MP198 Paper feed Problem alarm E 3 some problem in
MP198 Paper feed Problem alarm E 3 some problem in the white Plastic gear near the roller
Soulvisitor
  • 1113 Answers
SOURCE: Paper feed occasionally gets stuck 1/3 way through.
Clean "rollers" with slightly damp cloth
Posted on Dec 27, 2007
  • 3 Answers
SOURCE: paper feed broken
You broke a part. It is a low end machine. The repair will cost close to the repalcement cost of the machine. I would replace it and start with a new warranty.
Posted on Mar 21, 2008
HockeyMom10
SOURCE: paper won't feed, HP printer dock series 3
I had this problem (among many others with my printer). I found that just cleaning the front roller with a damp paper towel fixed it. Wipe it carefully and let it dry before reloading the paper. The rubber on the roller seems to lose it's ability to pick up the paper if it sits unused for any length of time, so wiping it with warm water and drying it works. Good luck. Lynette
Posted on Oct 07, 2008
frcs68
  • 1605 Answers
SOURCE: Dell Photo 966 Printer - not feeding paper/rollers not turning
the dell website may help you to get some answer
http://support.dell.com/support/topics/global.aspx/support/product_support/product_support_central?c=us&l=en&s=gen&SystemID=PRN_ALL_A966
if not you can get online tech support. one on one. it is free.
Posted on Oct 22, 2008
  • 77 Answers
SOURCE: lexmark x4270 fax machine receives faxes but won't feed paper
Try cleaning the rollers in X4270 printer. You may need to clean the scan lens and the white roller.
1. Unplug the power cord and the phone line from the wall.
Open the control panel.
2. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
3. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
4. Reinstall the white roller.
5. Reconnect the power cord and the phone line.
Next, try to make a standalone copy and let us know the results.
Posted on Apr 27, 2009
13.2 paper jam/open tray error, but its not. It doesn't make the right sounds when initialising, no motor running.
Hello There,
After working with HP for quite sometime,
here is what i recoimmend.
1.Ensure that paper trays are loaded properly, so that paper can feed from the tray
2.Check the input area for obstructions, such as paper in the path or visible damage to the paper path near Tray 1.
3.Remove the print cartridge and lift the green handle attached to the metal plate underneath to check for paper in the paper path.
NOTE: Try swapping the tray and print cartridge with one from different printer, same model. Determine if issue follows the tray or the print cartridge.
4.Ensure that paper is feeding correctly from the appropriate tray (try using a freshly opened **** of paper).
a.Inspect the pickup assembly by removing the paper tray in question to look inside the printer.
b.Locate the rubber roller with a purple, plastic hub (paper feed roller).
c.Locate the paper pickup assembly that is directly behind the paper feed roller. The paper pickup assembly consists of a shaft with four half-moon shaped rubber and white plastic rollers attached to it.
d.Rotate the shaft to locate the half-moon rollers and ensure that it turns easily.
e.Locate the black plastic coupler shaped like a dog bone that is immediately to the right of the shaft .
f.If either the pickup assembly or the coupler is missing or damaged, the printer will need to be serviced.
5.Do not fan paper to separate, bend the **** into a U shape to break the sheets free from one another.
NOTE: If the steps listed in this document do not return the printer to a READY state, service may be required. Contact the HP Customer Care Center for more information
Please feel free to leave a testimonial if this works and please do not forget to click 4 thumbs.
Cheers!
Mar 22, 2011 | HP LaserJet 4000 Printer
Im using ricoh 2045..Paper jam occurs at point A1 (the lever the drops to remove the paper) . I have noticed roller A1 and registration roller doesn't rotate. When i remove the paper and close the covers...
this is not a thought I am 100% sure and give you the correct solution:
problem with the paper feeding section is dusty or due to developer drooping
1. Open the developer unit and check the rear side developer unit bush one or two bush are faulty
and drop the developer.
2. remove all paper trays with remove the four each screws
3. Remove the toner collection bottle
4. Remove the right side cover.
5. Remove paper left roller plate.(show in the picture)
6. Now remove the first tray paper feeding section(is a complete unit included paper feed rollers motor and clutch and gear section)
7. Clean the drooped developer from all gears and roller and motor section
8. remove the second and third tray paper feeding section and doing the same.
9. now fix it all
10. replace developer unit bush witch are faulty or if you don't have yet cut a plastic sheet and past the upper side of first paper feeding unit gears witch are don't disturb the paper path and stop the developer drooping on the gear good_help.pnggood_help_0.png
Jan 27, 2011 | Ricoh Aficio 450 Copier
The feed rollers keep jamming and feeding in at an
phyical inspection of the rollers for a jam or a roller out of its socket would be my first look.
then inspect the plastic gears at the side of the rollers as these will crack and are hard to spot untill they break completely.
