Question about Denon AVR-3805 Receiver
Video Monitor Out issues
I have hooked my Set top box video to the 3805 using a video (yellow) cable and am trying to get the signals from the Reciever via the component on to my projector... I am not able to get the signals... any settings that I missing out on....?? Thanks.
  • nasly Apr 18, 2008
    HDMI direct from my DVD Player.
  • 151 Answers
MOST AMPS NEED TO BE TOLD TO SWITCH ON THE VIDEO UP SCALEING TO PASS THE SIGNAL ON TO YOUR PJ.I NOTICED YOU HAVE AN HDMI LEAD ON YOUR DVD PLAYER ,DO YOU HAVE A HDMI CABLE FROM YOUR AMP 2 YOUR PJ OR IS IT COMPONENT AS MOST AMPS WONT TAKE THE SIGNAL BACK FROM HDMI 2 COMPONENT ONLY THE OTHER WAY ROUND.
HOPE THIS HELPS YOU NASLY
CABLE GUY.
Posted on May 20, 2008
  • 4,234 Answers
Just to be clear, what is the input you are using on the projector?
Thanks,
Dan
Posted on Apr 18, 2008
How to hook up an old RCA 14 inch tv to DVD
Easy. All you have to do is to make sure that the DVD player is old the older types that have RCA connectors at the back of the DVD. Latest DVD may have RCA connections but I am not sure if it can send digital signal directly to the analog TV. Try this and see what happens. if your TV is old and does not have Component Video (Red/Green/Blue) RCA sockets (input) but has standard Pal/NTSC sockets (Yellow/Red/Black) hook up the yellow, red and black plugs into a DVD (out) RCA sockets of same colour, then hook up the other end of the cable in the (in) RCA sockets at the rear of the TV.
If it works, then all is well. If it doesn't work, then you have to hook up the cable from the DVD to the (input) RCA sockets of a Set Top Box, so that the Set Top Box will convert the signals for the analog TV. Just pay attention to the inputs and outputs at the rear of them.
On your DVD - plug the RCA cable to the (OUTPUT) RCA sockets. On the Set Top Box - plug the connectors in the (IN) RCA sockets and then use another cable connected to the OUT RCA's of the Set Top Box, then connect the other connectors to the (IN) of the TV RCA sockets. Hopefully you get the picture on what I mean.
Sep 01, 2014 | Televison & Video
I have a Sony Bravia XBR 4 LCD. I connected a RCA cable to my Denon 3805 monitor out and RCA to the Sony video 2 in.I want to set up the Denon using the Sony as a monitor to set up my speakers. The screen...
Make sure you didn't get the video line out confused with one of the audio lines.
If using composite video the connection should be yellow and the left and right
channels should be red and white
May 16, 2011 | Denon AVR-3805 Receiver
My 61in rca scenium is saying unuseable signal and there is no sound or picture
For whichever input the monitor is currently set to (i.e. Input 1, HDMI 2, etc.) it is telling you that the signal it is receiving is unusable. The question first is the monitor set to the input you truly wish to use?
If it is, then check the cabling between the monitor and the source device (cable/satellite box, game box, etc.) If you believe it the source is working, try swapping the cable or using a different input.
If that fails, try hooking up the source to another monitor and seeing if it works there. If you have a long cable run, try higher quality cables, the video signal can degrade over long runs (> 25').
It sounds like the monitor is receive *a* signal, just not one with enough data to be useable. Probably a bad cable.
May 06, 2011 | RCA Televison & Video
No problem - I hope!!!! Just need to know if Direct TV is compatible.
Direct TV is compatible with all TV's. Just requires the proper cable connections
Mar 10, 2011 | Televison & Video
We have our cable box hooked up to the tv and get a great picture but no sound. The previous owners had a stereo system hooked up to the tv and we are simply trying to get any sound at all. We went into...
Ok, I need more verifications:
1) Your TV is Fujitsu Siemens PlasmaVision P42VHA40 Monitor which does not have tuner? If not, please provide the make and model of the TV.
2) What kind of cables you are using to hook between the cable box and the TV? HDMI? Component video (Red, Blue, and Green cables withe RCA plugs)? Composite video cable with Yellow RCA plugs?
3) Are you trying to get the sound to come out off the TV speakers or through the stereo system?
Feb 03, 2011 | Fujitsu Siemens PlasmaVision P42VHA40...
Cannot get a signal. tried all the imputs.
I wish you would have said what your using for signal- cable, cable box, satellite ?
Cable- The lead screws into the cable in jack. Then auto program set.
Cable Box- Cable screws into "cable in" on box. It's best to use the 3 jacks colored RED-GREEN-BLUE,and red & white for Audio. These are known as Component Input. If your not using that way then you can use A/V input. These will have 3 leads,Yellow (video) Red (audio-R) and White (audio L). Either way,just make sure Component >Component or Video > Video and dont forget the audio. After your done just change your input on the tv (via) remote to which ever input you used.
Satellite- Is the same hook up as cable Box
Outside or Indoor Antenna- Connect to Antenna Input and Auto Program your set. It will know what your using.
Dec 04, 2010 | Sanyo Televison & Video
HOW I CAN USE M-15N MONITOR AS A TV?
Two choices: 1) get a tuner for your computer and watch the live or recorded show the monitor (Similar to watching a download from the networks or HULU.com)
2) get a set top tuner with an s-video out. Connect an S-video cable to a video cable signal adapter (Mini-dim 8-pin connector to S-VHS and CVBS jack) and connect that to the monitor. Then hook up speakers to the set top box.
I hope this helps.
Jun 24, 2010 | Neovo S 15V 15 in. Flat Panel LCD Monitor
What is Monitor Out on 42'' Hitachi plasma TV (42HDT50)
Monitor Out connects audio and video signals to an external monitor with corresponding inputs as noted in the document.
Mar 07, 2017 | Hitachi 42HDT50 42 in. HD-Ready Plasma...
I have this DENON AVR4800, and there is no osd. I plug the yellow cable in dvd input, and outmput in DENON monitor 1 Yellow also. I try to reset the unit and that do not solve my problem, please help....
You need to use the monitor output on the denon and go to a video input on your tv, be sure the tv is set to the video input you plugged into on the tv input, then take the denon remote and hit the setup button, should show a on-screen setup
Mar 09, 2009 | Denon AVR-3805 Receiver
Recording out of my Denon
No, if you have nothing on the tape out, there is a problem I'm afraid with the preamp section of this receiver. the tape out should always be on, no mater what mode is being used. Good Luck
Jun 19, 2007 | Denon AVR-3805 Receiver
Denon AVR-3805 Receiver Logo
87 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
