Question about Zodiac Baracuda G3 Automatic In Ground Pool Cleaner
Baracuda G3 My Baracuda G3 moves very slowly then stops There are no blockages and the pressure is good
I just had the same problem. Did everything I could find on the Internet. Ended up calling he pool guy. Guess what? There is a small tube inside the suction part. He replaced that and voila it works! The one that was onside it had a small slice on it that wouldn't allow for flow through it. He said even a sharp leaf will slice it and it won't work. Hope h
This helps.
Posted on Oct 09, 2012
  • 640 Answers
Check your pool cleaners hose to make sure that it is not becoming tangled. Storing the hose in a coiled position will cause this. If it is not moving and it is not the hose, you could have a leak in a connection somewhere. If the cleaner is getting adequate suction, it should be moving. Try adjust the hose weights to make sure the cleaner is at a 45 degree angle to the pools floor.
Posted on Apr 13, 2011
My g3 is not working, took it to pool store and they replaced diaphram, but still not hopping or moving, suction is good but now movement.
There are a couple things to check with these pool cleaners when they stop moving. Use Pool Pulse to insure proper flow through the cleaner. Clean baskets and filter to ensure that you are not clogged. Check hose sections for leaks by lifting each section above water.
Apr 09, 2011 | Zodiac Baracuda G3 Automatic In Ground...
Zodiac G3 stopped traveling even though there is good suction.
There are several things that you can check on these pool cleaners if you are sure that the suction is not a problem. Normally, I would start by suggesting you check for blockages and obstructions in the cleaner, filter, and skimmer. However, if you are getting the correct suction, this shouldn't be a problem. I would also check the diaphragm for damage. To adjust a worn diaphragm, loosen the cassette swivel, gently push down on the the inner pipe, and retighten the cassette swivel. Check all hose sections for leaks by lifting each section above water.
Mar 06, 2011 | Zodiac Baracuda G3 Automatic In Ground...
How to put on the pressure regulator
Here is a copy of the users manual for the G3 pool cleaners from the Zodiac website. Any set up and installation instructions that you need should be in the manual.
http://www.baracuda.com/resources/manuals/TL-2050.pdf
Jan 08, 2011 | Zodiac Baracuda G3 Automatic In Ground...
I have replaced the diaphragm on my Classic. I have even replaced the filter sand. There are no apparent tears in the pipes, yet the cleaner runs for a few minutes and then stops dead, not pulsating. The...
Use Pool Pulse to ensure proper flow. It could feel ok on your hand, but you need very precise pressure to power these pool cleaners. If you are not familiar with how to use the Pool Pulse feature, take a look at the users manual below. They have a step by step guide to this feature.
http://www.baracuda.com/resources/manuals/G4W83408.pdf
Oct 20, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Even with good pressure the cleaner barely moves
If you are sure that you have adequate pressure (main drain closed, no leakage, proper flow), it is probably your diaphragm. Check the diaphragm for damage or wear. If you see that there is damage or wear, replace the part. This should solve the problem with the pool cleaner.
May 19, 2010 | Zodiac Baracuda G3 Automatic In Ground...
MY POOL CLEANER WILL RUN FOR A FEW MINUTES, THEN STOP. SO METIMES IF I SHAKE THE HOSE IT WILL START AGAIN. ANY ANSWERS?
Hi , most pool cleaners run by the force of the sucked up water moving gears inside the cleaner .. if yours is this way, then any blockage in the cleaner or in the hose attached would restrict the flow and keep the cleaner from moving.
Apr 30, 2010 | Zodiac Baracuda G3 Automatic In Ground...
My Baracuda Zodiac works for a few minutes and
check the diaphragm for debris, damage, or deformity. unthread the collar above the handle and push the tube downward. Inspect the rubber diaphragm, any damage or deformity will cause erratic behavior.
Apr 07, 2010 | Zodiac Baracuda G3 Automatic In Ground...
My baracuda G3 stop working is not pulsating and therefore not moving. I checked the suction and the hoses even the diaphram everything looks ok.
If you have suction at the bottom of the cleaner, there has to be a problem with the diaphragm. I would remove it and recheck.
Feb 01, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Baracuda G3 zodiac Clings to bottom or sides moving slowly
here is a link to the Technical Support at Baracuda. this should be able to solve your problems. initially sounds like maybe too much suction.
Feb 25, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Zodiac Baracuda G3 Automatic In Ground Pool Cleaner Logo
709 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
