Question about Sony Xplod XM-1652Z Car Audio Amplifier
High distortion there is a jvc 200 watt car sterio in and 6 panel speakers factory and the subs are 12s 1200 watts peak with a 1000 watt amp hooked to it and the amp is only pushing the 2 subs the higher the volume goes on the sterio the more distortion
  • 631 Answers
The head unit may be rated at 200 watts but it cannot produce more than ~20 watts of real power per channel. There's no way that it can drive the high end speakers to a level that will be needed to compete with the subs on a 1000 watt amplifier.
Posted on Apr 19, 2008
Will the amp blow my speakers?
If you bridge the amp and get 1000 watts RMS and that is split going to two speakers then you will get 500 watts RMS at each speaker. If you have your amplifier on maximum gain it may blow your speakers, not because they are overpowered but because you might run into "clipping" issues running the amp at maximum capacity. Just to be safe I would dial the amp's gain down to 3/4 of the way to full gain. That should give you ample power and keep your amp from clipping and running hot.
Aug 11, 2015 | MTX Car Audio & Video
How do i bridge a 1000 watt amp to two 1200 watt subs
a sony 1000 watt rating is an exagerration. you will blow your 1200 watt speakers far before reaching sonys claim of 1000 watts
Jul 10, 2014 | Sony Xplod XM-1652Z Car Audio Amplifier
I have 2 12in kenwoods and a 1200 watt pyrimade amp, how can i hook these up to be the loudest
1st have your subs facing inwards towards the front of the car, not facing out the boot, This creates a better bass.
Wire 1 sub to one channel and the other sub to the other channel.
Turn down your gain as low as possible and then power everything up.
turn volume to desired loudness and then start turning up the gain slowly, if distorts a little turn in back down a notch.
avoid using bass boost, I agree it sounds great but it puts more strain on your amp and shortens its life.
after sorting out your gain, tweak all others until sound is bassy and clear with no distortion.
If you would like to use bass boost, turn on bass boost first, then up your gain etc.
Jan 16, 2013 | Pyramid PB915X 1200 Watts 2 Channel...
My stereo in 1997 chevy caviler is turning off and on when turned up to a high volume. I have a sony xplod 52 watt by 4 channel radio. With two 6x9 sony xplod 50 watt rms and 300 watt peak power in the...
Most likely cause is heat. The clearances behind the radio are often not sufficient to provde the proper air coolling that the higher power radios need. The heat sinks on the rear of the radio require a certain amount of air flow to dissipate the heat generated under high load conditions. If you add summer heat to the equation, you can have the radio going into thermal cutout to protect it circuity.
May 27, 2011 | 1997 Chevrolet Cavalier
What size amp needed with a sony explod player?
this bandpass enclosure is rated peak power at 1200 watts . what this means is that each subwoofer in the is peaked at 600watts to make 1200 watts . what your looking for is to power up the subs with rms continuous wattage . you need an amp that will put out 400 to 500 rms a channel to run this sub enclosure at 800 to 1000 watts rms to keep the speaker from blowing
audiopipe apf1801
71671968.jpg this amp will give you 1 channel @ 4 ohm x1 350 watts 1 channel @ 2 ohm x1 900 wats 1 channel @ 1 ohm x1 1800 watts you would have extra power for better subs with more power later but you get 900 watts which when connected right would mean 450 watts per sub be perfect for you . i sell this for $320.99 in my store can shipp any where in usa to contact me caraudioquestion@gmail.com
Oct 14, 2010 | Dual XINBP-210 Car Subwoofer
What wattage amp do I need to get good sound in a toyota corolla
Make sure it's a RMS 1200 wats not MAX watts also the Ohms of this speakers and them you can buy any amp. with the same RMS watts of your speaker and same Ohms of resistance.
Jan 27, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
I have 2 kicker l7 12s 4ohm speakers and was
Hello gonenutz14,
It depends on how you define the "best way". Driving each sub with a separate 750 watt amp will result in about 50 percent more power than having them share the output from a single 1000 watt amp. But with 2 amps, there's more wiring issues to contend with and the adjustments are more complex. The 2 750 watt amps will cost more than a single 1000. Plus if the 1000 watt amp is stable to 1 ohm, the power difference will actually be less than 50 percent because of the lower impedance. But if the 750 watt amps are also stable to 1 ohm and their outputs can be combined, we're back to 2 being better than 1.
I'd say that the simplest, most economical way is to use a single amp. If maximum power to the subs is the highest priority, and cost and wiring is not an issue, then 2 is better.
Hope this helps.
Jul 12, 2009 | Car Audio & Video
Is amp big enough for speakers
To run 2 subs, the amp would be a little small. The subs will run OK, they just won't be very loud.
It's usually better to compare and match up the RMS power rather than the peak power. The Sony XS-L10P5B sub has a peak power handling figure of 1200 watts, but the RMS is 300 watts. The Sony XM-ZZR3301 monoblock amp puts out 1100 watts peak, but only 330 watts RMS. They would work great together, 1 sub, 1 amp. But if you add another sub, each one would only be getting about 165 watts. They'd work OK, just not as loud as they could be.
Hope this helps!
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Repeated blown subs
Unfortunately some of these speakers today... DO NOT PERFORM up to peak as they should.The on logical reason for this to be happening it that the speakers are NOT very DURABLE and cannot take constant playing. I would recommend to L7 the can take alot more abuse than your average speakers. Good luck and thanks for using FIX YA
Mar 23, 2009 | Kenwood KAC-X401M Car Audio Amplifier
2 12" Hitron 600w subs in a BandPass box
Remember that driving a load with an underpowered amp will probably cause more problems than having a more powerful amp that is not running flat out. 200-300W amp would be ok, but I would suggest going for the biggest you can afford. If you crank up the volume on the smaller amp you will probably get a fair amount of distortion, which may actually damage the speakers. A larger amp will not give as much distortion for the same loudness/volume and give better control of the speakers for a tighter bass..
Oct 31, 2007 | Hitron 2 12in Subwoofers loaded in...
Sony Xplod XM-1652Z Car Audio Amplifier Logo
125 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
