Question about Toshiba 51H84 51" Rear Projection HDTV-Ready Television
Tried to set up DirecTV, DVD, and Roku through a HDMI 3 port switch to a Toshiba 51H84 Problem(1) With the above setup the screen setting will continue to come up condensed and will have to be reset to full screen each time the TV is turned on. Problem(2) When I tried to go back to the Color Streaming hookup, I am getting picture but no sound. I can not access the MTS setting to change it to stereo, if that is the problem. Am not able to access MTS audio setting so I do not have sound with a Color Stream hookup.
SOURCE: HDMI
Use the input button on your remote control... as you press input you should see VID 1, VID2, COMP 1, FRNT and then DVI... When you get to DVI you should see your picture..
Posted on Oct 19, 2007
zaids
  • 456 Answers
SOURCE: HDMI quit working with store bought DVDs
so you have to update a new firmware and then it will be ok
Posted on Dec 20, 2007
  • 2427 Answers
SOURCE: Audio Problem - Can't turn the 'stereo' feature on the MTS
It aint your tv,, if it was it would have been on all chanels,,, My thoughts would be to call the cable company....
dont bother to fiddle with your tv...
if it was your tv it would have been constant and on all channels.. not just 3 - 4
Posted on Jan 11, 2008
MikeMaierTV
  • 206 Answers
SOURCE: Audio Problems
First for the Toshiba could the SAP (Second Audio Progam) be turned on this will somtimes cause the audio to drop. And are you using the onboard tuner or does this set conect to a cable box?
Then for the Panasonic the most common problem for your fault would be the convergance curcuits are shorted and need replacment, or some other componet may be loading down the set and forcing it in to shut down, Tv's will do this to prevent further damage
Posted on Feb 13, 2008
IFIXALL
  • 868 Answers
SOURCE: no audio brand new toshiba 42xv540u
speakers are muted.
Posted on Jun 10, 2008
Setting up with code
You can use Roku Streaming stick to any of the television with HDMI port connection. You can directly connect the Roku Streaming stick to TV HDMI port. In case, your Tv doesn't have the HDMI connection then use HDMI extender cable.
Follow the given steps for setting up the Roku Streaming Stick,
1. Once you connected the Roku streaming stick to your Tv, the first screen will be "Language setting". 2. Scroll down or up to select your preferrence language.
3. Go to settings and select your internet connection name from the list of network.
4. Then enter the network name and password.
Note: Connect the Roku device, TV and smartphone in same network.
5. Once you connected the internet, your streaming stick will automatically download the latest version of software.
6. Create a Roku account by entering Roku code link that displayed on your TV.
Once the above steps are completed, you Roku streaming stick will ready to use. For more information call us at 1-844-965-4357 or visit Roku Activation Code.
Jul 28, 2016 | Roku Streaming Stick
My hdmi input 2 gets a no signal blue screen. My Roku is hooked up to this port. have replaced hdmi cables and even got a new roku.
Sounds like you have done everything correctly and have covered all the angles.
Set Up and Troubleshooting is here. If nothing in that, contact them direct as the unit might be faulty. You did have verified power to the unit?
https://support.roku.com/hc/en-ca/articles/208754878-Roku-3-Model-4230-Setup-Instructions
https://support.roku.com/hc/en-ca/categories/200889378-Setting-Up-Your-Roku
Setting Up Your Roku Roku Support
Mar 18, 2016 | Polaroid Televison & Video
How do i connect my wireless Internet router to my proscan Smart TV
Go into settings on your tv & activate the wireless mode
Feb 11, 2015 | Computers & Internet
I am still lost
1.Turn it on.
2. If necessary, put batteries in the remote.
3. Turn on your TV and using the HDMI cable provided, connect the Roku to one of the HDMI ports on your TV.
4. If the Roku screen does not appear on your TV, press on the 'Source' or 'Input' button on your TV's remote. From the list, find and select the HDMI port where the Roku is connected to your TV.
5 Use the Roku's remote to set up your Roku.
Please read the set up instructions on the set up guide/manual that came with Roku.
Nov 16, 2014 | Roku Televison & Video
I only have on set of white, yellow & red receptors on back of tv. There is a set (entitled Video 2) on the side of the tv.1st - can I attach the Roku to the receptors at the side of the tv or2nd - i...
You didn't say which Roku you have, so I will assume you have a Roku 3 since it's the only one without RCA output jacks (the red, white, and yellow jacks you mention). You can return the Roku 3 and get a Roku 2. You can only attach the Roku to a switching box if 1) the Roku has the RCA outputs and your switch has A/V inputs. If you DO have the Roku 3, then you may be able to purchase a HDMI to RCA cable from Amazon http://www.amazon.com/HDMI-RCA-VGA-Cable-1-8m/dp/B002ZUI68G
Mar 03, 2014 | Televison & Video
I have a 1080p sens tv DVD combo. I tried to connect my roku and chromecast to it and only get no signal when either device is connected. Anyone know what is going on?
You have to set up the ROKU to connect to your router correctly. Try changing HDMI ports if you have more than one to see if it's a bad port or not.
Jan 08, 2014 | Televison & Video
Roku 3 hdcp
Hello... I searched the internet and found this. I hope this helps...
To resolve the "HDCP unauthorized. Content disabled" issue, try these steps:
  1. If you are trying to stream 4K Ultra HD content when you see the purple screen, review the instructions for setting up your Roku player for 4K. Go to the next step if you continue to see a purple screen.
  2. On both your Roku player and your TV or AVR, unplug each end of the HDMI cable.
  3. Power off your TV and your Roku player and unplug their respective power supplies.
  4. Reconnect both ends of the HDMI cable, pushing them firmly, all the way in.
  5. Reconnect your TV and your Roku player to their power supplies and power them on.
  6. Try viewing the video again.
If the above did not resolve your issue, try these additional suggestions:
  • Try a different HDMI input on your TV.
  • Try using a different HDMI cable (less than 6 feet if available), just to make sure the cable you are currently using does not have any defects.
  • If you are using an HDMI switch or AVR, try connecting the Roku player directly to the TV.
  • Try another TV, if possible.
  • If you are using a computer monitor, try using a TV, if possible.
  • Try using different Display Settings on your Roku player. You can find these settings under Settings >Display type.
  • If this is the first time you are seeing this HDCP purple screen after setting up your Roku player, ensure that your TV and/or AVR supports HDCP. Contact your equipment manufacturer for more information.
Nov 17, 2017 | Roku 3
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Jan 24, 2009 | Onkyo Audio Players & Recorders
No sound when playing dvd
HDMI may not output sound. Go into the setup screen of the DVD player and go into audio setup. Make sure you have it set for PCM or equivalent DIGITAL setting. If you set that and you still get no surround sound, you will have to use and optical cable between the receiver and the DVD.
Sep 06, 2008 | Audio Players & Recorders
Toshiba 51H84 51" Rear Projection HDTV-Ready Television Logo
205 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
