Question about Fisher and Paykel WA37T26G Top Load Washer
I have a Fisher & Paykel WA37T26GW2 washer that I have loved for the last year. After moving homes however I am now getting an error code: the cold water temp light and the first green wash light are blinking. There is no code in the manual for the wash light but the cold ewater light is supposed to be either a blocked inlet or an incorrect temperature. I cleaned out the filters both of which were already clean no kinks in the hose and the hoses are connected correctly. It seems as if the machine fills and then just stops giving this error. If I hit the Start button it continues through the cycle as normal. I tried setting the water temp to warm instead of cold and the same result appears. Any help?
SOURCE: Washing machine not draining and finishing cycle
I had the same problem.... It would stop on the rinse cycle and beep.  Check to make sure you can hear the water pump running or if you can just hear an electrical hum and then it quits, it may be a problem with the water pump.The water pump can be accessed by removing the tub, reach down the center of the agitator and remove plastic bolt, remove the stailess steel tub and then remove the plastic oval shaped cover at the bottom of the main tub to access the pump impellor.  Make sure the impellor turns freely, if it does not you may have a problem with the pump motor.  We had a gold chain go missing and it showed up wrapped around the pump shaft causing it to bind at times.  It took me two tries to fix it but now it runs 100%.
Posted on Nov 01, 2007
jackiaria
  • 350 Answers
SOURCE: Fisher and Paykel washer dripping water into tub.
Dear FixYa Customer,
First and Always go to the Manufacturer for Parts Compatibility and/or Service!
For a GREAT APPLIANCE PARTS WEB SITE click on the highlighted http:// link that follows...
Same-Day Shipping, Return Any Part
Save When You Do Repairs Yourself! @
http://www.partselect.com/Entry.aspx?
jackiaria
Posted on Mar 21, 2009
stephanos18
  • 144 Answers
SOURCE: Fisher Paykel GWL11 Cold Water Not Flowing
you can swap the hot and cold valves over and see if this fixes the problem as it sound like your cold valve is faulty but not the hot valve.
Cheers
Posted on Mar 25, 2009
SOURCE: Fisher & Paykel GWL11 Leaking water
If you cannot see the water leaking from the inlet valves, check the seal just above the water pump located directly under the drum. I am in the midst of awaiting parts to fix this very thing on my FP GWL11. This leak is dripping water directly onto the motor, causing it to trip the circuit breaker during drain/spin cycles.
Note... I have also had to have the inlet valve assembly replaced as well as it was not opening to allow cold water to mix with the hot.
Hope this helps.
Posted on May 12, 2009
localwonder
  • 6784 Answers
SOURCE: My washer won't stop filling up with water!
This is a faulty water valve assembly. replace asap if possible. the embedded water pressure sensor is damaged.
Posted on May 29, 2009
My fisher and faykel washer model wa37t26gw2 does not fill, and will not drain. diagnostic says plugged drain hose, but it is clear from pump to diverter
Your question does not make sense. You say it does not fill but then you say it will agitate. How can it agitate if no water has filled? Does it beep and give an error code/ If so what is the error?
Jul 23, 2016 | Fisher and Paykel Washing Machines
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
WAS THERE A RECALL ON FISHER & PAYKEL GWL 11
no not thst i know of but its always been a problem with them over tha last 20 years
Feb 02, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel Ecosmart WA37t26gw2 won't drain
Check your belts and replace if faulty
turn the pump by hand with belt off to see if pump is jammed
still no go, you may have a faulty electronics board.
Oct 30, 2011 | Fisher and Paykel GWL11 Top Load Washer
What is error code 136 on a fisher & paykel IW709AU top load washer
136 fault is 'motor stall'...Quite often this is a broken wire to the motor. However it could also be a Motor fault, or Rotary Position Sensor problem. Water damage can cause this fault as well. After a visual check for broken wires or water damage, and if your machine is in good condition, you should consider a tech....Good luck...Nomess
May 20, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
May 18, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Have Fisher & Paykel top loader. Error code
fault code 56 is a real code : bowl invalid check clutch in centre of bowl and pressure tube is not kinked,can also mean pressure tranducer on motor control board could be faulty, note check for obstruction between inner and outer bowl( missing a sock perhaps.?)
May 07, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
May 29, 2009 | Fisher and Paykel WA37T26G Top Load Washer
Fisher and Paykel WA37T26G Top Load Washer Logo
158 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
