Question about 5501 LC3 SST LCD 2 Way Car Remote Starter System
The battery on my viper 5501 ran down. I plugged it in to recharge and now it won't work. The back-up key fob does work. how can i reset it? thanks very much.
  • 4 Answers
Are you talking about the Remote LCD key fob itself? If you are then you need to replace the battery. Search on ebay. Hopefully this helps.
Posted on Mar 21, 2013
4 Suggested Answers
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
dancandoit
  • 436 Answers
SOURCE: '98 Audi A4, Viper 5501. Car auto-starts and runs
You will be best to connect the real tach wire. You will need to programme the alarm to recognise the speed of the engine, this way it will know where the idle position is.
Posted on Nov 20, 2009
slick42371
  • 42 Answers
SOURCE: I have a viper 5501
This sounds like you have a delay domelight and they used that to trigger the alarm. You domelight stays on for 20 seconds after you close the door so because it is still on the alarm thinks the door is open even if the doors are closed. you can fix that by having a tech hook up the door triggers to the door latch wires and not the domelight itself...or you can program the alarm in Menu 2 otion 3 to not sense the door ajar when you first arm your alarm.
Posted on Feb 10, 2011
SOURCE: bought viper 5501 yesterday.started car
Make sure you turn the key to the on/run position, then once you place your foot on the brakes to put the vehicle in gear the remote will beep and recognize the alarm.
Posted on Sep 01, 2011
How do I turn off the alarm?
Try pressing the unlock button twice quickly.
Aug 21, 2017 | Viper Vehicle Parts & Accessories
Viper 5501 control center won't enter pairing mode
If you didn't already get it all set you can disconnect power from unit for a little while (10 or minutes) and reconnect, you then should be able to program your remotes regardless if it was locked or not.
Feb 19, 2014 | 5501 LC3 SST LCD 2 Way Car Remote Starter...
I cannot enter fuction programming on viper 5501
You're going about all wrong. ALL the power wires need to be connected.
The MTS programmimg is not done through the remote, it's done WITH the remote. Open your instructions; Turn ignition on then off, press and hold programming button on antenna untill the LED flashes three times, release programming button. Now, press and release the programming button one time then press and hold. (This the transmission option) Press the unlock on the remote. The LED should flash two times indicating that the system is now in automatic transmission. Turn the ignition on to exit programming.
Dec 17, 2012 | 5501 LC3 SST LCD 2 Way Car Remote Starter...
I have 2004 chev tahoe w/ a viper remote starter system,but no key fob. I replaced the car battery & now the cars computer won't let it start. How do I reset the computer?
The car's computer wont let it start?
Well, if you changed the battery and the viper alarm is the issue; locate the push button valet/programming switch. Turn the ignition on, press and release the switch. The alarm will disarm and you can start the vehicle.
To put the alarm in valet, turn the ignition on then off, within 10 seconds press and release the valet switch. The LED will illuminate solid to show that the system is in valet.
Aug 20, 2012 | 5900 SST 2-Way Security System / Remote...
The remotes for my Viiper 5501 won't charge
There was an issue with these remotes when first manufactured. Try this, when initially charging the remote; plug the charger into the outlet then, plug it into the remote; remove, plug it in, remove; continue. It should take approximately six times before the remote says "charge" in the screen. If you repeat the process and the remote does not "wake up", replace it.
Jul 15, 2012 | 5501 LC3 SST LCD 2 Way Car Remote Starter...
Bought viper 5501 yesterday.started car with remote but when i put key in ignition car stops running when key is removed car starts automaticly
Aug 20, 2011 | 5501 LC3 SST LCD 2 Way Car Remote Starter...
I had the Viper 5501 installed on my 2000 4Runner last week and today my new truck battery has died. I got it boosted and now it is dead again. The only thing I can think of is the car starter is draining...
Yes your alrm could have been installed wrong. Depending on where the tech hooked up his wiring he maybe at a spot where the alarm is not allowing the trucks computers to shut down. The trucks computers should shut down after 20 minutes to where it draws only 20 to 30 milliamps. If the tech hooked up his wiring in the wrong locations the computer may never shut down and will stay at 150 to 200 milliamp draw which in this case would drain the battery
Dec 24, 2010 | 5501 LC3 SST LCD 2 Way Car Remote Starter...
Nov 20, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
1994 Dodge Viper will not start after storage and battery drain.
With the battery charger connected or a jumper battery simply click the alarm key fob on and then off. This will reset the alarm and the car should start...had mine towed to find this out
Apr 07, 2009 | 1994 Dodge Viper
5501 LC3 SST LCD 2 Way Car Remote Starter System Logo
622 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