Always check your printer properties first and make sure it is set for the correct type of paper.
Unfortunately if has broken gears it will be less expensive to replace than repair.. Regards
Jun 21, 2010 | Epson Stylus Photo R300 InkJet Printer
Line feed problems. give 1/2 line feed. document feed sounds like it needs 'oil'
While HP may use a little white grease on some plastic gears, oil is not normally used. Most likely some debris such as paper dust, or part of a label, or a stray staple is jamming the mechanism.
If it's all clean, then I would look closely for a damaged gear of some sort.
Most printers rely on rubber feed rollers of some sort to pick the paper from the paper tray, then more rubber rollers to pull the paper through the mechanism. If the printer is relatively new, the rubber rollers should be in good condition. As the printer ages, these get less rubbery and more slippery, and wear out, leading to feed problems. Further, any contaminant such as oil, white-out, or a sticker on the feed rollers will render them useless. Printer technicians change a lot of these rubber rollers.
Oct 16, 2009 | HP Officejet 7210 All-In-One InkJet...
Incapable of feeding paper.
There may be debris blocking travel near the feed roller, or the feed roller is not turning (check for broken drive belt or bad gearing).
Jul 18, 2009 | Dell 810 All-In-One InkJet Printer
Lexmark x4270 fax machine receives faxes but won't feed paper
Apr 15, 2009 | Lexmark X4270 All-In-One InkJet Printer
Paper feed feeding multiple sheets plus noisy feed
The most likely cause of this problem is a paper feeder malfunction. Because you were not specific in the model you have, repair could be rather variable.
One plausible cause is the paper rollers have tried up. Normally when the small rubber rollers grip the paper, the friction generated by a properly moisturized feeder can grip a single sheet. If your rollers are getting dry, you can use some rubbing alcohol on a q-tip and rub it on the rollers. Make sure not to use isopropyl alcohol, that will cause the rollers to dry out even more. I've heard of people using WD-40, but I've never tried that. You would want the WD-40 to dry a while otherwise it will leave greasy residue on your nice white paper.
Another cause could be a small object (paperclip, staple, raisins) stuck in the paper feeding mechanism. Carefully inspect the feeder, comparing one side to another, and gently pushing on the movable parts to make sure they can move free. You don't want to push too hard or you could knock out a needed spring or damage the plastic gears.
Hope this helps!
Oct 16, 2008 | Canon Office Equipment & Supplies
MP470, Paper jam on one side
There is something jammed in there....shake it upside down first.....if nothing then revese feed a paper through it manually......take left side off hold paper in front and roll wheel on the left side so the paper feeds back into the machine,,,,,,open top to see in there and when paper feeds under white rollers make sure it dosent jam where wite rollers are about an inch from the right there is a small rectangle hole with a black plastic piece in there pry it up carfullywith a paper clip and feed paper with the wheel under it at that point the paper push out a bobby pin into my back tray,,,,, now everything works great.......keep checking i didn't believe something was there either but there was..... also if your paper first starts to feed and stops pull out the paper and check for a bend or crinp in it mine kept doing that and that is exactly where the pin finally came out.....
Feb 01, 2008 | Canon PIXMA MP470 All-in-One Printer
Tried solution for printer unable to initiate
This is related to the paper feed roller:
Check encoder disc if it is stained with ink or broken (its the round foil disc which is fixed on one of the three white big gear wheels on the left hand side). It should turn around without any scratching sound!
Check if another gear wheel is broken (right hand side behind the purge /parking station). Here you will find the gear box which is shifted by print head (little white plastic coming out of the metal plate between purge station and absorber box)
Pull out the paper tray and try to turn the paper feed roller by hand. You can reach it when seeing from bottom without the tray.
Dec 07, 2007 | Brother MFC 210C All-In-One InkJet Printer
Cannon pixma 1600
I had the same problem, and found that the sheet feeder mechanism was intermittent. The problem seems to be that the lubricating grease inside the mechanism.(white nylon round thing with gears on it) becomes too slippery and stops picking up the activating arm which allows the cam unit to move to kick the top sheet of paper into the rubber feed wheel.
The repair was extremely difficult because it involved taking most of the printer apart to get to the ink pump/sheet feeder mechanism.(white nylon round thing with gears on it), and then I tried quite a few lubricants (including no lubricant at all) but none of these worked reliably. Finally I tried a dab of automotive wheel bearing grease (it feels like glue), and this worked perfectly. I have had no more paper jam errors and no miss-feeds in about 7months of everyday use.
Nov 25, 2007 | Canon PIXMA iP1600 Printer
111 people viewed this question
jasbo
jasbo
