Question about Kodak EasyShare P850 Digital Camera
My Kodak EasyShare P850 will not turn on. I purchased a new battery for it, charged it, and put it in the camera. When I turn the camera on, it will make a little click noise but that's it. Nothing shows up on the screen, you cannot look through the view-finder, it will not do anything. Any ideas of what could be wrong with it?
Habubnik
  • 114 Answers
SOURCE: "unrecognized file format" error message
When videos are spliced, multiple audio and video tracks are needed. Kodak EasyShare digital cameras can handle only one video and one audio track at a time. Use the Apple QuickTime player to view spliced videos.
Posted on Aug 29, 2005
Noggin
  • 944 Answers
SOURCE: Kodak EasyShare P850 - Black screen
here is the link to the Kodak support page for your camera; http://www.kodak.com/global/en/service/products/ekn030485.jhtml?pq-path=7546 It has user manuals, FAQs, troubleshooting etc if you select "view in browser" under manuals (the download seems to have a problem) then select "camera problems" under "troubleshooting" First see if anything there helps out (especially check the "EVF/LCD toggle button"). Next thing to try is removing any memory card if you have one inserted and see if this helps. If so then try reformatting the memory card. replace it if this doesn't help - try and borrow a card from someone to check that this makes a difference. Next try resetting the camera to all default values - this is easiest to find by looking under "reset" in the index of the manual - there is a setting in the setup menu of the camera that allows you to select this option. If that doesn't help then i would recommend contacting kodak (all details are on the link page) - they may have a solution for this problem that has not yet been added to the website Hope this helps - please ask for more info if not :)
Posted on May 20, 2007
  • 8 Answers
SOURCE: My Kodak Easyshare M1063 won't turn on
Try cleaning the contacts from the battery and the battery compartment of the camera. I had the same problem and this fixed it, it seems to be a common problem.
Posted on Aug 15, 2009
duane_wong
  • 6826 Answers
SOURCE: Kodak EasyShare M340 Digital Camera
Maybe, the batteries need to be changed to new ones.
Try to use Li ion batteries as recommended by Kodak.
Posted on Jul 23, 2010
lock123
  • 6831 Answers
SOURCE: kodak easyshare ls743. lens wont retract. camera error #E45 shows on screen. battery is fully charged.
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Dec 14, 2010
I just opened a brand new SD card and tried to use it with my P850, but when I insert the memory card it says "Memory card is unusable. Insert new memory card." I've tried formatting and...
If you just purchased this camera, you can try phoning place of purchase or make a trip there. It sounds as if the software in camera may be messed up.
Sep 18, 2011 | Kodak EasyShare P850 Digital Camera
Wont turn on and lens wont extend. Put in new fully charged battery but still nothing. Can hear motor but nothing works.
This is may be a camera battery problem or a lens error. Try Li-ion batteries first and see if anything better
May 19, 2011 | Kodak EasyShare P850 Digital Camera
Flash doesnt always work and lens retacks when you turn it on
Flash always draws more electricity to charge the big capacitor, the main flash's component. When battery getting too low, camera will turn itself off. Try it again with freshly charged battery or you may need to replace Li-ion battery. A cheapo third party's battery will do.
Good luck
Mar 14, 2011 | Kodak EasyShare P850 Digital Camera
My Kodak EasyShare P850 Digital Camera won't turn on
Spray a littlebit of WD40 or contact spray round the powerswitch, after removing the batterie and work the switch a number of times.
Feb 24, 2011 | Kodak EasyShare P850 Digital Camera
New battery the lens is out camera wont turn on
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 14, 2010 | Kodak EasyShare P850 Digital Camera
Battery is charged but camera won't turn on
Dec 14, 2009 | Kodak EasyShare P850 Digital Camera
My P850 Kodak camera turns off / on in
P850 is no longer repaired since no longer produced.
If under warranty they will exchange you camera to a brand new one.
If not under warranty KODAK offeres a Trade up. You can chose any new model available in stock and receive 25-30% off.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 10, 2009 | Kodak EasyShare P850 Digital Camera
My P850 will not turn on. It opens the flash and a motor sound and thats all. Have tried new battries nothing.
If your cam use AA batt.:
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Contact KODAK:
Nov 01, 2009 | Kodak EasyShare P850 Digital Camera
P850 Battery Problem
clearly an issue with Kodak. sounds like they erred with the firmware.
Jun 04, 2007 | Kodak EasyShare P850 Digital Camera
Kodak EasyShare P850 Digital Camera Logo
170 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
