Question about Linksys Wireless-G WRT54G Router
My router suddenly gets a poor signal. It is a
My router suddenly gets a poor signal. It is a Linksys Wireless-G WRT54G and Ive had it for about 3.5 years. It has always sent a strong signal, but suddenly it gets a poor signal, sometimes no signal. I have unplugged the modem and the router to no avail. I have pressed the reset button, to no avail. Its it past its prime, or is there something I can do? Thanks!
  • 85 Answers
Go to www.linksys.com click support were it says "start here" type in your router modle #, scroll down alittle click on "download" select your version, then click download firmware. This will update you router and should make it more stable. Good Luck jope this helps.
Posted on Jul 06, 2010
    President:
  • 1,851 Answers
Locate at the router's management page the Basic Wireless settings. At this section locate the line displaying "wireless channel" and change it at any channel you like, your connected devices will auto locate the new channel and connect without any problem. This happens from time to time, especially when a strong wireless transmitter is (or comes) near the Wi-Fi area (maybe a wireless phone is your problem or something like that).
Take care that in case you make a change at another setting, your connected devices may not locate the new setting, so you will have to connect to the router using the ethernet connection in order to recover your problem.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Added a linksys wusb100 adapter to my desktop and it has poor signal strength. The desktop is located on a floor above the router and the distance is about 20 feet. Laptops in the same area as the...
Check to make sure that you don't have any cordless phones in the area or ductwork directly below your computer between the adapter and the router.
Jan 18, 2011 | Linksys WUSB100 Wireless Adapter
Unable to stream novie sites with my linksys wireless-g router
Check the connection (signal) strength of your wireless connection in the status area of the task bar in Windows. Also, hovering the mouse over the wireless connection should reveal the connection speed. 54mbps is the highest you can expect on a wireless connection, which is generally OK for streaming video..Any less of a signal strength/connect speed will likely not be adequate for streaming video.
A poor signal strength is usually because of too much distance or too many walls between the router and the computer.
Hope that's helpful.
Jan 15, 2011 | Linksys Wireless-G WRT54G Router
I have a Linksys WRT54G which I have hooked up to my older Dell computer successfully. The signal is excellentfor this one, called "Bob" for clarity. I am trying to hook up to "Bob"...
Sounds like you may be experiencing excessive interference in the WIFI space. Try setting the linksys router to use a different wireless frequency. (normally the available ones are 1 - 11).
Jan 11, 2011 | Linksys Wireless-G WRT54G Router
I have the Linksys WRT54G router hooked up thru Ethernet to my desktop PC with Windows XP. I go thru a cable modem to the internet. I have 2 laptops, both with Windows Vista on, wirelessly linked to to the...
Low or poor signal is mainly caused by the following major factors:
Going Around Physical Obstructions
Wireless networks are also susceptible to obstructions that may lead to low signal. Often, the signal gets reflected, refracted or absorbed by the obstruction.
Common obstructions are:
  • Cabinets
  • Mirrors
  • Glasses
  • Metal objects
  • Thick walls and ceilings
If you have any of these objects between your wireless adapter and access point, consider relocating your access point somewhere high to get around the obstruction.
Aug 05, 2010 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G doesn't send a wireless signal out anymore. I did the driver update and still doesnt work.
1. check the RJ 45 cable see if you are getting a signal through a hard connection if not go in to the router and check the status. You may have to reset the router and to release/ renew the IP in the router. Call Linksys for there support they will be happy to do check-sums to see if the router is defective. you can also check their site for troubleshooting to check the router to see if there is a malfunction.
Jan 29, 2010 | Linksys Wireless-G WRT54G Router
I am trying to hook up a omni antenna to a wrt54g is it possible in a motel setting
Hi there If u have a linksys wrt54g router. the omni antena will not give u the maximum wireless signal if u are going to set it on a motel, u need to setup a wireless access point in order to broadcast the signal or to repeat the signal u need a wireless access point and the model # is WAP54G..
here is the link just incase u want to know more about on how to set up a wireless access point
1. How do I configure an access point as a wireless bridge?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4194
2. How do I configure an access point as a wireless repeater?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4200
3. How do I configure an access point as an access point client?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4202
4. How will I know if an Access Point is configured as an Access Point?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4165..
check this out and i hope this will solve ur concern..
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
How do i connect and get signal?
This is a common problem with Linksys wireless routers and primarily the WRT54G and WRT54GS. For some odd reason they all of a sudden go stupid and forgetful.
The easiest method to revive these routers is to go to the Linksys web site and get the automatic configuration download for your specific model of wireless router.
Hope this helps you
Dec 26, 2008 | Linksys Wireless-G WRT54GS Router...
Occasional signal loss
Go to www.linksys.com and see if there is a firmware update for your model
Aug 23, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
127 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
