Question about Astoria Argenta AEP-2 Coffee Maker, Espresso Machine
Filling the boiler tank
When using the frother and hot water, the pump does not work, the 4 lights on the both control pannels are flashing, but goes off when the machine is switched off ans on again, the pump however does not work when using the above said. The pump and motor has been replaced and in good working order. Pls Help !!
    President:
  • 1,618 Answers
Sounds like the auto fill circuit is not engaging or is getting blocked, usually when all the lights in front is flashing, machine is saying it is not getting water.
Posted on Jul 07, 2010
Hot water is not staying hot
Is the control that operates the pump located in the storage tank? If so the pump not be pumping. A few factors might be needed to solve the issue.
Dec 18, 2013 | Taco 006-B4 1/40 HP Bronze Circulator Pump
Tip
Ventilate error -
The following procedure works when you get the ventilate error:
The Ventilate sign can be due to one or more of the following reasons:
Cause 1- Water leaking from the inlet valve below the water tank. The hose from the inlet valve to the pump can be air locked. When using the hand pump, do not thrust its nozzle too deep
Cause 2- Blockage in the passage of water due to clogged passage anywhere between the pump and espresso delivery nozzle.
Cause 3- Pump is not working. Open steam/water outlet knob and hear the pump work. If you do not hear any noise from the pump, this may be the main cause.
Cause 4- Flow meter is faulty. This part is like the water meter for homes. It measures the flow of water and signals the electronic board. The malfunctioning flow meter will not send signals even when water is flowing through it.
Cause 5- Hose is disconnected and water is not flowing in the system.
Cause 6- O-rings at hose connection is leaking, reducing the water flow to be sensed by flow meter.
Cause 7- Boiler gasket is leaking. Reduces flow of water through the system.
Cause 9- Brew unit is blocked, blocking flow of water through the flow meter. This also causes pump to slow down and ultimately stop with muffled sound within 15 seconds.
Cause 10- Brew unit not connecting brew valve, preventing flow of water. Same sign under cause 9.
Cause 11- Steam is leaking. Registers reduced flow of water at the flow meter.
Cause 12- Solenoid valve is blocked or solenoid coil is bad. Same observation as cause 9.
Cause 13- Electronic Control board is bad. Though rare it can happen due to condensed water from leaking steam. When steam is leaking or boiler is leaking, machine should not be used any more to prevent steam shorting the Electronic board.
Some of the above causes can be checked and corrected before seeking technical help. Do not assume anything without physically checking each of the following:
1- Make sure the water tank is full. If the water tank has water level float, make sure the float is in its housing and it floats as water is filled in the tank. If the level float does not rise with the level of water, then replace the float.
2- Water is not leaking from below the tank. The inlet valve is good. If leakage is present, replace the gasket in the water inlet valve.
3- Prime the machine by opening the hot water knob for 20 seconds or pressing the hot water button. Hot water flow shows the boiler is not blocked with minerals and pump is good. The solenoid valve is good.
4- Water & steam flowing normal, check the brew group for blockage. Determine when was the last time brew group was cleaned. Clean the brew group as explained elsewhere on these pages. If the machine has pre-ground function, try making a fake espresso (without coffee). Make regular espresso in other models to make sure that water goes through brew group and espresso is dispensed.
4- If hot water does not flow because the pump is not activated, then pump is bad. Replace pump.
5- Pump starts to work but within few seconds its sound is muffled and finally stop. This indicates there is serious blockage in the water line or the boiler is clogged with mineral deposits. If water is leaking and seen on the counter top, the chances are that water is leaking from hose connections(replace O-rings) or the boiler is leaking from seams (replace boiler).
6- Prime the machine by opening steam outlet for 20 seconds. Steam flow shows that steam boiler / steam outlet is not blocked. If the steam does not flow, then steam boiler or steam passage is blocked. Replace steam boiler or steam valve
7- Check the solenoid valves to make sure that they open & close as the coil is energized. Solenoid valve is located between the pump and boiler. The pump is activated simultaneously as the solenoid valve when espresso selection button is pressed. Some models may have a solenoid valve near the steam valve. In these models, the solenoid valve is activated to allow passage for steam/hot water. If the valve is not functioning, the ventilate sign will appear.
7- Hear the pump work when priming the machine. Louder noise from the pump can be due to
** air-locked water hose, or
** water is not sucked from the tank or the pump is sucking air instead of water or
** the diaphragm inside the pump has lost flexibility and not developing pressure to push water forward
** the hydraulic system is blocked at one or more locations due to mineral sediment. Find the location and cause of the block and correct it.
