then press the Connect button on the bottom of the mouse.
Feb 19, 2011 | Dynex Wireless Optical Laptop Mouse...
Changed battery correctly but the on/off green light keeps blinki
you have to hit the button on the wireless base adapter as well as the one on the mouse its self
good luck and pls rate this post
Mar 23, 2010 | Logitech Wireless Access Duo Optical...
How to connect wireless mouse to computer?
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Mar 17, 2010 | Micro Innovations IC445C Webcam
Can't remember how to reset
You will need to press and hold the connect or reset button on the wireless mouse receiver that is plugged into your computer. While pressing that button also press the connect or reset button on the bottom of the actual mouse. The lights should blink indicating they are now connected and you should be good to go!
Please let me know if you have any further questions or problems.
Mar 09, 2010 | Logitech Cordless Mouse
The wireless mouse works but the laser 5000
press connect on the wireless device...let go and then within 5 seconds press the button on the bottom of the keyboard. Repeat the same steps for the mouse whther its working or not. The problem usually is that the keyboard and mouse are on the same "Wireless Channel" and only resyncing them puts them on a seperate channel, hope this helps.
Erick
Oct 27, 2009 | Microsoft Wireless Laser Desktop 4000...
Fujitsu siemens wireless mouse not working but keyboard is. Have checked cables and changed batteries I have the same problem as Sean after replacing batteries in mouse it no longer works. I have tried...
check the range at which it can support.........
don keep any additional electronic device near by to it.........
check the wireless connection is enabled on the device........
40% times it works.... try!!!!!!!!!!!!
ny more q: mail me at --dashvrista@gmail.com
Sep 24, 2008 | Fujitsu Siemens Siemens (S26361-F2378-L30)...
Wireless mouse
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Sep 20, 2008 | Microsoft Wireless Optical Notebook Mouse...
I am trying to connect my wireless kb and mouse to teh new acer aspire series l3600, the manual say to press the receiver button then the conect button on either the kb or mouse. there is one problem, the...
the receiver botton is usually on the top side with a LED.....and the connect button on mouse and the keyboard is usually on the bottom (small white button)
Apr 15, 2008 | Computers & Internet
Wireless mouse issues help
This information is straight off of Logitech's help forum. To change the channel a mouse is using, simply press the connect button on the receiver and then press the connect button on the bottom of the mouse. You can check the channel status in the MouseWare Properties under the Cordless Tab. You may also try to keep the distance between systems at least 10 feet or more. Moving the mouse closer to or further away from the receiver can also improve transmission and performance. If the above fails, try pressing and holding the "Connect" button on the receiver for 10 seconds. This will reset the receiver's connection information and allow you to do a first time connection with the receiver and mouse. After holding the Connect button for 10 seconds, press the Connect button on the bottom of the mouse to synchronize it with the receiver. Good Luck.
Jun 10, 2007 | Logitech Cordless Click! Plus Mouse
Logitech Cordless Mouse Logo
578 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
