Question about Ariens Lawn Mower Universal Solenoid Starter Replaces ARIENS 03551000
What wires go where?
Someone else took the solenoid off of the lawnmower to be replaced with a new one. The person that did that does not remember what wires go where and I have never put one on so I'm not sure where they go. I have three black wires and one red (which I know is positive) and one blue and one white.
  • 18 Answers
You should have a big black wire that has a red stripe going through it. This wire will go on the picture as shown to the top left terminal and travel down to the starter. You will have a big red wire and there may be a smaller red attached with it. This or these wires will go to the top right terminal. The white wire should be a small gage wire and will go on the front left terminal. There should only be one more single black wire with a female terminal on the end of it where it will plug into the front right terminal on the solenoid. The remaining black and blue should have male ends on them and discard them, they do not plug into anything.
Posted on Jul 08, 2010
I own a 1985 honda elite 150. I tried to started with no success. I was told that it needed a new battery which I replaced. The battery is fully charged. The light beam is bright when i turn the key on the...
Buy you a $10 volt ohm meter. Set it on DC Volts 20 volt scale or that range. Find starter solenoid place leads on small wire connectors have someone try and crank when they do you should have 12 V. If you do have the voltage you may have bad solenoid contacts. Place meter test leads on large wire contacts if you have 12 v there when the person tries to start you have open contacts on solenoid. If you do not have 12 volts on meter when person tries to start place one lead on one of the large wire post and the other on neg. Terminal on battery if you now get 12 v you probably have a bad starter.
Jul 23, 2017 | Honda CG 150 Titan KS Motorcycles
I have a 98 saturn sw. Replaced the alternator, there's a wire, thick looks like it goes to the starter? Didn't take this wire off, don't know where it goes. possibly called the B wire. Alternator reading...
There is a heavy red wire that connects to the only terminal on the back of the alternator. The starter should have a smaller purple wire connected to the starter solenoid. A red (positive) battery cable connects to the top terminal of the starter solenoid. There also may be smaller red wires connected to the solenoid at the same connection where the heavy red battery cable connects. Hope this helps
Sep 01, 2010 | 1998 Saturn SL
I have an 1989 jeep comanche. It had an ignition switch bypass. I took it off and replaced the switch and the relay. If i touch the positive battery cable to the green starter wire on the relay it...
on the relay there will be a small wire that gets power when you turn the key to the start position
find that wire and connect it to the small terminal of the starter solenoid
then if you get it right , when you turn the key to start, power will get to the starter solenoid , energize the solenoid and the starter will engage
Jun 03, 2017 | 1989 Jeep Comanche
I have a 2000 pontiac grand am 2.4 liter and took the starter off and cant remember how the wires go back on the starter
THE RED POSITIVE BATTERY CABLE WIRE AND THE SMALL RED FUSE LINK WIRE GOES TO STARTER SOLENOID POSITIVE TERMINAL.THE PURPLE WIRE GOES TO STARTER SOLENOID S OR SWITCH TERMINAL.
Jun 03, 2010 | 2000 Pontiac Grand Am GT
Riding lawnmower will not start with key. I tried a new key switch and a new solenoid. I checked all safety switches and they checked out OK. I don't know if the wires for the solenoid are hooked up...
Depend on the make and model of the mower....the safety switches usually are the seat, pto, shift lever, brake and clutch. If any of these are bad...the switch won't work. Can you cross the starter and have it start? With these safety switches....you can't just disconnect them to bypass. Most require a loop and running a wire from one side of the switch to the other will usually help you find the one causing the issue.
The solenoid comes in about 4 different models. Some ground to the frame and some don't. Not all key switches are the same either...we stock over 25 different switches and I could show you 7 that look identical but are different.
Personally I would start testing from the starter and work my way back...starter, solenoid, safety switches, starter switch. www.nnyparts.com
May 30, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
1999 mitsubishi montero sport wire on starter
all this is a a reference wire that tells the solenoid to kick on.....If it can make it anyeasier on your part.....invest in a female spade terminal.(wire connector) and test fit it on the new starter....make sure it fits snuggly on the new one....then simply cut the wire from the old starter...wire crimp the new one together...reinstall starter....install wires...and VIOLA!!! If i can help ya with anything else get back to me.... I HOPE I COULD HELP!!!
Nov 16, 2009 | Car Audio & Video
Need to change transmission
make sure u really need a new transmission. my D4 light kept flashing periodically and then would hesitate wen accelerating also it slipped wen exceeding over 40 mph. i took it to a transmission place and all he had to do was replace the solenoids. it also could be the computer or wires. either way it is MUCH cheaper than replacing a new tranny. make sure it is a trustworthy person, a crooked one will try to tell u to replace it even if u may not need to.
Sep 29, 2009 | 1992 Honda Accord
The car has power but starter just clicks when turn the key its not the starter i took it out and had it rebuilt and replaced the battery any help would be very greatful
The solenoid for the starter may have bad power contacts. Older GM starters had the solenoid mounted to the starter itself. If this starter has just a heavy wire going to it, trace the wire to the solenoid--listen for the click while someone turns the key. Check the heavy wire on the other side of the solenoid which goes directly to the battery positive post. A voltmeter or test light is a handy tool for testing for voltage around the solenoid and the starter terminal.
Aug 06, 2009 | 2003 Cadillac Deville
1989 Firebird 2.8 If you are looking at the abck of the starter where does the single wire go right or left side?
Facing the solenoid on the starter, the small (trigger) wire goes to the terminal on the right.Be careful that it does not touch the larger battery terminal and remember, the cover on the solenoid is plastic...tighten too much and you can break it.
May 30, 2009 | 1987 Pontiac Firebird
Ariens Lawn Mower Universal Solenoid Starter Replaces ARIENS 03551000 Logo
263 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
