Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Lift the tractor to work under deck
How do I get the tractor up enough to work under the tractor ?
Thanks
I use a chain block and tackle to lift and support with car stands once in the air. It can be used front or back and makes it so much easier for repairs/maintenance
Posted on May 09, 2014
    Brigadier General:
  • 3,911 Answers
One would think that a jack and jack stands would come in handy.
Posted on Jul 07, 2010
Craftsman tractor mower deck doesn't go up or down
Make sure lift lever is connected properly and adjusted.
Jun 30, 2014 | Craftsman 26 Hp 54" Deck Yard Tractor
I recently purchased a Troy Bilt Bronco riding mower from a local Lowe's Store. It was delivered by a flat bed truck. The mower was removed by placing the forks of a fork truck under the mower deck and...
I never heard this problem before.
It would seem to me that if you were to lift a mower with forks, they should NOT be under the deck.
I have a Craftsman and I think my deck is bent, I can't align it in all the directions the way I should be able, maybe they did that to mine.
I would call Troy Bilt; it's important enough.
Gary
May 31, 2011 | Troy Bilt 22HP Hydrostatic 46" Riding...
Removed mower deck with no problems. Cannot re-attach. Do you have a step by step instruction for this process?
1. Raise attatchment lift lever to its highest position
2. Slide the mower deck under the tractor with deflector shield (grass Chute) to right side of tractor
3. Lower lift lever to its lowest position
4.. Connect the front links to the mower deck and secure with the retainer springs.
5. Connect thye suspension arms to the rear deck brackets and secure with their retainer springs.
6. Connect the anti-sway bar to the chassis bracket and secure with the retainer spring.
7. Push the clutch cable housing guide into the bracket, and slide the collar onto the guide and
secure it with the large retainer spring.
8. Place the flat washer and clutch spring on the idler pulley bolt and secure them with the small
retainer spring.
9. Re-install the blade belt onto the engine pulley it goes on.
Apr 23, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
There is a big, wrap-around lifting bar in the front of my Husky used to raise the engine assembly off the mowing deck but I can't figure out how to free the engine assembly so I can pivot it up to expose...
most rideons have the deck assembly able to be removed without too much work.usually release any spring tension,then spring clips holding the arms on,then usually you can disconnect the belts and slide the whole deck out sideways,from under the rider.
Jun 29, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
How do you adjust the cutting deck?
Pete, go back to partstree and look at the diagram for lift arms. Item #27 is your lift cables. You will notice there are several little ferrules or balls on the cables, you unhook the cable and slide these up or down as needed to adjust your deck. If you need the deck higher, you would position more of the balls under the lift arm on each side. If you can't get the desired height then your cables are stretched and need to be replaced
Oct 09, 2009 | Garden
My john deere 214 won't start
The deck lift lever normally wont start lifting until you pull back at least half way.Ther are 2 sets of wires that go under the fender deck,one set goes to the seat switch and the other set goes to the neutral start switch next to the shift lever,just in front of the seat.The neutral start switch wires more than likley came loose when you pulled fender deck off.The micro switch is on the back side of plate that surrounds shift lever.
Sep 03, 2009 | John Deere &Reg Branded 27" Tractor Metal...
How do I adjust the mower lift on my Husqvarna lth 130 lawn tractor? Can't seem to be able to raise deck high enough when mowing
Some units have a dial style adjuster on the lower section of the dash. However, you may have to manually adjust the two rods under the unit that attaches the housing to the mower. Check this out first to see if this helps.
Aug 23, 2009 | Garden
Deck not high enough
Assuming this is a Craftsman, there is an adjustment for height, but mainly just for leveling purposes. There is a nut on each side in the center of the hanger and unless these are all the way to the bottom end, it's not going to raise the deck that high. I would look carefully at the deck hanger mechanism on each side. Something is obviously not right. Has it always been like this, or did you just get the mower? You can go to.. http://www.searspartsdirect.com/partsdirect/index.action Then enter the model number that's under the seat, hit search, then scroll down to Lift Assembly for a look at how it is set up. I have seen broken hanger rods as well as a broken weld on the lift handle where it's attached to the cross shaft. Hope this helps..
Jun 28, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
139 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
