Question about Apple iPhone 3G
My iPhone will not recharge after running out of
Three times now, after being completely drained of battery power, my iPhone has taken extraordinarily long to charge to the point where I can turn it on. On the previous two times, my iPhone only was able to be turned on after several hours of charging. This time, it's been over 12 hours, but I am still unable to turn it on at all.
My iPhone didn't get wet or damaged, it simply ran completely out of charge during use. I have verified that my charger is working.
Is this a known issue? Is there something I can do other than charge it and wait?
Thanks for any insight you have!
  • Lauren Chang Jul 06, 2010
    Thanks so much for the suggestion, chiefmecha! That's just what I would have done, but the problem was actually resolved right after I posted this.
    Here's what happened, for anyone else experiencing this:
    Apparently, there was some sort of crash and the phone turned itself off. The fact that the timing coincided with me running out of batteries may have been coincidental. While I had tried to reset it (by holding down the home and the power button at the same time), I guess that I just hadn't held the buttons long enough because a coworker just got it to turn on by holding them down a bit longer. Since the phone will not charge when it has turned off due to a crash, it wasn't actually charging for the last 12 hours, like I had thought.
    For the record, two of the three times that this has happened, the last thing I did was use the video function. Maybe that's the culprit?
    Nope, I haven't jailbroken it. But I appreciate knowing about the complications that can arise from doing so!
  • 600 Answers
From what i see here, this could be a battery issue, you can have your iPhone's battery changed, if you said that the phone have done this twice already and this would be the third time, I could tell its battery problem.
Also it could be software or firmware issues,.
i would recommend that you bring your iPhone for immediate repair, I cannot recommend also dismantling the unit yourself, because the iPhone have so much delicate and sensitive parts inside and if the person that would dismantle it have no experience at all, may lead to more serious damages.
Posted on Jul 06, 2010
Testimonial: "Thanks chiefmecha!"
  • manuel oliva
    manuel oliva Jul 06, 2010
    I would also now suggest that you have your iPhone restore or updated in iTunes, I will definitely say that it might go back to its previous state, the phone may have some errors already in its sytem.
    i strongly recommend that you restore or update your phone immediately or as soon as possible,
  • manuel oliva
    If you have jailbroken your phone (that is a hack or unlock override) could be an issue using video, also if you have some apps that directly work with video(or anything that uses the camera) you may try uninstalling the app first and observe for a couple of days, some app releases today still have bugs in them specially when they are running on higher firmware version on iphone.
My iphone 3g is having some charging problems. sometimes when i'm charging it, it just stops charging. the only way i charge it now is i put it on plane mode. any suggestions? I'm on a jailbroken and unlocked 3.0 iphone. Thanks in Advance. I'm really worried now.
Posted on Jul 10, 2010
  • manuel oliva
    manuel oliva Jul 11, 2010
    I suggest you restore your Iphone again, and jailbreak it afterwards, your problems is i guess program malfunction.
Should I allow the power pack to run completely down before recharging?
There are a couple schools of thought on this subject. I work at a battery store and usually tell customers that they will get more cycles out of their battery if they only drain it to about half and then recharge. In my opinion you're doing the best thing for your battery. Lithium Ion batteries dont like heat and they shouldn't be drained all the way down.
Jan 29, 2015 | Cameras
How long should it take to recharge my iphone 4 brand new battery ?
The first two or three times, don't look, but normally, when you use a 1 A (1000mA/h) charger, within 4 hours. I don't like to use the iPad charger that can deliver 2 Amps, because it will heat up the battery. And the wormer it gets, the sooner you need a new battery.
But, if you want to find out the quality from your battery, just visit the genius bar in an Apple store. They test it for free, and also can point out if there is an app consuming too muck power. I went in with my iPhone 4 and they found an older firmware version. They put in a newer firmware (not the iOS) and since then it is running 2 or 3 days with one charge, with a 4 years old battery. Before I went in, the battery would drain in less than 6 hours.
Sep 30, 2014 | Apple iPhone Smartphone
My iPhone battery drains quickly
Hi, many things can contribute to battery drain, what model and IOS do you have?
Oct 31, 2013 | Cell Phones
I have an HP ProBook 6445b laptop. This has happened twice. Battery worked fine, one day drained completely, then wouldn't recharge. Got a new battery... same thing... worked fine, drained completely,...
