Question about Craftsman Convertible 25cc. Gas Line Trimmer
I have a craftsman line trimmer, I believe it is model #79107, pull string to start and string will not go back in ???
    President:
  • Craftsman Master
  • 1,545 Answers
This can be a challenge to repair. The Torx screws holding the casing and machine to it will have to be removed to access the starter/recoil unit. If you have opened one up before, it's not that bad...if not...it's a real learning process, Take your time, you will need Torx head screw removal tools and a little patience. Once you reach the starter unit, you will realize the problem. Go to that point and maybe post again later?
Posted on Jul 10, 2010
How do i disassemble a craftsman string trimmer head to expose the trimmer shaft?
you dont,y7ou need to get the adapter that came with the universal head,if you try to take more than the head off,you will damage it
Jul 19, 2015 | Craftsman Convertible 25cc. Gas Line...
I need to feed the line back into the holes on the craftsman 17' 25cc weed trimmer. I dont know how to remove the line holder to replace
Although it is called dual line, only one line is used - except that you use both ends of the line. Cut off as much line as you think the spool will hold. Put the two ends together to find the center of the line. Some trimmers have holes to thread the lines through and others have a place to hook the bend at the middle of the line. if yours has threading holes, thread one end of the line through each hole and then pull on both ends until the bend of the center of the line won't allow any more slack. If your trimmer has the place to hook the bend, hook there and start winding the lines in the direction shown on the spool. Be sure one line is on one half of the spool and the other line on the other half. Wind both lines at the same time as smoothly as you can. When the spool is full, insert the loose ends through the trimmer head, insert the spool and pull on the strings. Hope this helps Tim
Here is a site that can help if I did not understand your question correctly:
http://www.ehow.com/how_7872475_replace-craftsman-25cc-line-trimmer.html
Apr 10, 2011 | Craftsman 25cc Gas Line Trimmer
Replacing the dual-line on the 15" Electric trimmer - Do you run the line through the slot on the casing before the outlet hole?
The slots on the string spool are there just to hold the line in place so it doesn't unwind while you are putting the string head back together. You have the strings sticking up, you lower the casing with the eyelet holes down, feed the ends of the strings sticking up through the eyes and then yank them free of the slots so they can automatically feed. So yes, line goes from spool hub to spool slots to casing outlet holes and don't forget to pull it free of the slots.
Oct 11, 2010 | Craftsman Garden
How do I get more line to come out of my craftsman trimmer model 316.79190?
Maybe try going to : www.searspartsdirect.com and download your model specific user manual. They probably have detailed instructions in there on the operation of your string head.
Aug 25, 2010 | Craftsman 25cc Gas Line Trimmer
I have a craftsman 32cc weedeater model 316791810. I am not sure how to replace the trim line. Is the line supposed to automatically length itself when the line breaks?
An auto feed line system will do just that and if too much line is released there is usually a cutter inside the edge of the plastic guard covering the string head. I use a Troy Built head on a 32 craftsman and I unscrew the bump knob ...twist and pull out the spring loaded spool....cut a lenth of line 6-8 feet or so....thread the two raw ends thru the two holes in the inner spool....pull them out until they are even with each other....then grasp each one and hold them side by side and wind them onto the spool in a clockwise manner. This is how I do the string head with a split boom that fits the 32cc Sears Power head (an older Troy Bilt).
Aug 23, 2010 | Craftsman 25cc Gas Line Trimmer
Putting new pull string on Craftsman trimmer
it does screw on take a channel lock to grab the clutch and turn left to remove it
Aug 01, 2010 | Craftsman 25cc Gas Line Trimmer
No spark Craftsman 989.796060 32CC string trimmer
I believe there is a t20 trox screw holding the clutch cover on. Look down the hole where the drive shaft would insert. After you get that off, the clutch itself needs to be pulled off of the shaft. DO NOT BEAT ON THE END OF THE SHAFT. You may need a small puller to get it off.
Jul 26, 2009 | Craftsman 25cc Gas Line Trimmer
Pull String Ripped out, How to Replace?
no its not imposssible.but its not easy unless u have done a few times.you have screws around the plasic casing get them out.and pull
shaft off engine.
Jul 20, 2009 | Craftsman 25cc Gas Line Trimmer
How to add more line in my craftsman 32cc
Invert the trimmer pull the center of the head straight off. Wind new line in counter Clockwise direction. There should be a hole or notch to place the center of the string in. insert each end of the sting through one of the holes in the head and reinsert the spool into the proper position. Be sure that the automatic advance is movable by pressing down and pulling out more string. Cut string to proper length and restart your trimmer
Jun 06, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman Convertible 25cc. Gas Line Trimmer Logo
115 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
