Question about Briggs Stratton H7159 & Stratton® 5500, 10 HP Generator
I have a 5.5 Vertical Briggs and Stratton about 6 years old that is mounted on a woodsplitter. This year it started dieing under load. It's driving a brand new 2 stage 11 gallon pump because I thought that may be the problem. New carb kit was installed with no change. Any idea why the engine may be dieing under load? Oil is fine also.
    Scholar:
  • 142 Answers
If the generator was used during these 6 years continuously on full or near full load, it may have loosed compression (and derated load).
If you can measure the pump current and compare with the rated of the generator it should be less than the half of the rated to run properly in continuous mode. If it is greater than 75% it may be more than the possible for this generator.
Nevertheless the new fine oil, the overheating or lowering of the oil level during operation may be the reason for stopping.
Posted on Jul 10, 2010
How to keep engine running ?
Hi Doug:
I'd drain and clean the carb, using air to blow out (gently) all the orifices. If there is a filter, make sure fuel is flowing through it, or just replace it.
Should run like a good thing after that.
Cheers.
Apr 09, 2016 | Briggs AND Stratton Intek Briggs &...
We have a briggs and stratton lawn mower that has very few hours on it but has been in storage for the last 5 years, it starts but dies
Clean the gas tank,after a year gas can turn into a gel which will clog the carb,clean the air filter,check spark plug,and readjust the carb(a small screw on the carb
Sep 03, 2012 | Briggs & Stratton Garden
Briggs and stratton vanguard 16 hp v-twin starter replacement
It most Likely is located under the engine cover..it mount just below the flywheel. Good luck
Apr 11, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
I have a briggs 22 hp vertical ohv that is about 6 years old. It is burning oil badly but still runs the mower. I worried that it was undersized for a 48 inch deck with a hydrostatic transmission. Is it...
It will give you a bit more service. However one should also replace bearings in crank and rod. I would purchase a new 6 hp from harbor freight for $100 BUCKS.
Nov 09, 2017 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs 20HP Intek sputters under load
reset the valves to specifications by gaping them all to .008 thousands The vibration will continuely make the gap wider causing this problem to get worst. Gap the valves is recommeded every other year
Jun 14, 2010 | Briggs & Stratton Briggs Stratton Intek V...
18 HP V tech B&S single is smoking only 4 years old
18HP vertical Briggs & Stratton vtech twin ohv; can't find oil leak; motor runs great; is leaking onto housing where motor is bolted to; any suggestions where leak may be coming from????????
Jul 01, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs Stratton H7159  & Stratton® 5500, 10 HP Generator Logo
250 people viewed this question
Top Briggs Electrical Supplies Experts
John Trevino
jdthefixer
rlev_7
Level 1 Expert
Are you a Briggs Electrical Supply Expert? Answer questions, earn points and help others
