Question about Brother Office Equipment & Supplies
How do I get the ? and / key to work I get : and ; only model EM-530
  • Brother Master
  • 3,594 Answers
Go to brother.com, click on support you will find a manual with pictures there.
DickyO
Posted on Jul 06, 2010
How do I reset?
Every model is different, try holding down the margin release key while powering up.
DickyO
Jul 28, 2015 | Brother Em 530 Electronic Typewriter...
How to reset the margins on Brother EM-530
On most electronic typewriters you change the margins by pressing the code button and holding down the press r margin or l margin on the key board. You want the carrier to be where you want the margin set. To set margins beyond the right or left margin move the carrier to the margin and press margin release to go past the margin. Then press code left or right margin.
Jun 30, 2014 | Brother EM-530 Typewriter
I am not able to type the @ symbol on my Brother typewriter. Model #EM-530. I have tried everything it is driving me crazy. Thanks for your help!!
If it is typing the alternate symbol on the key you are in KBII. The code key with the key in the top row labeled KBII will get you out of that mode.
DickyO
Aug 09, 2011 | Brother EM-530 Typewriter
Where is the 1/2 key on a bem 530
Go to BROTHER.COM, click on typewriters, poke around there you will find a manual.
DickyO
Jun 14, 2011 | Brother EM-530 Typewriter
EM-530 - suddenly the "j"
First, be sure you are using a Brother compatible daisywheel. Some other manufactures' daisywheels "look" the same but the charters are in different order, so they will not function properly.
If you have not changed the daisywheel, the next thing to check is that the wheel is correctly installed. The easiest way to check it is to remove and reinstall it. To do that;
1. Open the top cover.
2. On the right side of the hammer (the metal piece that strikes the daisywheel) there is a small lever (see attached figure). Pull that locking lever towards you to release it.
3. Remove the cassette that holds the daisywheel.
4. Reinstall it, making sure that you lock the lever towards the paper roller.
5. When you close the top cover the carriage (otherwise known as the print head) will move to one side and do a procedure known as "Homing."
6. Test the machine. If it is still mistyping, continue with the next part. Continued in part 2
Dec 19, 2010 | Brother EM-530 Typewriter
How to use the margin release for Brother EM-530
Is Margin Release on it's own separate button on the EM-530? If so, then to move beyond a margin:
  • Use Return or Tab to go to the left or right existing margin.
  • Touch Margin Release.
  • Use the Backspace or Space bar to go beyond the margin in question.
  • If you want to set a new margin, then go to the location you want to have it and touch the Left margin or Right Margin button.
Some models may require the CODE key to access one or more of these functions. If the function name is not printed on the top of the key, but on its front or on the surrounding plastic above the button, press and hold the CODE key while touching that button (just as you hold the Shift key to type capitals). The CODE key might possibly have a different name; chances are it's color will match the functions it works with.
Jan 05, 2010 | Brother EM-530 Typewriter
I need manual for brother EM-530 typewriter
Go to http://www.brother-usa.com/typewriters/. Click on "Manuals." Select "Typewriters", then select your model number in the drop down boxes. Click on "View download." Click on the "Users Manual - English" and the manual will open in Adobe as a PDF file. Print it or save it to your computer for future use.
Hope this helps!
Jay @ www.granadahillsbusinessmachines.com
Apr 17, 2009 | Brother EM-530 Typewriter
HELP PLEASE!!!!
I just talked to A Brother Customer Service Agent, I have a EM-530, and was having the same problem with my keys and symbols. Turn off your typewriter, hold down your Code, Shift and Tab key at the same time. Keep holding them down while you turn your machine back on. This will restore your factory settings competely. You will have to change your margins and tabs to where you like them again. If it continues to not type the write symbols, push code and the letter "K" and watch the upper left lights with roman numerals I II & III (KB is under the numerals), when the light is just on roman number I, let up the code key, turn off for ten seconds and then turn it back on. The keyboard has now reset and all should be well.
Mar 11, 2008 | Brother EM-530 Typewriter
Margin Resetting
position the carrier where you want the margin and press the left or right margin key. Lawrence
Feb 08, 2008 | Brother EM-530 Typewriter
15 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
