Question about Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
My Robo kleen stop working at the end of last summer I have checked the power source the battery pack is working the electricty is going throught the electrical cord that works the vaccum.the power is going to the black control pack that is inside the Robo Kleen but it doesn't come out of the pack. It seems that the problem in in the black pack inside the unit I have not been able to check the Motor because the voltige doen not go beyond the Black packinside the unit respond please. Ken
  • 52 Answers
Sounds like you have found the problem. Change the Black Pack. Not sure the pack is available as a seperate part. Suggest you contact Robo Kleen for that info. http://74.84.137.218/website/manuals/RK01A.pdf
The Pool Tech
Posted on Jul 10, 2010
My robo kleen moves around the pool but has no suction so it won't pick up any debris
i had that problem, past year
open the motor check for rust stains on the round magnetic surface
i used a steel or copper brillo pad dry to sand down the surface
careful with those plastic motor screw washers to secure motor
Jul 27, 2012 | Smartpool Dolphin Robo - Kleen Above...
When I place my Robo-Kleen in the pool, it now only travels about two feet, rocking back and forth. Occasionally, it will go a few additional feet, but then stops. I also don't seem to be getting the...
I would first check for obstructions in the front and back wheel axles. Then, take the top grill off and make sure that the impeller is not jammed. It sounds more likely to me that you are having a problem with the pool cleaners gear box or drive system. If it is still under warranty, send it back to the manufacturer. If its not, you will need to have it repaired by an experienced pool repair person.
Jul 20, 2011 | Smartpool Dolphin Robo - Kleen Above...
Is there any way I can get a replacement wire for my Robo Kleen? Plug broke off end of wire that goes into power box.
You can try MaytronicsUS to get an answer straight from the manufacturer. If they offer the part you seek they can also refer you to a stocking parts dealer to purchase it.
John
Aug 15, 2010 | Smartpool Dolphin Robo - Kleen Above...
My Robo-Kleen, when I first turn on goes forward a couple of feet, then goes in reverse for a couple of feet then stops altogether. Fan is still working while the wheels are turning however when the wheels...
It sounds like your gear box has gone out. If that is the case, the pool cleaners not going to work until you replace the gear box. Unfortunately, this is something that only a professional can do. Just to make sure that this is the problem, you should first check the wheels for any debris or damage. Then make sure that you don't have any clogs or jammed/cracked hoses.
Aug 10, 2010 | Smartpool Dolphin Robo - Kleen Above...
What is the output amps on robo kleen transformer
Here is the users manual for these pool cleaners. You might be able to locate the information you are looking for there in the parts specification manual.
http://www.backyardcitypools.com/Pool-Cleaners-Automatic.htm
Jul 03, 2010 | Smartpool Dolphin Robo - Kleen Above...
Robo kleen stopped sucking
Make sure that your filter bag is clean and free of obstructions. You will also want to check your impeller to be sure that nothing has jammed it. A jammed impeller actually occurs pretty frequently on these automatic pool cleaners.
Apr 24, 2010 | Smartpool Dolphin Robo - Kleen Above...
Wondering if a robo-kleen robotic pool cleaner can be used in an inground pool?
You will find it won't climb walls, but should clean just fine on the bottom area.
S. Christian dansker01@msn.com
Jun 05, 2009 | Smartpool Dolphin Robo - Kleen Above...
Robo kleen stopped working, motor starts but it does not move
Hello, I think I had the same problem with mine : the filterpump worked, but robot didn't move. I opened it up and the problem seemed to be that the pin which locks up the gear wheel to the axle of the front wheels had broken into three pieces. We inserted a new pin (nail, screw etc) and the Robo kleen works just fine again. Maybe you should check this is also the problemwith yours. Good luck !
Apr 09, 2009 | Smartpool Dolphin Robo - Kleen Above...
Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner Logo
502 people viewed this question
Top Smartpool Pool & Spa Experts
Robert Plante
Thomas Perkins
Thomas Perkins
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