** Clean the brew unit (see cleaning instructions) and make sure that
a- the ground coffee used is not powdery fine.
b- The dose of coffee grounds is not in excess specification
c- check if there is blockage. Find the cause and remove it.
8- If steam and hot water flow is normal, but the ventilate sign persists, then the flow meter or the electronic control board is bad. Replace flow meter or the control board, as necessary.
Try also the following:
  • Press hot water button once. Message on the screen will not change, this is normal.
  • Open the steam knob and allow the water to flow freely from steam wand into a cup. The screen should now read "Hot water,ventilate", you may need yo empty several cups of water before message changes. In some case it is necessary to refill the machine container without interrupting the operation.
  • As soon as the screen displays "hot water," turn the steam valve off .
  • If the machine warms up again, then problem is fixed.
on Jan 21, 2011 | Saeco Magic Comfort Plus Espresso Machine
My Jura Capresso E 8 is stuck in open tap filling system. I open tap it says filling system, it says close tap, when I close the tap it goes back into open tap. Float valve looks fine, water is moving
Open the tap with frother spout off. This happened to mine and I took the frother tip off and opened tap with tip off. Water filled and I closed tap...Machine returned "Ready". I heated water in microwave for three minutes- placed frother tip in hot water and all kinds of gunk came out. Lesson learned- Do a thorough cleaning of frother by immersing it in very hot water at least once monthly- even if you don't use it
Jan 06, 2013 | Jura Capresso Impressa E8 Espresso/Coffee...
Filter change
this was absolutely the problem with my Jura Capressa E-8 machine. I followed instructions after changing the filter. I opened tap-machine stated that it was filling system- I closed tap when instruction. The open tap remained on because no water was filling system. I took the frother tip off and opened tap. Water filled system (container under frother). I closed tap without the frother tip. Machine Ready.... (I heated water in microwave for three minutes) I placed the frother tip in there and used a wooden skewer to ensure frother was clear of debris... Worked like a charm!
Nov 26, 2012 | Jura Capresso Impressa E8 Espresso/Coffee...
Amtrol 41 hot water maker :not working when calling for hot water,contols are on showing temp,but tank is cold.oil fired boiler is fine,the whole system is 5 yrs old.
The problem is probably with the circulator pump or the zone valve, which ever way your water circulating from the boiler is controled.
The water needs to be moved through the boiler and the coils in the Hot water maker to heat water. If this is not happening then no water will be heated.
Check for power and then is the pump is running or the zone valve opening.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 21, 2009 | Dishwashers
Bled radiator and now boiler is losing pressure
if your boiler is a combi re-pressurise locate filling loop and refere to manual
Oct 09, 2009 | Water Heaters
Water does not come out the frother/hot water spout .
check your solenoid valve and security valve of boiler of the machine. make sure they are clean and work good, than you will have perfect espresso again.
if pump runs without your comand check up the swich of brewing coffee.
Mar 31, 2009 | Jura Capresso C1500 Espresso & Coffee...
I purchased a second hand Saeco Royal Professional coffee machine and the frother does not work. When I press the button all I hear is a pumping sound but no suction what so ever. Also when I use the...
try inserting the frother in hot water its probably block and for our water everytime you whant steam open vale boiler start to boil water let the water drip into the tray wait untill steam come out pierre
Jan 10, 2009 | Saeco Odea Giro Plus Coffee Maker
Saeco Primea Cappuccino Ring--stuck on "boiler filling" mode!
Hello, I had the same problem, therefore the machine has gone to a repair centre. The problem is caused by a mechanical switch in the machine, that doesn't work properly. To repair it you've to open the machine completely, but that’s not easy. Because there is nothing broken you’ll should have warranty because it is a production failure. The solution in my case was to heat up the switch and push it a little together so that the contact works properly. It is the switch that you hear when you turn on the machine.
Oct 29, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Steamer
Both tubes must be in the water. If you haven't used the machine for awhile, fill the water canister, turn the espresso maker on and also turn on the delivery switch (the top switch on the EC140). You'll hear the pump and in a second or two water will begin to exit the boiler nozzle. Immediately turn the delivery switch off. Wait for the "OK" light to come on. Press the "Steam" switch (the middle switch on the EC140, place an empty cup under the frother and turn the steam control knob on top in the counterclockwise direction. Steam will come from the frother. Be very careful to avoid contact with this steam.
Apr 23, 2008 | DeLonghi EC140 Espresso Machine
Astoria Argenta AEP-2 Coffee Maker, Espresso Machine Logo
157 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
Charles T Nevin
Charles T Nevin
J.D. Browning
J.D. Browning
NOEL
NOEL
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