Before you installed your new battery did you fully charge the battery. If you do not do that you run the risk of burning out your battery cells.
If you can go into your setup when the computer first comes on, go to drop down menu tabs until you see something for the battery. You can run the this program so the battery can get use to the amount of time you spend on the computer.
Mar 27, 2011 | Computers & Internet
I have a new refurbished kodak easyshare c160 -- the camera will not last but for one or two pictures without completely draining the batteries. i have tried about 4 new sets of photo batteries....is this...
Solution: As digital cameras become more advanced and include more features, the power needed to keep them functioning has also increased. That means that typical alkaline batteries likely won’t do more than power your camera for a few shots before running out of juice. Sometimes, your digital camera may not power on at all if the inserted alkaline batteries aren’t fully charged or powerful enough. Rather than carry along dozens of alkaline batteries for a single photo shoot, you can save money by purchasing rechargeable NiMH (nickel-metal hydride) batteries. Rechargeable batteries can be purchased with a charger that you plug into a wall outlet, and they fully charge in one to five hours depending on the charger and the type of batteries you’re using.
If you’re already using rechargeable batteries but are experiencing short battery life with your digital camera, it’s likely time to replace your rechargeable batteries with new ones. Depending on the number of charging cycles you perform (how many times you discharge and recharge your batteries), rechargeable batteries typically last for two to three years before they no longer hold a full charge. You may also ensure that you’re charging your rechargeable batteries directly before use. As batteries sit unused for extended periods of time, they automatically lose some of their charge.
There are many ways you can conserve battery life while using your digital camera, too. For starters, if your camera has a viewfinder in addition to an LCD, use the viewfinder to frame your shots and turn the LCD off because LCDs draw a lot of power. If you prefer to use the LCD, you can still conserve battery life if you refrain from looking at each picture on the screen after you take it.
Jun 13, 2010 | Kodak EasyShare C160 Digital Camera
Power failure for BOSCH PSR 1440 Drill
Usually the problem is in your battery, they develop a memory, they will only charge to a certain point. This can happen when the battery is recharged when it is not completely dead.
The key is to let the battery go completely dead, before recharging. I will wait till the battery is dead, then tape the trigger down and let the drill run till it won't move any more.
Sometimes you can reverse the battery memory, by doing the above, but when the battery is that bad, you might need to start with a new battery, and make sure it is completely drained, before charging it.
Wish you the best of luck.
Sincerely,
Paul Gibson
Apr 09, 2010 | Bosch 14.4V Brute Tough Drill Kit
I HAVE 18/24V DEWALT NI-CD BATTERIES THAT LOSE CHARGE CAN THEY BE REPAIRED, THEY DO NOT HOLD CHARGE CAN SPARES BE PURCHASED OR BATTERIES EXCHANGED
completely drain all the batteries by taping the on switch and, letting the drill run until it stops.
then recharge again do this three times for each battery ( these batteries have a "memory" and, only recharge to the level of last topoff if this does not work the chemicals in the battery are depleted and, must be replaced they can be purchased from Dewalt.com
Sep 14, 2009 | Drills
Disney Pix Micro Digital - stopped working after 10 minutes
The type or memory in the camera requires a charge in order to store data. So if you have any pictures on the camera it will constantly be pulling a charge from the battery until the battery is completely drained. If you have this problem even with a brand new battery it's possible that the memory may be corrupt and needs to be cleared. To do this just remove the battery and press both buttons several times each to make sure that the camera is completely discharged, replace the battery with a brand new battery and try again. If that fails I'd get in touch with customer service for a replacement.
May 18, 2008 | Disney Pix Micro Digital Camera
Camera not working
change batteries try lithiums or rechargeables. these cameras drain batteries quite often after 5 pictures are taken and generally after one video
Dec 25, 2007 | Samsung Digimax S630 Digital Camera
IPhone Battery power Problems
No, my cousin has one and it works fine, but remember if your battery isnt fully discharged it wont last as long. before you go just charging it all the time you should everynow and then let it run out before you recharge it.
Aug 02, 2007 | Apple iPhone Smartphone
Apple iPhone 3G Logo
499 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
