Question about Uncle Mike's Sport & Outdoor - Others
I have a Pro-3 RH 2232 holster that the top strap has broken off of. It will need to be resewn to make the holster serviceable again. WHERE can I take it or send it in the Portland, OR metro area (or not) and how much are the only two questions I have
    President:
  • 1,561 Answers
I advice you check the service manual that came with your device to see names and locations of service center on the device, getting this is a way forward and a better means of getting your device service.
Take care.
Posted on Jul 06, 2010
What are the top 5 concealed carry holsters?
If you want the best leather concealed carry holsters. Then you can select from here. Here I am giving top 5 holsters name
1. N82 Tactical
2. HK P7 Outside the Waistband
3. Small of Back
4. 4100 Holster
5. Comp-Tac CTAC
From here you can choose your holsters according to your need.
Mar 14, 2018 | Cell Phones
Where can I find the best holsters for women?
There is a site that offers the best leather gun holsters. You can view a great variety of women holsters there. The holster which I prefer is Tequila Ladies Rig model. It has a curved belt structure to meet the specific needs of women shooters. This structure also makes it comfortable so that you can keep wearing it for a longer time duration. There are also various other types of holsters available on the site which you may definitely give a try.
Feb 13, 2018 | The Health & Beauty
What points must be considered while looking for the best shoulder holster for a gun?
Some of the points to be considered while buying a shoulder holster is as follows:
1. Comfort- First of all, the holster must be comfortable. The holsters made up of high-quality leather provides great comfort.
2. Durability- The holster must be durable. Don't go for buying cheap holsters as it would definitely save your money but have lots of comfort issues in the later period.
3. Price- Good holsters are little expensive but don't get caught up with the name of brands.
4. Design- Its design should be classy and should go with your personality.
There is a site that offers custom custom leather holsters, you can refer to that site anytime.
Feb 06, 2018 | The Optics
Name the different types of holsters available online?
The different types of leather holsters available online are pocket holsters, shoulder holsters, waistband holsters, belt holster, f**ny pack, ankle holster and many more. In my opinion, the waistband holster is comparatively the best as it becomes easier for you to fetch your gun and shoot your rivals instantly.
Feb 05, 2018 | The Computers & Internet
How do I repair the vt commodore rh front door escutcheon assy
Good afternoon,
From my previous experience and knowledge you will nomal get lick a cracking and knocking when opening the door this is due to worn check strap centre bush.
In some cases you can just replace the bush but depending on how long its been like it I have found with some commodores when you loosen the bolt they tend to break .So I would recommend you change the whole check strap ,bush and bolt assembly.
if you go the the front a pillar and open the door you will see the top and bottom hinges approx. half way up you will see then plate with a 10mm bolt through it attach to the a pillar.
1.remove the 10mm bolt an nut.this end will then come away from a pillar.
2.fully open door on the other end of check strap you will find to 10mm nuts remove these and check strap will be removable.
3.please remove the door will have no tension.
4.fit new check strap to inside of door.
5.then slow close door so you can align the check strap with a pillar bracket once this is done .
6.fit 10mm bolt and nut and tighten do not over tighten .
7.open and close door cracking noise will be gone ..
hope this helps you
Feb 17, 2015 | 1998 Holden VT Commodore
I can't figure out how to fix the straps to my leg for the tpx holster.
The holster should have 2 straps to put around your leg with quick disconnects and a loop hole for any kind of belt you want to use.
Feb 14, 2011 | Tippmann A 5 Standard Paintball Gun
K2 Cinch loop leash on top of highback tore. What is the best way to fix it? Glue, saw on, both or order a replacement part. Or leave it alone since it does nothing after adjustment.
The K2 website has a binding technical manual, link was found at the bottom of the K2 home page (see link below). The manual provides NO part numbers and NO repair procedures, but the repair is fairly easy.
http://assets.k2sports.com/k2snow/ftpk2snow/2017/catalogs/k2snowboarding_binding_tech_manual.pdf
The back straps on the K2 Cinch are called "grab loops" as shown in photo below.
If both “grab loops” are broken, take a few photos first so you can recall the routing for installation of the new “grab loops”.
These "grab loops" are held in by two silver coloured roll pins which can easily be tapped out with a small nail & hammer. If the pin doesn't come out easy, tap from the other side of the pin. The pin has a head on one side.
You may need to use pliers to remove the broken piece of strap from the top lever.
Take the broken strap pieces to your K2 retailer ( snowboard shop) and ask them to order a new strap. K2 info suggests you can’t order parts online direct from K2, so you have to order through a K2 retailer.
Use your other binding with the good strap to copy the routing of the new strap. You might want to order two new grab loop straps and change them both while you are at it. ??
Apr 14, 2010 | K2 Cinch CTC Snowboard Binding
Need help with dash removal.
  1. Remove the A-pillar and cowl side Trim Panels
  2. Remove the front floor console.
  3. Depower the supplemental restraint system (SRS).
  4. Remove the instrument panel side finish panels.
  5. Remove the 2 steering column opening cover screws.
  6. Remove the steering column opening cover.
  7. Remove the 3 lower steering column cover screws.
  8. Remove the lower steering column cover.
  9. Disconnect the steering column electrical connectors.
  10. Disconnect the RH side bulkhead electrical connector.
  11. Disconnect the RH side body harness electrical connector.
  12. Remove the 2 parking brake release handle screws.
  13. Disconnect the LH side instrument panel electrical connectors.
  14. CAUTION: To avoid damage to the clockspring, do not allow the steering column shaft to rotate while the intermediate shaft is disconnected.
  15. Remove the pinch bolt..
  16. Disconnect the adjustable pedal electrical connector.
  17. Disconnect the brake light switch electrical connector.
  18. Remove the 2 LH instrument panel center brace bolts..
  19. Remove the 2 LH instrument panel center brace nuts.
  20. Remove the LH instrument panel center brace.
  21. Disconnect the transmission range selector lever cable.
  22. Disconnect the RH side bulkhead electrical connector.
  23. Disconnect the LH side body harness electrical connector.
  24. Remove the 3 ground strap bolts.
  25. Disconnect the inertia switch electrical connector.
  26. Disconnect the RH side instrument panel electrical connectors.
  27. Remove the 2 RH instrument panel center brace bolts.
  28. Disconnect the vacuum connector.
  29. Remove the 2 RH instrument panel center brace nuts.
  30. Remove the RH instrument panel center brace.
  31. Remove the cowl panel grille
  32. Remove the instrument panel bolt located under the cowl panel grille
  33. Remove the instrument panel defroster grille.
  34. CAUTION: To avoid damage to the sunload sensor and electrical connector, remove the grille just enough to disconnect the connector.
  35. Disconnect the sunload sensor electrical connector.
  36. Remove the 2 instrument panel top cowl bolts.
  37. Disconnect the antenna lead-in cable.
  38. Disconnect the RCM electrical connector.
  39. Disconnect the center ground strap bolt.
  40. CAUTION:To avoid damage to the instrument panel, an assistant is required to support the panel before carrying out this step.
      • Before removing the instrument panel make sure all electrical connector wiring is free and not hindered.
  41. Remove the 4 instrument panel bolts.
  42. Remove the instrument panel.
  43. To install, reverse the removal procedure.
Feb 11, 2009 | 2005 Ford Explorer
Sport & Outdoor - Others Logo
Top Uncle Mike's Sport & Outdoor - Others Experts
Bill Eager
Are you an Uncle Mike's Sport and Outdoor - Other Expert? Answer questions, earn points and help others
