ebay or craigslist find a broken dryer for sale near you. I just replaced one of my customer old kenmore parts NLA I found it on craigslit $35. Just a suggestion cheers!
If the water is showing on the freezer side, more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt. Also note on the maytags these days they put a rubber piece called a duck bill on the bottom half of the drain which will also cause this over time. To access this piece you'll have to pull the machine from the wall and remove the lower panel and find the plastic drain and remove the duck bill.
In order to help you let me explain to you how the Nintendo zapper works. The nintendo zapper works by decetcing the light from your TV screen. When you "shoot" the gun the screen goes completely dark for a franction of a seccond display white squared where the targets are. The light emitted by the squares is picked up by the zapper only if it's pointed directly at it. What may have happened is that your nintendo zapper is not working propperly, to make sure of this try "firing" the gun at a strong source of light like a light bulb. If this doens't trigger the gun to work then youre Zapper is broken and sadly the product has been discontinued and they don't offer tech support for it anymore. Your best chance of fixing it would be ordering repair kits online or buying a new one.
Had the same problem on a whirpool drayer. Get our multimeter and check which
heat fuse is broken. Take that one out and throw it in the floor until you have
conductivity again. Clean drayer vents and heater. This worked for me, good
luck. http://www.youtube.com/watch?v=UuFQOuSlzlw
No heat may mean that one side of the 240 volt circuit breaker is tripped or one fuse of the 240v circuit at the fuse/breaker box is tripped. Just replace/reset the fuse or breaker which ever you have. Dryers will have controls working but not heat if it happens to be that particular side of the 240v circuit that tripped or fuse burned.
