Question about Dometic Rooftop RV Air Conditioner
Roof Top A/C problem
Last year I had a problem with my front a/c unit's compressor not shutting off. Even after I turned the switch to off, I heard a humming from the unit and ended up throwing the feeder breaker to shut it down. Never did figure out what happened. Got it home to check it out and the unit worked properly for the rest of the season.
This weekend it started cycling with the compressor on 1.5-2 mintutes then off for 4-5 minutes. Now the compressor won't even kick in. My back unit is starting the cycling thing also, but not at those short time periods. The units are Duo Therm 13,500 Penguins, model #610015.305. Any ideas?
    Top Expert:
  • Dometic Master
  • 5,922 Answers
Compressor overheating
Posted on Sep 15, 2017
mikeandkim5
SOURCE: compressor on ac unit
we have the same problem but it wont dupicate when take it in to be checked replaced lower board but didnot help
Posted on Jul 16, 2008
SOURCE: duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Posted on Jul 19, 2008
pierre1811
  • 144 Answers
SOURCE: Have Duo Therm roof mount A/C. Fan runs but when
It sounds like the compressor is locked up. You can try a start boost or hard start kit but once this starts the compressor is on it's way out.
Posted on Feb 26, 2009
  • 659 Answers
SOURCE: Duo Therm compressor tries to start and kicks out
I don't think these little units have a start capacitor but what I would do is check that the on/off switch wires to make sure they aren't loose. Also check the wires to the compressor for loose wires as well. It is possible that these are the first signs that the compressor is about to fail. They also can act up some when they haven't been used for awhile and then you try and start them up. Try running the unit for a few hours without asking it to cycle. It might just be a sticky valve.
Posted on Apr 13, 2009
  • 116 Answers
SOURCE: A/C Thermostat display is blank
find the stat wire and jump red to green to see if fan comes on if so then stat bad if not check for 24v ac transformer or 5 amp fuse
Posted on May 09, 2009
Dometic roof top AC unit compressor turns on even if T-stat is off. Only way to get the compressor from turning on is to turn the breaker off. Unhooked T-stat wires to see if issue was there but the...
Sounds like you may have a couple of problems there. First, have you checked incoming voltage to make sure you are getting 100-120 VAC at the AC control board in ceiling? If that's ok, try removing/disconnecting Ac compressor wire at ceiling control box and see if compressor shuts off then. May be a capacitor for compressor going or shot, and possibly relay in control box sticking, or bad wiring to thermostat. Have you had any lightning in the area prior to all this happening?
Jan 23, 2013 | Dometic Rooftop RV Air Conditioner
My coleman mah 3 roof top will not blowon fan side
Sounds like you have either a bad fan motor or a bad fan motor capacitor. When you turn the unit on with the fan not working, the compressor (the humming noise) runs and gets real hot real quick resulting in the compressor cutting off ( the nothing after) on it's inside high temp switch. This is what the compressor is designed to do so that when this happens, it does not burn the compressor out. Replace you fan capacitor, give the compressor an hour to cool, then try it. In most cases and if I'm correct, the unit will run just like you want it to. Good luck.
Please rate solution
Sep 09, 2009 | Coleman Mach III Air Conditioner
Possible Contactor Issue
Sounds like a bad fan switch in your unit. That unit has a fan board in it that is time delay on and off. Turn the fan to the on position and let it run all the time. If it keeps temp and does not shut off it is the fan realy board. The board also controls the compressor. Check that first and then the tsat. Russ
Jul 24, 2009 | Carrier 38CKC042 Air Conditioner
Only at night the unit runs fine day-time it short cycles and will shut completely down and restart not just compressor the whole thing
Has anyone cleaned coils inside, as well as taken cover of on roof & done the same? If you remove inside filter etc, and look way up in front with a flashlight, you'll see coils that need cleaning usually. I use a shop vac with brush & long extension. Tight fit near top, but can be done, without damaging coils. Then take cover off on roof unit (with breaker shut off ) & clean both sides of rear fins, as well.
Jul 08, 2009 | Dometic Rooftop RV Air Conditioner
AC ROOF TOP CYCLING EVERY 5 MINS
well most unite will go to 54 degrees but 43 that coooool man what complain about. the compressor dose shut down at certain temp so as not to turn into one hunk of ice. that what they are design to do.
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
Coleman roof top rv air no cool,warm compressor
No Cooling.
Turn the selector switch to “Cool” and the
thermostat to a low temperature (below room temperature).
The fan runs OK, but the unit does not cool. When the unit
housing is removed, we observe that the compressor does not
run; however, it periodically hums for 15 to 30 seconds.
Possible Causes- Check all of this before buying a new unit, that may not be the solution.
“The voltage could be low – ”
a) Check the voltage between #1 on the
overload switch and the “R” terminal of the
compressor while it is not humming. This
voltage must be 115 volts domestic USA
models or 240 volts export/overseas models.
No less than minus 10% is allowable.
b) Check the voltage from “C” or “R” of the
compressor while it is humming (trying to
start). The latter reading will probably be
lower, but it still must be 103.5 volts
minimum domestic USA or 216 volts
minimum export/overseas models.
If the first reading is above 103.5V domestic USA and
the second is under 103.5V domestic USA, there is
too much voltage drop in the lines - a situation which
must be corrected for the air conditioner to perform
safely and satisfactorily.
2. “A capacitor could be shorted, weak or open.”
Turn the power off.
Caution – There is always a chance that a capacitor is
holding a residual charge, so before touching a
terminal, discharge the capacitor as explained earlier
in this booklet.
Remove capacitors, visually examine them and test
them per instructions given in earlier section on
capacitor testing (See page 9).
If the capacitors test OK, replace them and carefully
reconnect the wires. Be sure the wires are connected
to the right terminals.
3. “Start relay contacts could be open – ” if so equipped.
Turn off all power, then check for continuity with
ohm meter between terminals 1 & 2.
4. “Compressor start winding could be open or
grounded.”
Check compressor windings per instructions. See the
section on the compressors (See page 8).
5. “Compressor could be mechanically stuck.”
This very rarely occurs and when it does, it is usually
after a lengthy shutdown. This should be considered
only after all the above possible causes have been
positively eliminated. To free a stuck compressor, use
your hermetic analyzer according to the
manufacturers instructions.
Jun 27, 2009 | Coleman Mach III Air Conditioner
This is a duo derm roof top air conditioner, possible compressor freezing up
If the compressor is not even trying to start you have an electrical problem in the circuit for the compressor. The thermostat could be open and not supplying power to the compressor or the thermal overload device could be open.
Nov 06, 2008 | Dometic Rooftop RV Air Conditioner
2000 roof-top Brisk-Air
I think you have a high pressure cutoff cycling the compressor on and off. Clean the filter inside the unit. Then with a hose clean out the foil condenser filter on top of the camper. Also you may need to buy a coil comb and comb out bent or damaged areas of the condenser coil on the unit that is above the roof of the camper.
Jun 09, 2008 | Dometic Rooftop RV Air Conditioner
Coleman rv roof air conditioner
(1)Check compressor contactor or relay if it stock in the close position
(2)Check for welded contact points
(3)Check switch control for defect
(4) Check if compressor contactor still geting power when it is off
Let me know what works for you.
Mar 30, 2008 | Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
99 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
